problem by streaming pc desktop to tv using serviio
ferko
Post Tue Jan 08, 2013 5:08 pm
I wanted to connect my laptop to tv using it as second monitor. I have made all the things written in the article "How to Stream Your Windows PC Desktop" (http://wiki.serviio.org/doku.php?id=stream_pc) in my toshiba laptop (Windows 7), however the tv (Samsung C650) screen displays only tilted color lines, what one could adjust easy on old tv sets. But how to change the image frequency now. The audio transfer is OK.
Please help me. Many thanks in advance.
Post Tue Jan 08, 2013 5:41 pm
Re: problem by streaming pc desktop to tv using serviio
If you want it for resonable work as a second screen, then give up. You'll get a few seconds delay on the stream.
ferko
Post Sat Feb 02, 2013 3:05 pm
I have tested the method written in the General Discussion by DLNAhooray on Tue Jan 24, 2012 6:08 pm, that is I streamed the desktop to the screen of a second VLC on the same desktop. I did not receive a normal image of the desktop but tilted strips, similar to those on the Samsung. I think this means that the error is in the bat file or in the scr 0.9.0 or scr 0.8.7 (I tested both). Have you any idea what is wrong?
ferko
Post Sat Feb 02, 2013 5:48 pm
Use the method in the wiki.
