HOWTO: Serviio 1.1 on Zyxel NSA 325
DeanoX
Post Tue Jan 15, 2013 1:12 pm
In order to run Serviio on the Zyxel NSA325 a number of steps are required. This hasn't been tested on other Zyxel models but the key enabler is the Fonz Fun Plug linux environment so the steps should be common for any NAS where FFP is available. You will need basic knowledge of linux to login via SSH and edit configuration files etc.
====== 1) Install FFP 0.7 zyxel package ======
Follow the instructions to install the Fonz Fun Plug (FFP) Zyxel package.
Enable the package in the Zyxel admin pages and check you can SSH into the NAS.
====== 2) Add the various FFP site definitions ======
Follow these instructions to add a number of extra FFP package locations.
====== 3) Install ffmpeg/lame ffp packages. ======
Add some additional ffp packages using the slacker installation utility:-
su
slacker -i ffmpeg-0.11.1-arm-1
slacker -i lame
The root (su) password should be the admin password you have setup your nas with.
Now verify that ffmpeg is working:-
ffmpeg -version
should give similair to:-
ffmpeg version 0.11.1
built on Jun 25 2012 20:34:06 with gcc 4.5.4 20111110 (prerelease)
configuration: --prefix=/ffp --disable-static --enable-shared --enable-gpl --enable-nonfree --enable-small --disable-encoder=aac --disable-decoder=aac --disable-armv6 --disable-armv6t2 --disable-armvfp
libavutil      51. 54.100 / 51. 54.100
libavcodec     54. 23.100 / 54. 23.100
libavformat    54.  6.100 / 54.  6.100
libavdevice    54.  0.100 / 54.  0.100
libavfilter     2. 77.100 /  2. 77.100
====== 4) Install Java ======
Follow these instructions to install the headless (no GUI etc) version of Java for ARMv5
As the admin user (not root) verify java is working :-
  java -version
should give similair to :-
  java version "1.7.0_10"
  Java(TM) SE Embedded Runtime Environment (build 1.7.0_10-b18, headless)
  Java HotSpot(TM) Embedded Client VM (build 23.6-b04, mixed mode)
====== 5) Install Serviio ======
As root (su) download the Linux serviio package to the nas:-
  cd /ffp/opt
  wget http://download.serviio.org/releases/serviio-1.1-linux.tar.gz
  tar xfvz serviio-1.1-linux.tar.gz
Set some permissions (Write for the library,log and plugin directories) :-
  cd /ffp/opt/serviio-1.1
  chmod a+w library
  mkdir log
  chmod a+w log
  chmod a+w plugins
Create a symbolic link to the version for easier upgrades later :-
  cd /ffp/opt
  ln -s /ffp/opt/serviio-1.1 serviio
Create a temporary directory for Serviio
  mkdir /ffp/tmp
Create a FFP startup script
  cd /ffp/start
  touch serviiod.sh
Edit the file and paste the following
#!/ffp/bin/sh
# FFP Startup script for Serviio
EXEC=/ffp/opt/serviio/bin/serviio.sh
PIDFILE=/var/run/serviiod.pid
JAVA_HOME=/ffp/opt/java/jre
OPTS=
test -x $EXEC || exit 0
case "$1" in
  start)
   echo "Starting Serviio"
   # set required JAVA home environment variable
   export JAVA_HOME
   # Use the normal serviio.sh script to ensure correct environment is set up
   if start-stop-daemon --start --quiet --oknodo --make-pidfile --background --pidfile $PIDFILE --exec $EXEC -- $OPTS; then
       echo "OK"
   else
       echo "Failed"
   fi
  stop)
   echo "Stopping Serviio"
   # Kill both serviio.sh script and Java process
   serv_kill=`ps aux | grep serviio.sh | grep -v grep | awk '{print $2}'`
    java_kill=`ps aux | grep org.serviio.MediaServer | grep -v grep | awk '{print $2}'`
            if [ "$serv_kill" = "" ]; then
                    echo "Serviio shell is not running"
                    RETVAL=1
            else
                    kill $serv_kill
                    RETVAL=0
            fi
            if [ "$java_kill" = "" ]; then
                    echo "Serviio Java is not running"
                    RETVAL=1
            else
                    kill -9 $java_kill
                    RETVAL=0
            fi
   echo "OK"
   status)
         serv_pid=`ps aux | grep serviio.sh | grep -v grep | awk '{print $2}'`
            java_pid=`ps aux | grep java | grep -v grep | awk '{print $2}'`
            if [ "$serv_pid" != "" ]; then
                    echo "Serviio shell (pid $serv_pid) is running"
                    RETVAL=0
            else
                    echo "Serviio shell is stopped"
                    RETVAL=1
            fi
         if [ "$java_pid" != "" ]; then
                    echo "Serviio Java (pid $java_pid) is running"
                    RETVAL=0
            else
                    echo "Serviio Java is stopped"
                    RETVAL=1
            fi
esac
exit 0
Once saved make the file executable
  chmod a+x serviiod.sh
We need to make some changes to the serviio startup script and the Options passed to Serviio i.e. specify the ac3_fixed encoder (-Dserviio.fixedPointEncoders) and temp directory for transcoding (-Dserviio.defaultTranscodeFolder=/ffp/tmp).
Edit /ffp/opt/serviio/bin/serviio.sh and find the line beginning "JAVA_OPTS" and change to
  JAVA_OPTS="-Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=$SERVIIO_HOME/library -Dserviio.fixedPointEncoders -Dserviio.defaultTranscodeFolder=/ffp/tmp -Dserviio.home=$SERVIIO_HOME"
Change the last line that executes the Java to decrease the memory to 384M :-
  "$JAVA" -Xmx384M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
====== 6) Serviio should now start :- ======
To start serviio (On boot will start automatically)
  sh /ffp/start/serviiod.sh start
Check the Java process is running
  ps -ef | grep serviio
Should show both the serviio.sh and underlying Java process
  root     27790     1  0 10:53 ?        00:00:00 /bin/sh /ffp/opt/serviio/bin/serviio.sh
  root     27795 27790  4 10:53 ?        00:03:34 /ffp/opt/java/jre/bin/java -Xmx384M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/ffp/opt/serviio/library -Dserviio.fixedPointEncoders -Dserviio.defaultTranscodeFolder=/ffp/tmp -Dserviio.home=/ffp/opt/serviio -classpath /ffp/opt/serviio/lib/*:/ffp/opt/serviio/config org.serviio.MediaServer
Serviio can be stopped with
  sh /ffp/start/serviiod.sh stop
====== 7) Manage Serviio and add media ======
Install the Serviio console of your choice (e.g. Windows Serviio package and select console only) and configure to remotely manage the NAS instance of Serviio.
To add a folder you need to use the relevant linux path on the server. e.g. for a single mirrored pair of disks that would be:-
  /i-data/md0/<SHARE NAME>/<MEDIA FOLDER>
e.g.
I wouldn't recommend the NAS is allowed to generate thumbnails as it drives the CPU quite hard. Initial loading of the library will also work Java and ffmpeg hard until fully scanned
Zyxel NSA325 running Serviio 1.1 | Sony Bravia 2011 KDL-24EX320 / KDL-40EX723
slyguy42o
Post Tue Jan 15, 2013 4:02 pm
Re: HOWTO: Serviio 1.1 on Zyxel NSA 325
nice work, you should probably post this in the wiki if you haven't already.
DeanoX
Post Tue Jan 15, 2013 4:37 pm
I tried....but I dont think I can add a page ?
julus
Post Tue Jan 22, 2013 9:35 am
Thanks for the guide. no problem at all except one thing:
you have a typo in
"Edit /opt/serviio/bin/serviio.sh and find the line beginning "JAVA_OPTS" and change to:"
it should be:
DeanoX
Post Tue Jan 22, 2013 8:45 pm
Thanks -now corrected. Glad it worked for you :-)
barmalej
Post Tue Jan 29, 2013 10:08 am
Excellent tutorial. I was planning to write it myself on another forum ;) , but you saved my time. Have you plans to make FFP package of Serviio?
julus
Post Sat Feb 02, 2013 3:16 am
Just a note for the web mediabrowser of Serviio on NSA 325
To make flv transcoding works - ffmpeg needs to be recompiled as it is not compiled with --enable-libmp3lame. This was not much problem (but time consuming, ARM is not made for compiling packages :)
Anyway, after the recompilation the web mediabrowser kinda worked, but the CPU was not strong enough for real-time transcoding to flv. Possibly there is a way to improve it (use better input format, or modify output parameters) but I was not patient enough.
nsa325sid
Post Sat Feb 02, 2013 9:58 pm
Re: thanks..installed.. but transcoding is not fast enough
Great tutorial. Thanks, followed and installed without any problems...it is working now, but transcoding is not fast enough, it is not fluid and stucks every few second... is there any way to speed-up this?
Reno
Post Sat Feb 09, 2013 1:23 am
Hello. Thank you for this guide! :mrgreen:
I've some problems. :cry:
I've followed the guide step by step.
STEP 1: OK
STEP 2: OK
STEP 3: OK
STEP 4: I'VE INSTALLED JAVA 7 update 10 (file name ejre-7u10-fcs-b18-linux-arm-sflt-headless-28_nov_2012.tar.gz) (NAS-Tweak site use 7 update 6)
STEP 5: here the problems...
for edit serviiod.sh file i've used windows notepad starting from a empty file, copy pasted the code, then copied to the NAS, in the correct "folder" (/ffp/start/), it's ok? "touch serviiod.sh" is only for create an empty file?
then for edit the /ffp/opt/serviio/bin/serviio.sh i've done same thing, copied the file to windows notepad, edited and saved, then sended back to nas...
you said "find the line beginning "JAVA_OPTS" and change to" but in my file serviio.sh there is not lines like a script, if i see the file in notepad is only two long lines, not formatted, is correct?
the final/main problem is when i start serviio with "sh /ffp/start/serviiod.sh start" command. I've got problems on lines 2, 4 and 9, all blank lines...
root@NAS:/ffp/start# sh /ffp/start/serviiod.sh start
: command not found.sh: line 2:
: command not found.sh: line 4:
: command not found.sh: line 9:
: numeric argument requirede 10: exit: 0
then if i check if java process is running (ps -ef | grep serviio)
i get this:
root@NAS:/ffp/start# ps -ef | grep serviio
root 7441 3605 0 01:18 pts/0 00:00:00 grep serviio
and if i try to stop serviio i will get same error:
root@NAS:/ffp/start# sh /ffp/start/serviiod.sh stop
THANKS FOR HELP ME :)
barmalej
Post Sat Feb 09, 2013 8:44 pm
You can't edit or create linux script files with windows editor. Typical mistake and it's related with your errors. You can use nano or vim or Midnight's Commander internal editor with FFP 0.7 on your box. On windows platform, notepad++ can do the job.
Reno
Post Sun Feb 10, 2013 5:54 pm
Solved with WinSPC thanks.
Mister XY
Post Thu Feb 21, 2013 7:13 am
Thx for the godd tuturial.
I have installed Serviio on my NSA 310 and it running but is it possible to watch content from online sources via video stream?
I put the plugin into the plugin folder and at the adress under online sources. From PC it's running perfekt but from NSA, there come only the file "refresh in ....".
Is it not possible to wathc from online sources like ilive and sky?
bmn
Post Mon Mar 04, 2013 12:46 am
Works like a charm, even on my NSA-310. Now I can see subtitles where Twonky failed. Thanks a lot for this very good tutorial!
As Reno stated, the Java file has changed to a newer version (as well as serviio). The changes in the tutorial can be guessed :)
If you want to install serviio on a NSA-310, the last step in section 5 should be changed to 256M instead of 384M
"$JAVA" -Xmx256M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
due to less RAM in the NSA-310.
Press
Post Fri Mar 15, 2013 9:04 pm
Hi
I have installed Serviio 1.1 on my Nas but when i try to transcode a video (.avi) it plays for 5 seconds then stops for 5 seconds. I have looked at the cpu usage using ‘top’ and found that there are 2 instances of ffmpeg taking 90% of the cpu usage. I am using a Sony TV (2011).
:geek:
Happy_Highlander
Post Tue Mar 19, 2013 10:14 pm
I have installed serviio onto my nsa 325 everything appeared to go well but sony bravia can't access server and serviio console won't start up saying serviio isn't running. Serviio also won't autostart when rebooting nas and has to be started from telnet command line. Strange thing is serviidroid picks it up on autoscan and allows me to configure shared folders and updates them. I know I must have missed something stupid but can't see the wood for the trees. I used vi to edit files in telnet. Here is the output after starting serviio for command line.
/ffp/start/serviiod.sh: line 1: cript: command not found
Starting Serviio
OK
Any help would be much appreciated
H_H
Edit just an update I chopped down some trees and found the wood when copy and pasting the startup script the first line was missing completely and half of the second as well so a quick edit sorted it out bravia now sees and plays files but is very choppy on 2010 profile. I'll try it on 2011 profile and see if my problematic files play with their embeded audio shenanigens...If there is any subtle transcoding to remove the above said audio nonsence It would be a great help
pony_wong
Post Fri Mar 22, 2013 11:37 pm
Anyone tried this guide for Servio 1.2? I have my Zyxel 325 working fine with 1.1 but not having subtitles is big drawback.
tmcatalin
Post Sat Mar 23, 2013 6:00 pm
sorry for stupid question, but i am a newbie:(
where exactly should be introduced "$JAVA" -Xmx384M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@" ?
i tried in serviio.sh, but isn't working.
thanks
Mister XY
Post Sun Mar 24, 2013 4:27 pm
before "$JAVA" -Xmx512M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
after "$JAVA" -Xmx384M -Xms20M -XX:+UseParNewGC -XX:MinHeapFreeRatio=10 -XX:MaxHeapFreeRatio=20 $JAVA_OPTS -classpath "$SERVIIO_CLASS_PATH" org.serviio.MediaServer "$@"
tmcatalin
Post Sun Mar 24, 2013 6:20 pm
Thanks for clarification, but I already read the entire post few times before...
If i would find a line where i would have the code i would change it!
But according to the initial post in the code of serviio.sh is no such line.
Consequently i tried to introduce it in serviio.sh but didn't work. i wrote the post in the idea maybe i am supposed to change/introduce in another place...
Thanks anyway
Mister XY
Post Sun Mar 24, 2013 7:23 pm
have you look in the /ffp/opt/serviio/bin/serviio.sh file or in the /ffp/start/serviiod.sh file?
you must look in the /ffp/opt/serviio/bin/serviio.sh file. when i download the linux file and extract it, i see the serviio.sh file and the last line is the line.
i think, you have look in the wrong file.
