Missing JVM
piggygrunter
Post Fri Feb 01, 2013 2:16 pm
Missing JVM
I wonder if any one can help?
I installed Serviio 1.1 on one of my computers that uses Windows 8 Pro O.S. When I installed Serviio Java 6.0 was installed with it. I then test Serviio and it worked fine. However, later Java automatically updated itself to Java 7. Since that update I can no longer operate Serviio. Serviio Console keeps telling me Java JVM is missing and then shuts down.
I should mention I had similar problems on two other computers that used Windows 8. Both of those computers self righted themselves on restart and I was then able to use Serviio.
If anybody has any ideas how to resolve the issue, I would welcome their help? I am not technical by the way, so the answer will have to very basic, so that i can understand it.
piggygrunter
Post Fri Feb 01, 2013 2:19 pm
Re: Missing JVM
Do you try to reinstall serviio after the Java update ?
Users browsing this forum: Google [Bot] and 46 guests
