Can't start Serviio on Ubuntu 12.04 server
AliBrown
Post Mon Feb 04, 2013 10:11 am
I am really struggling to get Serviio to work on my Ubuntu 12.04 server.
I installed all the pre-dependencies for ffmpeg from https://ffmpeg.org/trac/ffmpeg/wiki/UbuntuCompilationGuide and then downloaded and installed the latest Serviio install from the Serviio site.
The problem is, I just can't get it to start.
When I type
sudo start serviio
I get
serviio start/running, process 3183
, or something similar.
But when I check the status a couple of seconds later with
sudo status serviio
It gives me
serviio stop/waiting
This is really frustrating as I have had it working on 12.04 in the past before my old server died.
I can't post a log file, since the server doesn't start at all and therefore doesn't generate a log.
Here are the versions that I am running:
ali@MainServer:~/Serviio/serviio-1.1$ java -version
java version "1.7.0_09"
OpenJDK Runtime Environment (IcedTea7 2.3.4) (7u9-2.3.4-0ubuntu1.12.04.1)
OpenJDK Client VM (build 23.2-b09, mixed mode, sharing)
ali@MainServer:~/Serviio/serviio-1.1$ ffmpeg
ffmpeg version 0.8.5-4:0.8.5-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
  built on Jan 24 2013 18:03:14 with gcc 4.6.3
Use -h to get full help or, even better, run 'man ffmpeg'
Any help?
i-matrixx
Post Mon Feb 04, 2013 1:27 pm
Re: Can't start Serviio on Ubuntu 12.04 server
this isn´t much information you have provided.
One thing I have noticed is that the output you have posted from ffmpeg is definitively not from your own compiled ffmpeg. This is the output from ffmpeg shipped from the official Ubuntu repositories. But that doesn´t explain why the server isn´t starting up at all.
Have you tried starting the provided serviio.sh?
Regards,
Ingo
AliBrown
Post Mon Feb 04, 2013 3:17 pm
Here is what I get running ./serviio.sh in the bin folder....
ali@MainServer:~/Serviio/serviio-1.1/bin$ ./serviio.sh
log4j:ERROR setFile(null,true) call failed.
java.io.FileNotFoundException: /home/ali/Serviio/serviio-1.1/log/serviio.log (No such file or directory)
   at java.io.FileOutputStream.open(Native Method)
   at java.io.FileOutputStream.<init>(FileOutputStream.java:212)
   at java.io.FileOutputStream.<init>(FileOutputStream.java:136)
   at org.apache.log4j.FileAppender.setFile(FileAppender.java:294)
   at org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:207)
   at org.apache.log4j.FileAppender.activateOptions(FileAppender.java:165)
   at org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:307)
   at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.java:295)
   at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:176)
   at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfigurator.java:191)
   at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOMConfigurator.java:523)
   at org.apache.log4j.xml.DOMConfigurator.parseRoot(DOMConfigurator.java:492)
   at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:1001)
   at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:867)
   at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:773)
   at org.apache.log4j.helpers.OptionConverter.selectAndConfigure(OptionConverter.java:483)
   at org.apache.log4j.LogManager.<clinit>(LogManager.java:127)
   at org.slf4j.impl.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:73)
   at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:242)
   at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:254)
   at org.serviio.MediaServer.<clinit>(MediaServer.java:66)
Mon Feb 04 16:16:48 CET 2013 Thread[main,5,main] java.io.FileNotFoundException: /home/ali/Serviio/serviio-1.1/library/../log/derby.log (No such file or directory)
Mon Feb 04 16:16:49 CET 2013 Thread[main,5,main] Cleanup action starting
ERROR XBM0H: Directory /home/ali/Serviio/serviio-1.1/library/db cannot be created.
   at org.apache.derby.impl.services.monitor.StorageFactoryService$9.run(Unknown Source)
   at org.apache.derby.impl.services.monitor.StorageFactoryService.createServiceRoot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.createPersistentService(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.createPersistentService(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.createDatabase(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection30.<init>(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection40.<init>(Unknown Source)
   at org.apache.derby.jdbc.Driver40.getNewEmbedConnection(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
   at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
   at java.sql.DriverManager.getConnection(DriverManager.java:579)
   at java.sql.DriverManager.getConnection(DriverManager.java:243)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
   at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:57)
   at org.serviio.MediaServer.main(MediaServer.java:110)
Cleanup action completed
java.sql.SQLException: Failed to create database 'db', see the next exception for details.
   at org.apache.derby.impl.jdbc.Util.newEmbedSQLException(Unknown Source)
Caused by: java.sql.SQLException: Failed to create database 'db', see the next exception for details.
   ... 20 more
Caused by: java.sql.SQLException: Directory /home/ali/Serviio/serviio-1.1/library/db cannot be created.
   ... 17 more
Caused by: ERROR XBM0H: Directory /home/ali/Serviio/serviio-1.1/library/db cannot be created.
   ... 17 more
============= begin nested exception, level (1) ===========
   ... 22 more
   ... 17 more
============= end nested exception, level (1) ===========
============= begin nested exception, level (2) ===========
   ... 17 more
============= end nested exception, level (2) ===========
============= begin nested exception, level (3) ===========
============= end nested exception, level (3) ===========
Post Mon Feb 04, 2013 4:58 pm
is your serviio folder writable?
AliBrown
Post Mon Feb 04, 2013 4:59 pm
Yes, owned by root, but with 775 rights.
khurram23
Post Tue Feb 05, 2013 1:58 am
Post the output of following commands.
in /home/ali
ls -al | grep Serviio
and
 ls -al Serviio
Seems like you are trying to run serviio.sh as user "ali" when the dir is owned by root.
Confirm the above, then try :
chown -hR ali Serviio
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
AliBrown
Post Tue Feb 05, 2013 7:13 am
Here is the current state...
ali@MainServer:~$ ls -al | grep Serviio
drwxrwxrwx  8 root root  4096 Jan 28 11:20 Serviio
ali@MainServer:~$ ls -al  Serviio
total 32
drwxrwxrwx  8 root root 4096 Jan 28 11:20 .
drwxr-xr-x 30 ali  ali  4096 Jan 29 15:30 ..
drwxrwxr-x 14 root root 4096 Jan 28 11:15 fdk-aac
drwxrwxr-x 17 root root 4096 Jan 28 10:44 ffmpeg
drwxrwxr-x 16 root root 4096 Jan 28 09:57 libvpx
drwxrwxr-x  8 root root 4096 Dec 19 17:05 serviio-1.1
drwxrwxr-x 11 root root 4096 Jan 28 08:50 x264
drwxrwxr-x 11 root root 4096 Jan 28 08:41 yasm-1.2.0
So I changed the owner to me....
ali@MainServer:~$ sudo chown -hR ali:ali Serviio
total 32
drwxrwxrwx  8 ali ali 4096 Jan 28 11:20 .
drwxrwxr-x 14 ali ali 4096 Jan 28 11:15 fdk-aac
drwxrwxr-x 17 ali ali 4096 Jan 28 10:44 ffmpeg
drwxrwxr-x 16 ali ali 4096 Jan 28 09:57 libvpx
drwxrwxr-x  8 ali ali 4096 Dec 19 17:05 serviio-1.1
drwxrwxr-x 11 ali ali 4096 Jan 28 08:50 x264
drwxrwxr-x 11 ali ali 4096 Jan 28 08:41 yasm-1.2.0
Then I tried again...
ali@MainServer:~$ sudo start serviio
serviio start/running, process 25504
ali@MainServer:~$ sudo status serviio
Still doesn't start properly. Hmmmm. :?
AliBrown
Post Tue Feb 05, 2013 9:49 am
Right, I just removed all the packages (ffmpeg, x264, etc) and Serviio. I did a clean install of all the packages using http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux and then downloaded and installed the serviio package again.
Yet I still get the same problem!
ali@MainServer:~/Serviio/serviio-1.1$ sudo start serviio
serviio start/running, process 2558
...wait 2-3 seconds...
ali@MainServer:~/Serviio/serviio-1.1$ sudo status serviio
So still no success, but at least now I can generate a log file....
2013-02-05 10:37:19,005 INFO  [MediaServer] ------------------------------------------------------------------------
2013-02-05 10:37:19,009 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-02-05 10:37:19,009 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-02-05 10:37:19,009 INFO  [MediaServer] http://www.serviio.org
2013-02-05 10:37:19,009 INFO  [MediaServer] Java 1.7.0_09-Oracle Corporation
2013-02-05 10:37:19,009 INFO  [MediaServer] OS Linux i386 3.2.0-37-generic-pae
2013-02-05 10:37:19,010 INFO  [MediaServer] File encoding: UTF-8
2013-02-05 10:37:19,012 INFO  [MediaServer] Headless mode enabled: true
2013-02-05 10:37:19,012 INFO  [MediaServer] User: ali
2013-02-05 10:37:19,012 INFO  [MediaServer] User home dir: /home/ali
2013-02-05 10:37:19,012 INFO  [MediaServer] Temp dir: /tmp
2013-02-05 10:37:19,012 INFO  [MediaServer] ------------------------------------------------------------------------
2013-02-05 10:37:19,499 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-02-05 10:37:19,506 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-02-05 10:37:19,628 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-02-05 10:37:19,629 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-02-05 10:37:19,686 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-02-05 10:37:30,590 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2013-02-05 10:37:51,371 INFO  [DBSchemaUpdateExecutor] Cleaning persistent cache
2013-02-05 10:37:51,805 INFO  [Device] Created UPnP Device with UUID: c7f54680-913f-3be8-b5d4-96fd42c5998e, bound address: 192.168.5.10
2013-02-05 10:37:51,839 WARN  [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2013-02-05 10:37:52,073 INFO  [prefs] Created user preferences directory.
2013-02-05 10:37:52,310 INFO  [MediaServer] ------------------------------------------------------------------------
2013-02-05 10:37:52,310 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-02-05 10:37:53,031 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-02-05 10:37:55,035 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-02-05 10:37:56,479 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-02-05 10:37:57,273 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-02-05 10:37:58,491 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-02-05 10:37:59,245 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-02-05 10:37:59,797 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-02-05 10:38:01,612 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-02-05 10:38:01,720 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-02-05 10:38:04,405 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-02-05 10:38:07,286 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-02-05 10:38:08,506 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-02-05 10:38:09,207 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-02-05 10:38:09,331 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-02-05 10:38:09,907 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-02-05 10:38:10,127 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-02-05 10:38:11,189 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-02-05 10:38:11,825 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-02-05 10:38:12,885 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-02-05 10:38:14,106 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-02-05 10:38:14,576 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-02-05 10:38:14,799 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-02-05 10:38:16,929 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-02-05 10:38:17,246 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-02-05 10:38:17,546 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-02-05 10:38:17,979 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-02-05 10:38:18,622 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-02-05 10:38:19,264 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-02-05 10:38:19,617 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-02-05 10:38:19,678 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-02-05 10:38:20,606 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-02-05 10:38:21,235 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-02-05 10:38:21,716 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-02-05 10:38:21,755 INFO  [PluginCompilerThread] Looking for plugins at /home/ali/Serviio/serviio-1.1/plugins
2013-02-05 10:38:21,756 INFO  [PluginCompilerThread] Started looking for plugins
2013-02-05 10:38:21,760 INFO  [UpdateChecker] Checking if a new version is available
2013-02-05 10:38:22,416 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "dcraw": error=2, No such file or directory
2013-02-05 10:38:22,416 WARN  [MediaServer] DCRAW not found. Support for raw image files will be missing.
2013-02-05 10:38:22,445 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-02-05 10:38:22,546 INFO  [WebServer] WebServer starting on port 8895
2013-02-05 10:38:22,572 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-02-05 10:38:22,573 INFO  [EventDispatcher] Starting EventDispatcher
2013-02-05 10:38:22,574 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-02-05 10:38:22,582 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth0 (eth0) and address 192.168.5.10, timeout = 0
2013-02-05 10:38:22,588 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-02-05 10:38:22,589 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-02-05 10:38:22,758 INFO  [RendererManager] Stored a new renderer: uuid='cc5b7c5a-43ab-4afc-9dfd-63c1559c6556', name = 'Unrecognized device', ipAddress='192.168.5.10', profile = '1'
2013-02-05 10:38:23,011 INFO  [RendererManager] Stored a new renderer: uuid='1d704d06-6c13-4264-b979-8060746c9675', name = 'Unrecognized device', ipAddress='192.168.5.12', profile = '1'
2013-02-05 10:38:48,667 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-02-05 10:38:48,681 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-02-05 10:38:48,714 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-02-05 10:38:48,718 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-02-05 10:39:52,002 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2013-02-05 10:39:52,002 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-02-05 10:39:52,002 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2013-02-05 10:39:52,101 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-02-05 10:39:52,201 INFO  [FeedUpdaterThread] Finished looking for online resources information
2013-02-05 10:39:52,302 INFO  [PluginCompilerThread] Finished looking for plugins
2013-02-05 10:39:52,406 INFO  [WebServer] WebServer shutting down
2013-02-05 10:39:52,406 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-02-05 10:39:52,407 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-02-05 10:39:52,407 INFO  [EventDispatcher] Leaving EventDispatcher
2013-02-05 10:39:52,408 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-02-05 10:39:52,461 INFO  [DatabaseManager] Shutting down database
2013-02-05 10:39:52,592 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-02-05 10:39:54,901 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Seems like a problem with DCRAW???
Post Tue Feb 05, 2013 10:36 am
you don't need dcraw, it'll run without it
it looks like the server starts, but then stops after 1 minute
I've seen this before, but don't remember what the solution was, possibly a different Java version.
Could you enable detailed log ? It might help further analyse it.
AliBrown
Post Tue Feb 05, 2013 11:28 am
I can get it running now with
./serviio.sh
but not with
sudo start serviio
Not ideal, since this seems to lock up my terminal (i.e. I can't close it without killing the serviio process).
Ideally I want to be able to use the start/stop/status commands, but mainly just have it start on boot. Any suggestions?
AliBrown
Post Tue Feb 05, 2013 1:13 pm
Fixed! (so far...).
I updated my serviio.conf file to include the line
expect daemon
(thanks to another thread)
It now reads
start on (started networking
       or started network-manager
       or started network-interface)
expect daemon
script
  /usr/local/bin/serviio-1.1/bin/serviio.sh
end script
and all works fine!
AliBrown
Post Tue Feb 05, 2013 1:45 pm
Spoke to soon! I just did a reboot of my server...
I couldn't see the Serviio server on any DLNA receivers, so I checked the status.
ali@MainServer:~/Serviio/serviio-1.1/bin$ sudo status serviio
serviio start/running, process 586
But when I tried to open a console I got the: "Cannot connect to Serviio server, it does not seem to be running. Exiting..." message.
When I try to stop the server with
sudo stop serviio
it just hangs.
Still puzzled! :?
khurram23
Post Tue Feb 05, 2013 8:40 pm
Seems like permissions issue.
Review your syslog. Look in your /var/log folder
can you start the server up using
./serviio.sh &
Don't terminate your shell, it'll probably kill the server. leave the shell open (it'll be free'd up when you use &), just don't exit.
Rex
Post Fri Mar 29, 2013 4:22 pm
Hi
Hope you don't mind my posting but I am suffering the same peoblem. When I type ./serviio.sh & in term it comes back with "No such file or directory"
I followed the install instructions as per Serviio Ubuntu 12.04 Installation Guide and added both Serviilo and Serviio Console in the Startup programmes. I've even installed ver 1.2.1 but still no success.
I also tried to terminate the programme but again it sad no such program exists but they are there in
/home/kXXX/servio-1.2.1/bin/serviio.sh
Any help I would be extremely grateful.
Rex
PS Go gently I'm an "Old" Newbie
Post Fri Mar 29, 2013 4:28 pm
is serviio.sh executable? (ie does it have the 'x' flag when you do ls -al in the bin folder?)
Rex
Post Fri Mar 29, 2013 5:09 pm
Hi
If I right click on the file - serviio.sh - properties - permissions - There is a box which is labelled Execute: "Allow excuting file as program" and the box is ticked.
Is that the same thing?
Rex
Post Sat Mar 30, 2013 9:51 am
I have just tried this and it would seem it's java causing the problem.
kitty@kitty-Inspiron-1000:~$ cd /home/kitty/serviio-1.2.1/bin
kitty@kitty-Inspiron-1000:~/serviio-1.2.1/bin$ chmod +x serviio.sh
kitty@kitty-Inspiron-1000:~/serviio-1.2.1/bin$ ./serviio.sh
./serviio.sh: 67: ./serviio.sh: java: not found
Any ideas?
Rex
(It's my wifes laptop i'm installing it on!!)
Rex
Post Sat Mar 30, 2013 10:36 am
Cracked it!!
Didn't have java installed!!
Rex
Users browsing this forum: No registered users and 53 guests
