Transcoding for Web Media Browser
Firstly, what format does serviio transcode files to to stream on the media browser?
Secondly if I was to convert my files to this format will serviio still transcode them or stream them straight off?
spudy12 wrote:Hi, 2 quesitions
spudy12 wrote:Secondly if I was to convert my files to this format will serviio still transcode them or stream them straight off?
will wrote:I believe alwaysEnableTranscosing means to ignore the on/off under the Transcoding tab, if the file doesn't actually need transcoding it won't be (although it this case the file will be remuxed to enable time based seeking which MediaBrowser uses)
