Mac and PC
Topoftower
Post Sun Feb 03, 2013 8:22 am
Mac and PC
I have an external drive connected to my mac loaded with my movies, shows, etc. that in turn is then viewed through my Panasonic tv using serviio. I now want to copy all my files onto a separate drive and give to friends who use a pc and have serviio loaded. Question is is it possible or will the pc not read those files that are copied from the mac. Serviio working very well I might add and happy with the service.
slyguy42o
Post Mon Feb 04, 2013 5:55 am
Re: Mac and PC
as long as you format the external drive in either the fat32 or ntfs format, windows will read it fine.
Topoftower
Post Sun Feb 10, 2013 12:30 pm
Re: Mac and PC
Many thanks. Posting new question so hoping for same outcome.
Return to General discussion
