Media Browser does not stream any file
fulvio007
Post Wed Jan 30, 2013 11:28 pm
I just installed serviio on my nas and it works well.
However, when I use the Media Browser, I am unable to play any file: all the times I have the same error: “200,Stream not found”.
Here the last error message received:
200, Stream not found, NetStream.Play.StreamNotFound, clip: '[Clip] 'http://192.168.0.100:23424/cds/resource/27/MEDIA_ITEM/FLV-0/MEDIUM,flv_player?authToken=b3e69122963241a083c1b94c94134bd8''
I copied/pasted the http command (http://192.168.0.100:23424/cds/resource ... ITEM/FLV-0) in my Browser and the error message that I got is:
<result><errorCode>553</errorCode><httpCode>401</httpCode></result>
I also pasted the command in VLC but I was stuck at username and password request.
For information, serviio is running on a qnap ts-219p+.
This is my OS: Linux FulvioNAS 2.6.33.2 #1 Wed Dec 5 11:46:33 CST 2012 armv5tel unknown
This is my FFmpeg version: ffmpeg version 0.8.10, Copyright (c) 2000-2011 the FFmpeg developers built on Dec 5 2012 02:57:35 with gcc 4.2.1
To install serviio, I followed this guide: http://forum.qnap.com/viewtopic.php?f=252&t=45994
I enabled the detailed logging and it is available here:
https://dl.dropbox.com/u/3404665/serviio.log
Has anyone else come across this ?
How could I fix this problem ?
Thank you in advance.
Post Thu Jan 31, 2013 10:39 pm
Re: Media Browser does not stream any file
Your FFmpeg is too old. Get the latest one.
fulvio007
Post Fri Feb 01, 2013 10:08 am
Hi Zip,
Thank you for your reply.
However I am a newbie, could you provide me more information on how I can upgrade ffmeg? Notably:
1 . Do I have to remove the supplied ffmpeg before compiling/installing new one? Or can/should I run them both?
2. Should I use ipkg or compile from source?
3. Do I have to create symlinks for the new version? And does it survive reboot?
4. I am thinking to follow tutorial in the link below (point 2, hard way), am I right or totally wrong?
http://wiki.serviio.org/doku.php?id=install_qnap
Thank you in advance for your help.
Post Fri Feb 01, 2013 4:36 pm
I'm not familiar with the NAS nor the package. Ask at the QNAP forum.
Xmantium
Post Sat Feb 02, 2013 8:58 pm
The QNAP admin may packaged the wrong ffmpeg version
Contant the qnap moderator internaut19 for an update
He packages both Intel and Arm versions
