serviidb.com
Xmantium
Post Tue Jan 29, 2013 4:45 pm
Re: serviidb.com
moltra wrote:Plugins can be downloaded from serviidb via the API, I can setup a download page so that users can download multiple plugins at the same time from one page.
Possibly add an extra column to her with checkboxes to here - http://www.serviidb.com/plugins
User checks and downloads the selected plugins in a zip file
Its nice to see https://bitbucket.org/xnejp03/serviio/i ... to-serviio going to be added to Serviio 1.3
Users on the website or forum then can add links without 3rd party apps
Post Tue Jan 29, 2013 4:59 pm
Re: serviidb.com
I am not sure if it will be zip format or each groovy file. Groovy files would be easier on the end user.
The link ability sounds great
That
Xmantium
Post Sat Feb 02, 2013 11:38 pm
Re: serviidb.com
Ive noticed a message on serviidb since you added Cloudflare
Cloudflare is not passing $_SERVER["HTTP_CF_CONNECTING_IP"], make sure to enable it and to configure your webserver to take variables.
The icons of the plugins dont show up the table of contents
Post Sun Feb 03, 2013 1:07 am
Re: serviidb.com
Xmantium wrote:Ive noticed a message on serviidb since you added Cloudflare
I changed the code so you should not be getting the message any more.
I do not understand what you mean about the icons.
Xmantium
Post Sun Feb 03, 2013 1:14 am
Re: serviidb.com
Sorry i mean the Table corresponding to the plugin
So when i click the iplayer icon, it shows the table of iplayer items in table like it was on the main original page
Post Sun Feb 03, 2013 1:38 am
Re: serviidb.com
Xmantium wrote:Sorry i mean the Table corresponding to the plugin
yes that is how I have it setup, do you think it should point to the plugin itself?
There is a link to the plugin itself right below the logo.
Xmantium
Post Sun Feb 03, 2013 3:23 am
Re: serviidb.com
Must be late and im getting things even confused...
Currently when you click on HDTrailers icon on the home page it goes to this page - http://www.serviidb.com/plugin-api-name/hdtrailers
Rather having this content in blog format, can we have the HDTrailers table list instead (like it was last week on the home page)
Xmantium
Post Sun Feb 03, 2013 7:20 pm
Re: serviidb.com
Thanks Mark, exactly what im looking for :)
Also now its in table format, can it display all the contents please rather than limiting to ten items
Would be cool if some information about the plugin before the table
Ideally:
Title
Plugin Description
Current Plugin version
Maybe link to downdoal plugin
Then the table of content of HD trailers
Post Mon Feb 18, 2013 8:47 pm
Re: serviidb.com
Any eta when the new extra plugin data will be available via the the normal /api/plugin endpoint?
One thing that would be nice is the number of sources associated with a plugin, as well as being able to get a list of sources basd on plugin id, rather than searching with plugin title.
@Xmantium The 4oD plugin API name is wrong (the others may also be), could you update them at some point?
Post Mon Feb 18, 2013 9:26 pm
Re: serviidb.com
Check out http://serviidb.com/apidev/plugin
I thought I sent out a request for a review on it. I can transfer it over to the production API tonight.
Post Mon Feb 18, 2013 9:53 pm
Re: serviidb.com
Yes I've already seen it, but want to keep released versions of ServiiDroid on the /api endpoint, so yes please transfer the /apidev stuff over.
Post Mon Feb 18, 2013 10:10 pm
Re: serviidb.com
Will transfer it tonight
Post Mon Feb 18, 2013 10:18 pm
Re: serviidb.com
thanks
Post Mon Feb 18, 2013 10:40 pm
Re: serviidb.com
Did you verify that all the original fields are the same?
Xmantium
Post Mon Feb 18, 2013 11:47 pm
Re: serviidb.com
will wrote:@Xmantium The 4oD plugin API name is wrong (the others may also be), could you update them at some point?
Been updated ;)
Shame this once great plugin is now broken
Post Tue Feb 19, 2013 11:04 am
Re: serviidb.com
plugin data updated in api
Post Wed Feb 20, 2013 4:41 pm
Re: serviidb.com
Thanks for transfering the data, I now have an Acitivty in ServiiDroid that displays a grid of plugins and their logos grouped by plugin type, then user will then be able to see the details for that plugin and associated online sources.
Some comments on the API so far:
Duplicated fields:
*pluginNid and nid (one should be removed)
*pluginName, plugin, pluginAPIName (pluginName or plugin should be removed)
Default data:
*pluginLogo: Some plugins don't have a logo (@xmantium, can you fix that :)), so pluginLogo should be null, not 'http://serviidb.com/sites/default/files/'
Duplicated plugins:
ABC & ABC Family appears twice under TV on Demand
TurboTV appears under Sports and under no type.
Image caching:
Do you want me to cache images on the device's sd card for short/medium periods of time? (I'm not doing it at the moment, instead I'm just building an in memory cache)
Post Wed Feb 20, 2013 4:49 pm
Re: serviidb.com
I left the other info in until everyone had a chance to update to the new field names.
New items should default to the serviidb icon. I can update the old ones. If any one has a good icon for default let me know.
I would just pull the icon again or give the user the option. Depends on device memory if it should be cached or not.
Post Wed Feb 20, 2013 5:04 pm
Re: serviidb.com
OK, which ones are you planning on removing?
I think it is better to have it null rather than a default, that way the apps can provide one locally (could all be the same icon mind).
The no plugin required and coolsport is a bit ugly as well, not sure of an alternative.
I can implement device caching, but it is a bit of work. My main concern was not load time for users but extra bandwidth requirements for you.
Post Wed Feb 20, 2013 6:36 pm
Re: serviidb.com
The plugin name for 4oD sources (and proably all) have changed to the pluginApiName field. It is supposed to be linked to the pluginTitle field.
