[SOLVED] KDL46HX853 and Humax .ts playback
aebailey
Post Sun Feb 03, 2013 9:39 pm
Hi all,
I am trying to use serviio to stream .ts files from my PC or Humax Fox HDR T2 to my sony TV (KDL46HX853). I have ensured the files are decrypted and can play them back on my PC or via my android tablets DLNA. When trying to play back via serviio on my tv, the files are detected, but the playback just gives me a black screen. I am using the standard Sony Bravia TV (2012) profile. Please can anyone give me some suggestions on how I might resolve this?
(PS. This is my first post on the forums, if I screwed up let me know and I'll try better next time :-) )
I have pasted the ffmpeg and mediainfo details for the tets file on my pc below:
The ffmpeg output shows:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Users\Home\Downloads\Doctor Who_2
0121225_1714.ts"
g-config
[aac_latm @ 033E7540] initializing latmctx
[h264 @ 033E12C0] non-existing SPS 0 referenced in buffering period
[h264 @ 033E12C0] non-existing PPS referenced
[h264 @ 033E12C0] non-existing PPS 0 referenced
[h264 @ 033E12C0] decode_slice_header error
[h264 @ 033E12C0] no frame!
[aac_latm @ 0340AE80] initializing latmctx
[h264 @ 033E12C0] mmco: unref short failure
Last message repeated 2 times
[mpegts @ 003EC3E0] Stream #3: not enough frames to estimate rate; consider incr
easing probesize
[mpegts @ 003EC3E0] Stream #4: not enough frames to estimate rate; consider incr
easing probesize
[mpegts @ 003EC3E0] Stream #5: not enough frames to estimate rate; consider incr
easing probesize
[mpegts @ 003EC3E0] Stream #6: not enough frames to estimate rate; consider incr
easing probesize
[mpegts @ 003EC3E0] Could not find codec parameters (Unknown: none ([5][0][0][0]
/ 0x0005))
[mpegts @ 003EC3E0] Could not find codec parameters (Unknown: none ([11][0][0][0
] / 0x000B))
Last message repeated 1 times
[NULL @ 03417940] start time is not set in estimate_timings_from_pts
[NULL @ 0341D9E0] start time is not set in estimate_timings_from_pts
[NULL @ 03423A80] start time is not set in estimate_timings_from_pts
[mpegts @ 003EC3E0] PES packet size mismatch
Input #0, mpegts, from 'C:\Users\Home\Downloads\Doctor Who_20121225_1714.ts':
Duration: 01:01:40.80, start: 76923.808578, bitrate: 7256 kb/s
Program 17472
service_name : BBC HD
service_provider:
Program 17540
service_name : BBC One HD
service_provider:
Stream #0:0[0x19c9]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1
920x1080 [SAR 1:1 DAR 16:9], 26.55 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x19ca](eng): Audio: aac_latm ([17][0][0][0] / 0x0011), 48000 Hz
, 5.1, s16
Stream #0:2[0x19ce](eng): Audio: aac_latm ([17][0][0][0] / 0x0011), 48000 Hz
, stereo, s16 (visual impaired)
Stream #0:3[0x19cd](eng): Subtitle: dvb_subtitle ([6][0][0][0] / 0x0006)
Stream #0:4[0x19fa]: Unknown: none ([5][0][0][0] / 0x0005)
Stream #0:5[0x19d2]: Unknown: none ([11][0][0][0] / 0x000B)
Stream #0:6[0x6f]: Unknown: none ([11][0][0][0] / 0x000B)
Program 17604
service_name : ITV1 HD
service_provider:
Program 17664
service_name : Channel 4 HD
service_provider:
Program 19648
service_name : 303
service_provider:
Program 20288
service_name : The Space
service_provider:
And the mediinfo details are:
Complete name : C:\Users\Home\Downloads\Doctor Who_20121225_1714.ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 3.13 GiB
Duration : 1h 1mn
Overall bit rate : 7 259 Kbps
Menu ID : 17540 (0x4484)
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=8, N=24
Codec ID : 27
Duration : 1h 1mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Color primaries : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AAC
Format profile : LC
Muxing mode : LATM
Codec ID : 17
Duration : 1h 1mn
Bit rate mode : Variable
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -555ms
Language : English
Audio #2
Format : AAC
Format profile : HE-AAC / LC
Muxing mode : LATM
Codec ID : 17
Duration : 1h 1mn
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 KHz / 24.0 KHz
Delay relative to video : -268ms
Language : English
Language, more info : Visual impaired commentary
Text
Format : DVB Subtitle
Codec ID : 6
Duration : 1h 1mn
Delay relative to video : 5s 452ms
Language : English
Menu
Duration : 1h 1mn
List : 6601 (0x19C9) (AVC) / 6602 (0x19CA) (AAC, English) / 6606 (0x19CE) (AAC, English) / 6605 (0x19CD) (DVB Subtitle, English) / 6650 (0x19FA) () / 6610 (0x19D2) () / 111 (0x6F) ()
Language : / English / English / English
Service name : BBC One HD
Service type : advanced codec HD digital television
UTC 2012-12-25 01:15:00 : en:Ù¶r9X / en:/ƒiÔ / ØöõcÅ>jz/D†ÐœÕöÿÞ“«ÍW¥vÝ¿W'¬Zç0­Á¿ñhûüýì^´Éb&ü+­5TY8wzà4‘Îu†Qº¯]wrP€‡¢äqQl°5z,à / movie/drama / / 01:25:00
UTC 2012-12-25 02:40:00 : en:÷ϯÿ€ / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2012-12-25 02:45:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 03:15:00 /
UTC 2012-12-25 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GTo›à²€õ<?tg¯ûki_a’y§ËÜ„¶É¼óÖڇ܀ / news/current affairs / / 03:00:00 /
UTC 2012-12-25 09:00:00 : en:’¯×rdà / en:_ +ÑÔõsÀÉeTçûÌêc¿÷jڍs´¿k4š²v+ëÇøãè ƒGß·%^™Æ¿ð¿C²ïlî¹£…¾‹¸¿V”)ZKŸ[~ì—±°ì»a,ûލÞ+¸ / show/game show / / 00:25:00 /
UTC 2012-12-25 09:25:00 : en:è-£`\œc&ÓÖ·ªqüš] / en:q˜c_¡ÚIÓ˜® ,[Ý=Eט_ýD†gs’m¦×WíYn‰úoÒZ€Û˜–¦¼nê¦X~SÞÉç7´2aoÝô>Èä{†©4ßAö Q¼V9p / children's/youth programmes / / 00:25:00 /
UTC 2012-12-25 09:50:00 : en:Árëì=€ / en:¢‘zpÂŒãè"ªV;.ûÍ / ì;p£,‡ U¿j̘åóDtÿ“n/ÃÝÛÝu>NGlïe¹%+%½tg‹Øû—·eÐY?o‡:uþº6p / movie/drama / / 00:10:00
UTC 2012-12-25 10:00:00 : en:§­oSnt³&­€ / en:å2Àg¯îœÅpIb1.ÌÝ–LSvíüsÚü<×f†¦­ïó«–*‚¿À[,£µ”©‚áÝŒÎØ*~Ꟗ¾EDz¸=—d÷’q¸÷ƒ­"õÖ Q¼Vp / news/current affairs / / 01:00:00 /
UTC 2012-12-25 11:00:00 : en:ýÖ / Õm¶PÀ / en:±tv±‡ ±óUÿÖÙrR\¯áÅ<á.G²m6~çsõ9òùà[RÿahäsÄÍÕû¶qÜj0Ó®ã>þ<…}7áØ/Êc¡ï¼\Ö;Sö-Êég / show/game show / / 01:05:00
UTC 2012-12-25 12:05:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬Ú`K»gŒì× / news/current affairs / / 00:10:00 /
UTC 2012-12-25 12:15:00 : en:ݪ|S–H5€ / en:jT;' +LCÕÚ\òÊÀÉ_¸4³$–¯½;DõñåÛcdr›ßÝ9Šà’à-Og®OIUí"£uWÜÊORìŽeêË8í¨ / ¹Žq›'µòMºÚs Q¼V9p / show/game show / / 00:25:00
UTC 2012-12-25 12:40:00 : en:ãz¿é;ž>—§u‡„ÆÜbဠ/ en:_ +¿“²åàK¹NI_É¿AÚI8aôë‚퍌~°}U|ÑëãÕcL€{$zk^­Äòzf¸Ÿ¦ý!=Ü\u1êÁ#ª7ŠÀÙýc— / movie/drama / / 01:20:00 /
UTC 2012-12-25 14:00:00 : en:-*§/èÒm=kzÀ / en:j3MÔÅu=f÷=6Zfsá\éÌW–#Ë‹n$'öÂ\ðÛQ‡i/12ŸütÞS’Í{Œkn»5î0ìö• ÷žž’°õÜ:sÁ$m·`‘ÕÅg / show/game show / / 01:00:00 /
UTC 2012-12-25 15:00:00 : en:M7< / en:°~K•tÉ_ù3îΜÅpIz¬ïÎÑ9-ªŒêzIÝ›¾#gç] Q¼Vp / news/current affairs / / 00:10:00 /
UTC 2012-12-25 15:10:00 : en:ݪ|_—FˆÚvè / en:_ (Î>Òç–^›è¹ù¯ü¬œçò”ÛÝsÌ÷J§‘M³TOÛêÿj³ÿN.ßâšr5¹ÝjŸ’yKW«Uw¨ã…¤˜ûv¿pifB{Çá÷°Hêâ°6©XåÀ / movie/drama / / 01:25:00 /
UTC 2012-12-25 16:35:00 : en:£pÖœ­øà€ / en:_ +ÑÔõsÀÒjÉØ¯¯ãÝŸ»æþ­¨Åwpvì- / d …ã:;' >ˆðyÓaî›Wr†P¥m6˾V¸ÏuН57î(FÁ#ª7ŠÇ. / movie/drama / / 00:25:00
UTC 2012-12-25 17:00:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬Ú`K»gŒì× / news/current affairs / / 00:15:00 /
UTC 2012-12-25 17:15:00 : en:s-`g / en:åkNwéŸíZ->6À / úŽœÅpIxõÕµ0‹§¤¾ÿ2‘Îó©$TÇ߇o¼;V…ùEÈ~KïÕ¡~ªÅmŽ.ðCÝS˳©ÇO×ëR—<ëðx¢·E‚GToŽ\ / user defined / / 01:00:00 / Running
UTC 2012-12-25 18:15:00 : en:ÞŒl̇%¶u™&ÓÖ·«Ñ‹ / en:ÅjR¦DÔidõ²Äy_zï=p>¬¶âBtæ+‚H¶âòÕ^Åòí¯¶ÖÌÎbý / show/game show / / 01:15:00 / Not running
UTC 2012-12-25 19:30:00 : en:ŽƒéÉø¹Ýÿ€ / en:‡1\V‹‰ æß•¦Z6Àæ$£Ÿl=>LéÌW™Ò­›çô{OPÜ¥Ü#ÆSÑã¾EÙzÑ9‘©I{t™–‘÷äõ2âJïÞ…Ù]í'^ªØ$uFñXåÀ / user defined / / 01:15:00 /
UTC 2012-12-25 20:45:00 : en:·¦½q±€ / en:äå / ø¤‚Î%õóÉI“ä˹ÿÜÃËÝ9Šà’ªzÕ#Vv_pÃ)p«ßµÕüñ–Ž9 îçËEÔ†ôÐ^‰}¶4ïÁì:£x¬rà / user defined / / 01:00:00
UTC 2012-12-25 21:45:00 : en:lÖ[ÂdÚzÖõz"±d / en:Â/,l b³(GðߨéÌW’¾Jαüµïô󈼲;_+§ösÍZ\à-$û×yÜCfˆõ<눏aȟѪ˜ Î|5ë÷­§‘wrP€‡¢õ×;>ëe‚GToŽ\ / show/game show / / 01:00:00 /
UTC 2012-12-25 22:45:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûklü°ýœ]¿Žw9Ù%ýlÿ¾vçËF@mêͦ»°Vvª3×þ3³\€ / news/current affairs / / 00:15:00 /
UTC 2012-12-25 23:00:00 : en:["o¹®¼ / en:}˜¿çUËäš5ÿ/ƒ¦uµ/É^¶8¿‘ž¿Ù¤aãÖÁ / show/game show / / 00:40:00 /
UTC 2012-12-25 23:40:00 : en:ýêm=kz±áì / en:äUJÇgNb¸$¿Žvè»WM~Wðæ5f0á!¦9Mgwž¡ŸøWîÖ]g8d¾(Ó]Ø+ ¸wcs¶ / Ÿ€º§å2Á#ª7ŠÎ / news/current affairs / / 00:05:00
UTC 2012-12-25 23:45:00 : en:|WG’7ËYg¡ÅsèEmß¶Ð / en:q˜xæ+‚JÑq!<Ëo©Òþ5¿ô / show/game show / / 00:45:00 /
UTC 2012-12-26 00:30:00 : en:ƒÓËÏ / en:8 / movie/drama / / 02:25:00 /
UTC 2012-12-26 02:55:00 : en:÷ϯÿ€ / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2012-12-26 03:00:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 03:00:00 /
UTC 2012-12-26 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GTo›à²€õ<?tg¯ûki_a’y§ËÜ„¶É¼óÖڇ܀ / news/current affairs / / 03:00:00 /
UTC 2012-12-26 09:00:00 : en:g§‰Îûœ / en:0¿ú+W'¤œÆ…/ª»ó¥f1õü›ûèê WÉyýjTsÝCÛb¯2ð÷[ûÇüÀ ¬É9ÎòTÍŸ-߯ñ=þ:o)®Ý6Ë›Çg^aô*E"Á#ª7ŠÇ. / children's/youth programmes / / 00:45:00 /
UTC 2012-12-26 09:45:00 : en:£pÖœ­øà€ / en:_ +ÑÔõsÀÒjÉØ¯¯ãÝŸ»æþ­¨Åwpvì- / d …ã:;' >ˆðyÓaî›Wr†P¥m6˾V¸ÏuН57î(FÁ#ª7ŠÇ. / movie/drama / / 00:25:00
UTC 2012-12-26 10:10:00 : en:ãz¿é;âgµRîÛY6žµ½IË@ / en:äÿðÍ / movie/drama / / 00:15:00 /
UTC 2012-12-26 10:25:00 : en:Cars / en:_ +¿“þAtÐ+cÚ ŒÊerAÙ\RgÏù–•ʁ?QŸÅ³‹¶YÖÃ`+ ¯~㎘ãJú¿ÛزxܥȒõ7ÇoéÿÿêTëލÞ+h«¸ / movie/drama / / 01:50:00 /
UTC 2012-12-26 12:15:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2012-12-26 12:30:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-26 12:40:00 : en:áÈþp / en:›öm€9mKéoQ£Ä ²—Jû·óGPvŸÿåÚ˜ó,½ôôÿÿõ)oŒi´O¿1N×Ïcúz½)&›Ó’zÛÆzÿ÷ 2Õê蔯šëލÞ+¸ / user defined / / 01:00:00 /
UTC 2012-12-26 13:40:00 : en:|[¿.›& / en:_ +¿“Ôÿášz™sx—ë:©/äÔ‹u¥–ߝ9~„êŸÕHBw%2Ýg(Om­ŸÓÿý§+-VxžæôŽñÍÿ·+±êÚOYìüãŽ2bÀÚ*Î / movie/drama / / 01:40:00 /
UTC 2012-12-26 15:20:00 : en:µtÍû / en:oIN¥_É¿²ebžíÙkÆu<œ0£8ð¼;V…ú}•¢ÊÀôi€X’ÙÕ¸^³¦Ü6ð}…ºM“ÛÚ/쇣GÜIËêaÔ´ VWœrÄ·B»Ù®°Hêâ°5XåÀ / movie/drama / / 01:40:00 /
UTC 2012-12-26 17:00:00 : en:y¥-fsÍí°4bûw / en:_ +u1ßû²¿“ÖŒ´=uÓ䍱œø%÷¼¬Ì© iŝ‡g6|úã Ù´·çOän$·¨£~ø_éÿÿêRà-D­.<³:^Ãoø / ±œøö Q¼V_ÕXåÀ / movie/drama / / 01:30:00
UTC 2012-12-26 18:30:00 : en:HçÕœø“0 / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:10:00 /
UTC 2012-12-26 18:40:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-26 18:50:00 : en:ÌáÞíc{v€ / en:oIN¦®xÙ,ªœÿy ÷P-캓! / œVž=ýÖ§ùó7‹ËÝkæcù9Žv’³AäÏSÒT­·3ÓײÒÕzoÉÅ»*E"îä¡Û¶á\ / ÀßiÕ²Á#ª7ŠÀëú«¸ / movie/drama / / 01:40:00
UTC 2012-12-26 20:30:00 : en:·¦½q±€ / en:ÞÚ-¯1ü‰7±¿<Gi#ÈùÔþ^å / ø¦éÌW™êŸËY/¸a”´ì×a›Ï%‡óÏ#çhÌéèL*qìF}ñš / user defined / / 00:30:00
UTC 2012-12-26 21:00:00 : en:ç†mC / en:°m/†øÜ¼íø¡Ô¦r¤o”ÓÜí/ÚÈw¡ùÍR§ü¯¿&\ó¯ÁËm9ýÁléÌW—^‹ÈÓV›gNX‹ôÛv÷B^·ä°”ôØz¸ÕêÇ’Á#ª7ŠÇ. / show/game show / / 00:30:00 /
UTC 2012-12-26 21:30:00 : en:áÌK}¼¦\šRm=kz½X² / en:3­Òûf$<7K{4|e7ýWû×Üô\G²[UF—•„ø Bµ4ÉÜ=<¬NI¥öÌHyªÝÜ” !è§}uÎÏÉâÆ1\Ÿ=Ó / Þ­– Q¼Vp / show/game show / / 00:30:00
UTC 2012-12-26 22:00:00 : en:HçÕœ˜ž / en:庭_µQž¿§»©Tg¯ûklü°ýœ]¿Žw9Ù%ýlÿ¾vçËF@mêͦ»°Vvª3×þ3³\€ / news/current affairs / / 00:20:00 /
UTC 2012-12-26 22:20:00 : en:‰Ç?SÏ´ÁÆäÁ)y\Ð / en:q˜îV4RŒõý½L^¯ Zç1Û]ól / §Þ»Ëf‘÷áõ?æçÝwÁe¨Þ¦)§¨ußsËùͰ*Åœ / show/game show / / 00:05:00
UTC 2012-12-26 22:25:00 : en:âòS–Ý€ / en:ÒšÛ––{v96é(š¼\o‹½‡i#fy½Ìý›ãÌʸ§à,xÏËÓ^Gôþ9ÃËó~+·ðÇSÀZ[Hgë´ñw7éÚÊ`öØ«Øç`0$.Þ“›‡u`‘ÕÅg / sports / / 01:35:00 /
UTC 2012-12-27 00:00:00 : en:Q·"‚>€ / en:y~´³‹¶LCÕÑ~ðŽþ¸źmytsÓZÿÉÓÔ¾µæ'έ¿AüsäÉïû2^¿v/ÑÙO3\„÷n¹Iq¦A™#0…ÝÉBŠw×\ìû­– Q¼V£+8 / movie/drama / / 01:25:00 /
UTC 2012-12-27 01:25:00 : en:÷ϯÿ€ / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2012-12-27 01:30:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 04:30:00 /
UTC 2012-12-27 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GTo›à²€õ<?tg¯ûki_a’y§ËÜ„¶É¼óÖڇ܀ / news/current affairs / / 02:00:00 /
UTC 2012-12-27 08:00:00 : en:âòS–Ý€ / en:ÒšÛ––{v96é(š¼\o‹½‡i#fy½Ìý›ãÌʸ§à,xÏËÓ^Gôþ9ÃËó~+·ðÇSÀZ[Hgë´ñw7éÚÊ`öØ«Øç`0$.Þ“›‡u`‘ÕÅg / sports / / 01:30:00 /
UTC 2012-12-27 09:30:00 : en:Sæ-B@ / en:…1ßû²¿“vy®í5}׍&F / U / \Žy î÷k;'¯ƒÊëƒ1Ùû¶s^÷íÍ>×]"ŸÉ—zgÿúëê÷jI¾6ÑVp / movie/drama / / 01:30:00
UTC 2012-12-27 11:00:00 : en:¹VÚØ.L / en:´t{x΃äþtv’ÅÊGJåTçûÝ “HºRýç×:j¿Â·gU¢ä]‹M,ý‹»ï]ûGƒQ#jKïÓmµ³"ÛýÖ¾¥è;ù£v#ê_ ²ÝpE‚GTo†{Uœ / movie/drama / / 01:40:00 /
UTC 2012-12-27 12:40:00 : en:HçÕœ¯¶ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:10:00 /
UTC 2012-12-27 12:50:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-27 13:00:00 : en:æ/Q“ië[ÕèŠÅ / en:ÓÔ5oRL~rÊñ\UÂø:d.œÅpIvdš¥ïí¨wÀ© ,búÓ-¸Ÿâg‘ÕzÓ&µ;zôkÒW”à»'9!Å âšàh¶p / show/game show / / 00:50:00 /
UTC 2012-12-27 13:50:00 : en:ݪ}Æ×+k©“øs5M / en:q˜xæ+‚N®…ª*7| ª•Éà / 3¿ã¦òœ–w‘¯yÇ=¥Ï,?Šû™]ñåΜÅpIe’¿B.>ü'À[Ýoëÿ°™Ödv²€õ? / ¯I"ü{û˜y}cÕœ / show/game show / / 00:10:00
UTC 2012-12-27 14:00:00 : en:Bolt / en:_ +¿“Ö‚ËqlTŽ—QJ׌évž˜sö¹45i¶tøsøW´g–E¤|õ±owyÏtº‹]Q·É|.ËÇ<‘z]Z¯KFÌ.*E"Á#ª7ŠÀÙýc— / movie/drama / / 01:25:00 /
UTC 2012-12-27 15:25:00 : en:å‘íˆV‚èÎùL / en:_ (Î<ŒwTkº;oêjY]ê÷ß2zæ7¨˜‹µþü3üÇø_ »¿fKÜ6Õ2òOi·û’ïcíð¯&½#çÁøŸ>?øÚr\ùhÆÁ#ª7ŠÀÚ¥c— / movie/drama / / 01:25:00 /
UTC 2012-12-27 16:50:00 : en:pÅöäZM|È"œãÃåðx / en:jT;' +zEÿã¦òžw‘¯yÇ;Zò'FKb~ÅsãÚíëHZr´”JÒãË.g²CI±¶3ŸøãÎlü²£v’ioΟ½µ·0¶p / show/game show / / 00:25:00 /
UTC 2012-12-27 17:15:00 : en:ô‚§m¶KøkK6Ûr½Œ / en:åõÔ¼v / öï9|É / Ré,WâžUa©FpŽ7ñjIíT4ÔÂ0zâ›ÇvWjb=à;`W½þ&\˯R^Ý{ÔßÂúöq‹º°Hêâ±Ë€ / show/game show / / 00:25:00
UTC 2012-12-27 17:40:00 : en:ïÿ4—‚x>0 / en:“‚Úá‰÷`!¸ÜŸ4õ™»Ë€¡&*>¾h+%…¢"¤QòeÅ·ùáÀgGi#”Å‚ðÉËT“·k(Soàkƒ"s¨úëÿË / show/game show / / 00:50:00 /
UTC 2012-12-27 18:30:00 : en:HçÕœø“0 / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2012-12-27 18:45:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:15:00 /
UTC 2012-12-27 19:00:00 : en:‹Á<(m=¥ƒ  / en:°nøºŸ1~ƒIÊbÁÀ7笝X³©³¯güäy5"µ[ë+ËÚušÓü¼¥AóòKúÙÿ|öáe0Ñ.Êß'³XÆçhÍ#ü5ìÛ7$5Oc”•ÁüsÒÕzV¿958°Hêâ³€ / show/game show / / 00:30:00 /
UTC 2012-12-27 19:30:00 : en:|WG’7ÌúAÛo / en:°Òà92tÕÑÚIí0TvÚÚ9LX.÷Q:½\¯’¯óÛ[Cµ‡®ëŽŒÃåˆ2„<KÃyWËðªµËrғˁƒ=úGkŒ•úˆ»'ŸŽò5w Q¼Vp / show/game show / / 00:30:00 /
UTC 2012-12-27 20:00:00 : en:·¦½q±€ / en:ÿáüàÉÈ„•ÁªêñnÌ“”7âž¡Ü? / user defined / / 01:00:00 /
UTC 2012-12-27 21:00:00 : en:¦h / en:°iÔÁTgGlqÆ@îJÂõbÚn\Û]²nÁ<êD›” ¹ûôÛÛ¤Û¨µæG®-¦þM$å€/kX*÷ûY™».hõò¨ÏG²X5_“:Ã) Q¼V9p / user defined / / 01:30:00 /
UTC 2012-12-27 22:30:00 : en:HçÕœ˜ž / en:庭_µQž¿§»©Tg¯ûklü°ýœ]¿Žw9Ù%ýlÿ¾vçËF@mêÎ / news/current affairs / / 00:15:00 /
UTC 2012-12-27 22:45:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-27 22:55:00 : en:ƒÒã^¼Î,@žmƒ‚@ / en:Í*0 / ±¦½&ùÝÀ:€¬:Zêª @_¶qèmû¢|ùh¢=—šîÚùTg¥Ìö³íÏKÖ\ö^áǝïIÑ~´º=NཚNíaëË»¹(@,cÉóÝ0ѝêÙg / show/game show / / 01:00:00
UTC 2012-12-27 23:55:00 : en:ïÿ~-½ü / en:FñC×òoåµ/®È•`5„T–¹¢:|:haÇj¶å³¹‘¾1ýªÏ’nªZv / ™K?dòT=ÿ¯v×ݸþ°s6ëN.‰ÝÉB / movie/drama / / 02:00:00
UTC 2012-12-28 01:55:00 : en:Ú¢u|úð?ø / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2012-12-28 02:00:00 : en:Ð.Ñx)ã / en:å¡•9e-å8_¡ÙuÌL!Ú¯iN}'íeêg¹?Ÿþ 'žÁPÊO[(öKô–@¯OkÊx¯yZˆ=ñEn‹£Là / news/current affairs / / 01:00:00 /
UTC 2012-12-28 03:00:00 : en:ô2-7‰m6žµ½` / en:)»µ¶T÷”÷°O¯pï7£sšŸ-þËT&^½ôO*ó®’Éÿœ³§1\M¤d‹åÞΜÅpI+ø¥—™ézE,êqïWÀ¦jÎßizžG]c”iœ / news/current affairs / / 01:00:00 /
UTC 2012-12-28 04:00:00 : en:ÙÚÍÇ@ / en:åé˜öÅéyòi#S˲fõp4ü w­J| / ¬¦Íñ<X+Ýu-'ßÛO“Ix|^Ξ¹ÃÔ©Ð.˜ã¦üø¿Kµ‹f–Á†žžÓbÇ|lޏdiœ / leisure hobbies / / 00:30:00
UTC 2012-12-28 04:30:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 01:30:00 /
UTC 2012-12-28 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GTo›à²€õ<?tg¯ûki_a’y§ËÜ„¶É¼óÖڇ܀ / news/current affairs / / 03:00:00 /
UTC 2012-12-28 09:00:00 : en:ê×pyKñp†GlÔŸÕŸ]O° / en:/‚Fó&!êüÙZ,ƒ¤ëß~Í[x¥ÁaÞo@DÂoÌI9e±ísèŠ(OQ;N' ~vþ9ôÚæ‚ºLËäÏ]ôbÏurijPÓÃöîW_!¤Û­§0g`h:³€ / movie/drama / / 01:45:00 /
UTC 2012-12-28 10:45:00 : en:¹V˖оÁr` / en:!•BâÖ\ñ6ß]qP ˆNê´\‹f–~ÀÅÝ÷®ý£‹GPKã³ìXêx¹ŽeUÙÞÊ~÷!òò,W¸w›Ð=6ÌÛ`‘ÕÅ`eUœ / movie/drama / / 01:35:00 /
UTC 2012-12-28 12:20:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2012-12-28 12:35:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-28 12:45:00 : en:æ/Q“ië[ÕèŠÅ / en:q˜g÷„pÕ¯Ã¦ðæ6ŸD±;P™ / Õ/&½}à ®œÅpIou7oÝPšg‘÷ÛžÿLcKÖöÑþLæüµ+S·¯RèsNæþ;cxЦºW®Wú·1~Ñlà / show/game show / / 00:50:00
UTC 2012-12-28 13:35:00 : en: ¥¨^Êq×ü¼ð / en:o 2ýÒS©C×òoúѬ¤qÝ©Z¹ÊÕÍÝ_²Q,æu¯J­]¾Z,#mÌöjû^ÿÂsrLË€¥>³¹'-â…B3»:© )õÅê\#µ-W¤1Ò¤R,:£x¬ / ªVp / movie/drama / / 01:35:00
UTC 2012-12-28 15:10:00 : en:b0s¸"œ®f>îæ·4bûw / en:_ +zE>×oZBOj¡ÐlÿÜ—zZêdã“!=Þ¾Te lîfQê㔕ñ0FsÉo»¯ü5¹?K¡íŠ çdz€ / movie/drama / / 00:20:00 /
UTC 2012-12-28 15:30:00 : en:ȧÛHhöçÙð> / en:FñÉˆzº`K¹MtÈŠeÊՏ­£þÁ¥æUÅîJŸö‘S / óú™q%wû2^ãa—C²ïi:5ÿ«¸á×fKC+Ç`»cc+»’„nÛ…p7}§VËލÞ+¯ê¬rà / movie/drama / / 01:40:00
UTC 2012-12-28 17:10:00 : en:ô‚§m¶Køk"ý)Ÿ¸« / en:%eáŠüSʬ5(Î?øµ$öªe¸¶É“Ž3¡˜=Aǹ_ϲºúZù6¯BUë-eÞÒué‡þ§çeØçìÈOv¡ÝÕ‚GToŽ\ / show/game show / / 00:30:00 /
UTC 2012-12-28 17:40:00 : en:ïÿ4—‚x>0 / en:‰óè¤jù#^øÚB{Îýx<[³*…·ùáÀgGi#”Å‚ðÄF´î*uåÞ`XÍØ#8ß'­/Š¸ãŒqà^ŸvÉó}ë¼î,:£x¬à / show/game show / / 00:50:00 /
UTC 2012-12-28 18:30:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2012-12-28 18:45:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:15:00 /
UTC 2012-12-28 19:00:00 : en:‹Á<(m=¥ƒ  / en:=ñu>bý“”Ń€"…ß«ñûÝMæ7Æ|¿4ï,â`-ì¬öL»kÔÞ7gè~»ÔR=¿Žzß[$öLCˆ¶¡—ß§±ÊJŒàþ9éj½+_œÇšœX$uFñYÀ / show/game show / / 00:30:00 /
UTC 2012-12-28 19:30:00 : en:¾ÏêҏÝÑM|9p@¨ / en:¿qî-üÊá­/ê'9‰ãÁÕþB{‹tÚÐ{Þê5W«•òUþÞ>v¬=w¿k(S66Jjù/?­I=%IƒÏ2Éí2þ)n¯<'á]Î / leisure hobbies / / 00:30:00 /
UTC 2012-12-28 20:00:00 : en:{Û˜Kr° / en:_±ùÄá{Z^:[»ÌÞaÏáwÇkþ]¸ÓP~ßQã…¼)x9ÃÝTËžuêtxª÷UÉÈAp¥kŸWûM9Šà’-·°xÕaçÀX´ïv/ÓííÅ‚GToŽ\ / user defined / / 01:00:00 /
UTC 2012-12-28 21:00:00 : en:¦h / en:3¯Ź…ê&é¸'®š´É`ÕV[˽şç{2G6w9!%Ê.îJ År|÷L4gdñcôKŸˆ¦RÏÕËލÞ+¸ / user defined / / 01:30:00 /
UTC 2012-12-28 22:30:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûklü°ýœ]¿Žw9Ù%ýlÿ¾vçËF@mêÎ / news/current affairs / / 00:15:00 /
UTC 2012-12-28 22:45:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-28 22:55:00 : en:‰Ç?SÏ´×n7˜ðøÑ€Ø / en:Íë¼°VCî>–«ÒãüP”:ï¹åü¯øŸ›òm8ó=$s:8óÔ;ë._Û×e×K`=Ï8¯ÌÞ}…«äÃöÕî´àÛÞ}œ / show/game show / / 00:05:00 /
UTC 2012-12-28 23:00:00 : en:1ù–3W÷h Y¸ / en:˜\3°íF·êuï4¨ÝdÜv°õâœÎÑeìó]ÚKáïoŠXwzà0J–và-g³¿ýŽ8È+䝸Ò;¶Å^Ö¹ŸÉÂîä¡ / show/game show / / 01:20:00 /
UTC 2012-12-29 00:20:00 : en:÷ϯÿ€ / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2012-12-29 00:25:00 : en:0<åš/ÿ / en:HûJò\Si+QОÙÞ.¨q=Ë‹r.*;»2X¬NœYÛ™¼^W7l½®îJõer|÷L4gz¶XUc”iœ / movie/drama / / 01:40:00 /
UTC 2012-12-29 02:05:00 : en:øFõM6gû…·_añ!Ð / en:Ç{¨À¯’Ú¨ÏvΦ0¶·±e—÷‡wi/nÛÎò“ÊâÜ‘í%õÔ¿5(Ë;Û÷Ÿí¾.ùävZ×È‚²”ÿ‘o2Ìú˜¸Ť|Ÿ-%‹c”iœ / news/current affairs / / 01:00:00 /
UTC 2012-12-29 03:05:00 : en:‚ÿ¡Àöœ / en:‡1\V‹‰ æÛ¸Óš¡£×S²»ü¨vöëožœ­´ø I>þØEÁòeÅ·ùqÎ=Ìæ/ÂŒé«;.Î / qÿ/Clz÷õ £0þ¬½ _eÍØ«Wá–F™À / news/current affairs / / 01:00:00
UTC 2012-12-29 04:05:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 01:55:00 /
UTC 2012-12-29 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GToœ / news/current affairs / / 04:00:00 /
UTC 2012-12-29 10:00:00 : en:Ñxó‹ÙDð / en:!\[q!?¾ñíxˆê / leisure hobbies / / 01:30:00 /
UTC 2012-12-29 11:30:00 : en:«ÇøUí!³ó³Ä{§0 / en:@ôr_ûÒu‡àKÉ8K“‡ÛvׯÓ]¡ù× ©ñ9 »c`2Êòó¾þØz.ãaa—>-‡crñ?ŽrãœzþúmÒR—ßÀç¯N.ß©Éá´-³u`‘ÕÅc— / leisure hobbies / / 00:30:00 /
UTC 2012-12-29 12:00:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkkøç’s•g / news/current affairs / / 00:10:00 /
UTC 2012-12-29 12:10:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:05:00 /
UTC 2012-12-29 12:15:00 : en:LJ®¸>þUæ / en:1q¿«ìžÕKŒ•Ù÷ûd— ?ú±§Š£xµã;»vþ9ìÓP†wø‹Ýo­r?“êRU[SþT;>•Û'"H¯èÚöÑÿ¿ëÆñù©Õ‚GToœ / sports / / 00:45:00 /
UTC 2012-12-29 13:00:00 : en:Ç _ímS‚"˜rÖìñÐ / en:~kó˜óÊOÇáï©qØ©ìDkNâ§^\Þê5W«•ãö¤½´_zˆ‹Ã·ËlÑqÎ8#®Ù¢#¾ãÞ¯¿T‹ˆún{ý¿žmÇr9ý’úê^\GÜ¢‹ލÞ+8 / sports / / 01:00:00 /
UTC 2012-12-29 14:00:00 : en:üg9°5p@¡Š#ô™¤C / en:×á‡m½Ô`«ÕÂ.ÒMïçÛ]À-“YÝí+ä–µò.>v¤‹gro©âÙÅÞ«ñõ=%ss¿ÛÇÎÒûõñì±oÁ%ÖÅTgÎ / sports / / 01:00:00 /
UTC 2012-12-29 15:00:00 : en:üg9°5p@¡–¾Úu9Ò”À / en:]^sÔª·º+ä›ßÏ¡Tê^®VdÒNs­‹ã0øq?žKÕ˃l×·‡e×LúZOneà-z‡3ÚƒöòRT³õ>V…êÎ / sports / / 00:30:00 /
UTC 2012-12-29 15:30:00 : en:Õ‰›áÞbàH§#q9ÿh¸ / en:ÒšÛ––{v96é(š¼\o‹½¿Ž{Dâû7ÇV»ßµ”©–1«Ðã"~LCÙmÄ„úGË / :íî£JýKÉ/oé\©¶w• ¦['Ø$uFñYÀ / show/game show / / 01:00:00
UTC 2012-12-29 16:30:00 : en:Àœÿ´\ / en:Òí¼·” / ž¸É]ƒËó–qwÓØ»;‹ðc“r–›%óÉ-xΩ}Uÿš«‡%rï$·ß ÖOW¹PØv’ÈiÍcÕßòÎúT`aÛü¨vùZj/á– Q¼Vp / sports / / 00:55:00
UTC 2012-12-29 17:25:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkkøç’s•g / news/current affairs / / 00:10:00 /
UTC 2012-12-29 17:35:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-29 17:45:00 : en:‹Á<(m=¥ƒ  / en:±vøºŸ1~ƒIÊbÁÀ7©“Ù1"€XÈ=õòÝ|çÞ»ËÙÓ˜”µ^ÇËZõ0\“þQ”ÇSÁvÙ(›Ï½w—°_€|ç50Mé / SØå%Fpôµ^•¯ÎcÍN,:£x¬à / show/game show / / 00:30:00
UTC 2012-12-29 18:15:00 : en:Ê@ÄëzÄš¦ÓÖ·¡ / en:q˜t / ¹¢âBy›=ÿëB1uÚ¥à×±·W,Wq~1g'©@£ª5ko'¾2X~ãTR,:£x¬à / show/game show / / 00:30:00
UTC 2012-12-29 18:45:00 : en:×BÃ# / € / en:¤vÏGf÷ó퇮ôtå€/`[&³»Í1V·çá_Ù]“'¼È.”Ï'‹¾[8¢™¹J…jvWWÚ‰Ô³S~h$¦¯ºŠõðûRoZ˜ù)‹ލÞ+8 / show/game show / / 01:30:00
UTC 2012-12-29 20:15:00 : en:‰Ç?SÏ´ïù‰éKòqÛ / en:°sέwÃùӔűz^j"°VB½ºÇ߯(ùkSù2ëX*÷údS]‘óà / ŽSvE%gOXÄ‹‚/Ï!=ÛØ°í3“½7é#sßíþÑݳ€ / show/game show / / 00:55:00
UTC 2012-12-29 21:10:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkkøç’s•fÓ]Ø+<gf¹ / news/current affairs / / 00:20:00 /
UTC 2012-12-29 21:30:00 : en:áÌK}¼¦\šRm=kz½X² / en:°iÔ<7MÓ˜® :Ð(V£”ߏÕþÓ'põ÷ÒSÓj­ÿWºsÁ$u>îä¡E;ë®v~O1Šäùî˜hÎõl°Hêâ³€ / show/game show / / 00:30:00 /
UTC 2012-12-29 22:00:00 : en:áÌK}¼¦\šRm=kz½X² / en:3­Òûf$<7K{4|e7ýWû×Üô\G²[UF—•„ø Bµ4ÉÜ=<¬NI¥öÌHyªÝÜ” !è§}uÎÏÉâÆ1\Ÿ=Ó / Þ­– Q¼Vp / show/game show / / 00:30:00
UTC 2012-12-29 22:30:00 : en:âòS–Ý€ / en:ÒšÛ––{>õÞvÕâã|]ì;I0èòx»þos?føó2® / sports / / 01:30:00 /
UTC 2012-12-30 00:00:00 : en:þºàý._ÔVÀ / en:¾á{8Íóù}ë¼ì¾y%¯ßãžJ™Zj/ço3'U)*­©tæ+‚Kè»›ùô¨À6×WíØ§ÿ,åª)§šúΗ”¡-óîÊæÆ>={ã\óÎ / sports / / 01:15:00 /
UTC 2012-12-30 01:15:00 : en:÷ϯÿ€ / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2012-12-30 01:20:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 04:40:00 /
UTC 2012-12-30 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GToœ / news/current affairs / / 02:05:00 /
UTC 2012-12-30 08:05:00 : en:âòS–Ý€ / en:ÒšÛ––{>õÞvÕâã|]ì;I0èòx»þos?føó2® / sports / / 01:35:00 /
UTC 2012-12-30 09:40:00 : en:¶|_†6 / en:Ö¼÷'üp|–%5}É7‡Œ›Ÿ"'¾8ô„÷FaÇbÜÀ4Ô’ ý¹JB¿ïï“HOqiÙ®e´Uœ / movie/drama / / 01:50:00 /
UTC 2012-12-30 11:30:00 : en:Ð.Ñx)ã / en:v×þ^DíFñZIBýË®baÕ{JpÃé?k(S=ÉøÌÿðÍ<öê†RzÙG²XƤ² / news/current affairs / / 01:00:00 /
UTC 2012-12-30 12:30:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkkøç’s•fÓ]Ø+8ùٷɤ±ö@†8  / news/current affairs / / 00:10:00 /
UTC 2012-12-30 12:40:00 : en:‚ÿ¡Àöœ / en:‡1\V‹‰ æÛ¸Óš¡£×S²»ü¨vöëožœ­´ø I>þØEÁòeÅ·ùqÎ=Ìæ/ÂŒé«;.Î / qÿ/Clz÷õ £0þ¬½ _eÍØ«Wá– Q¼Vp / news/current affairs / / 01:00:00
UTC 2012-12-30 13:40:00 : en:_÷uÝ­mµ¿Í€> / en:ž§?Þbå#¥~é)Ô—?öqéh±³¼;狎Oއ=‘ä / P˜†å(.Òûä'ºãAwl|¼\ß¡!^¤AÔJ€­Þû€;º”ôJWͤ*\fÆß&]î,þ™mù °Hêâ°Í‹¸ / movie/drama / / 01:50:00
UTC 2012-12-30 15:30:00 : en:ŽƒéÉø¹Ýÿ€ / en:‡1\V‹‰ æß•¦Z6Àæ$£Ÿl=>LéÌW™Ò­›çô{OPÜ¥Ü#ÆSÑã¾EÙzÑ9‘©I{t™–‘÷äõ2âJïÞ…Ù]í'^ªØ$uFñXåÀ / user defined / / 01:20:00 /
UTC 2012-12-30 16:50:00 : en:Ó¦”î{TKÁ<1†\)YÍS@ / en:q˜Â(üɬîò逽C>5w9R:?Î`,òùÉVêXMm¿‹ŽÆ“‹¾žúv”;{Åú\ŒÎbü+¬=w™T-¸ŸÿŽy+:gó/jü2Á#ª7ŠÎ / news/current affairs / / 00:40:00 /
UTC 2012-12-30 17:30:00 : en:õ©ÃçÔwo / Ã` / en:%VšÖOgÐûiqÖöDt•î{º|gfËU(ÊKÝòþ¯ð—ù¸}_*Œô°ÏÏq“Ûã4¥çGYá{ö»ÿ“7«€=Õ[ö¬ò‹8 / news/current affairs / / 00:30:00
UTC 2012-12-30 18:00:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFa 8 / news/current affairs / / 00:20:00 /
UTC 2012-12-30 18:20:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-30 18:30:00 : en:‹Á<(m=¥ƒ  / en:²‹|]O˜¿A¤å1`öQö;Å÷Eë•©GW^aô}ë¼½­CV¶Z×]}Öþ¡ÏöÄÙ§²bEk.7ôöHjžÇ)*3ƒøç¥ªô­~sjq`‘ÕÅg / show/game show / / 00:30:00 /
UTC 2012-12-30 19:00:00 : en:‚ÿ¡Àöœ / en:×Gö÷Q‚¯W+ä½}Osñ÷š=|z£=ìox+2NXöÈiÍOí½X$uFñY´À—v / Î>vmòi,}…!Ž( / news/current affairs / / 01:00:00
UTC 2012-12-30 20:00:00 : en:ÎðO ¶¹v:Ø / en:°s<Za¤¡ / leisure hobbies / / 01:00:00 /
UTC 2012-12-30 21:00:00 : en:¤#Š?¥Ù0 / en:ÞØ]§¨¶´·Ãv¹ÅÞ¥: / Ÿ?ê|7«Í2ø_uÝw9-ʁ~/ð ÒVaAö½ºk®îJ †?ƒp7ÚIãr¦ï?L¥Ÿª-– Q¼V9p / user defined / / 01:00:00
UTC 2012-12-30 22:00:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûklü°ýœ]¿Žw9Ù%ýlÿ¾vçËF@mêÎ / news/current affairs / / 00:15:00 /
UTC 2012-12-30 22:15:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-30 22:25:00 : en:âòS–Üá@ / en:˜‡>ñc“n’‰«ÅÆø»Øv’ú«üÕ÷æ÷3öo3+è»›ô¬=w / r®ƒ%ÑÊqòzÿ¥%jˆ –ã¹íÔ;AÀXñŸ—¦¼éüsim!Ÿ²{Ïx\†Á#ª7ŠÎ / sports / / 01:00:00
UTC 2012-12-30 23:25:00 : en:Õ‰›áÞbàH§#q9ÿh¸ / en:ÒšÛ––{v96é(š¼\o‹½¿Ž{Dâû7ÇV»ßµ”©–1«Ðã"~LCÙmÄ„úGË / :íî£JýKÉ/oé\©¶w• ¦['Ø$uFñYÀ / show/game show / / 01:00:00
UTC 2012-12-31 00:25:00 : en:ýnÍ / en:Uê%Hß)ØÄ2îE8n»Eû˸áÎ>ê'iü™qÊoݽ־=!=Ï穾â÷3ÕØ4î<²À6ͦg¤O«#œKã´Wà÷w%z)ÞGËލÞ+PúÎ / movie/drama / / 02:15:00 /
UTC 2012-12-31 02:40:00 : en:÷ϯÿ€ / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2012-12-31 02:45:00 : en:‰ÖRééŽ¿åæŠr?ì:ú / en:q˜ûÛ¤­Q¼;;ûݵ%yY÷ / news/current affairs / / 01:00:00 /
UTC 2012-12-31 03:45:00 : en:{Û˜Kr° / en:_±ùÄá{Z^:[»ÌÞaÏáwÇkþ]¸ÓP~ßQã…¼)x9ÃÝTËžuêtxª÷UÉÈAp¥kŸWûM9Šà’-·°xÕaçÀX´ïv/ÓííÅŽQ¦p / user defined / / 01:00:00 /
UTC 2012-12-31 04:45:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 01:15:00 /
UTC 2012-12-31 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GTo›à²€õ<?tg¯ûki_a’y§ËÜ„¶É¼óÖڇ܀ / news/current affairs / / 03:00:00 /
UTC 2012-12-31 09:00:00 : en:æÓ‚“7©yQÅË´ / en:!]î·õÿ÷ãî˜í%•SŸï!~u’`;ö.üOêê¯<<çOå–DZÐlé+;TWGp:—C¾®™ç:z«+½¤ëÓøË´mÛ}õ•"‘`‘ÕÅažÕg / movie/drama / / 01:30:00 /
UTC 2012-12-31 10:30:00 : en:G-Force / en:_ +׌꿓ԟƇµx¸Ë2!h.3Z|ýä§E´¤·U«Ëi³ËYŠó­úâïÄË|zKŸ-½Iٝ“Ö€{:ö¸|ô‰m˜ûX$uFñXT¬à / movie/drama / / 01:20:00 /
UTC 2012-12-31 11:50:00 : en:i"ü¯¯9Úُto` / en:_ +Ü0Ëôu!óQN/’MâQÿ„^Ú€Û˜ÿŽoù4"úÏþ¤×’z§ô‹é¹J ‘/¾Hò>P{$[Á¶Ç}KU>öf9øWE°:þªÎ / movie/drama / / 00:25:00 /
UTC 2012-12-31 12:15:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2012-12-31 12:30:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2012-12-31 12:40:00 : en:+ÊxR / ;ÃYŠ… / en:,Ý寍nÿ|© {œ&þL¸¶âB}*0 / ¶§ÌùNKLU íD¡ÇûË×¾že‹´õ?d)K¾íeêm1ÎTó£Üöüø9=§wüX / Š]ª-œ / show/game show / / 01:00:00
UTC 2012-12-31 13:40:00 : en:_îŸö? / en:…1ßû²¿“ÔRŸ^ÿZÛv÷Y2N{ás½•9žÉquiÔ / BÅTžšF¤+“€¶ªm“Ûoh›*wDÄòcL´]@,h>]±R) Q¼VÏë8 / movie/drama / / 01:30:00
UTC 2012-12-31 15:10:00 : en:ÍýÁ°ƒ` / en:ž§?Þ}N“ùÑÚJÏo‹žj†Ü•“>ë_þÏ5Ý—m˜–Âk`xÕüûí²ZßtÓlœ_ω­u‡×=£àgT®˜ºš²‰®Ý6û†-‚GTo†[_¬à / movie/drama / / 02:50:00 /
UTC 2012-12-31 18:00:00 : en:HçÕœø“0 / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2012-12-31 18:15:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:15:00 /
UTC 2012-12-31 18:30:00 : en:‹Á<(m=¥ƒ  / en:±Ù¾ óÖ@æ­AšÊÎ%EOÅ¿ «=“.ñòòbE™Ë´¿¨ž¢“MS:sZ8³~ßšZ¯J×ç1æ¦ì®Ìæ/Ði<8 èí%•SŸïSÁ#ª7ŠÎ / show/game show / / 00:30:00 /
UTC 2012-12-31 19:00:00 : en:-*§/èÖ~vxÝ> / en:Ng1~gGi#¬2ÇWøõWêÆš:o)„þÛ@d|ìÀ\ / €Y³ÙßþÇdÏã£ø%*=Bvºª<u£ŠÖñfH?]^Ã=%õÔ¿a3¬ÙµGk_ZÁ#ª7ŠÎ / show/game show / / 01:00:00
UTC 2012-12-31 20:00:00 : en:·¦½q±€ / en:|-%§+!Øžù)+÷¨C+¡9 ùÅmþ½Û–;dz𮛦­p]VÍ<ÌÅïî¦øs?>'_&ã3¹ž—”-ô]»~târ_ÍwÂÛtX$uFñXåÀ / user defined / / 00:30:00 /
UTC 2012-12-31 20:30:00 : en:ê×vq`Š ÈøìÔ9ÚÀ / en:oIN¥_É¿êl{j§Þͺ€Œæ?6V–"i-å¿àüÞ4~HúëÁ¹J ‘$\*÷ñÙw¦q¼6fõÛšîÙk‡it z°Hêâ°:þªÇ. / movie/drama / / 01:45:00 /
UTC 2012-12-31 22:15:00 : en:HçÕœ˜ž / en:庭_µQž¿§»©Tg¯ûklü°ýœ]¿Žw9Ù%ýlÿ¾vçËF@mêͦ»°Vvª3×þ3³\€ / news/current affairs / / 00:15:00 /
UTC 2012-12-31 22:30:00 : en:–(༠½VÀ / en:ÞØØ ±Þ=-Â+áëÒ’vd¶Öì3¸ Q3º­s­ÃW¼‡íÕ¯¥jV­r*yÇ8WV§Kú—'R¥ªô®:ôLøy­Í¯­=ç‰{X!úÛs¿¼¬ù°Hêâ³€ / show/game show / / 01:10:00 /
UTC 2012-12-31 23:40:00 : en:¯çgˆÖn / en:´vþ9ÛßÏå„vÞ[Ê.b ~Ã×pžÂRN͇¯£€´–ubƒ³ÍÍêzH¶âòÕllXï®öü| / Ëb°¶ Q¼Vp / show/game show / / 00:35:00
UTC 2013-01-01 00:15:00 : en:úübªÎ§÷#ï¡ÊÌÛ4 / en:hîS’-%Ö,‡mTˆüžKãý / ‹ÙY݈{¢—6Ï2ª3å•'ÉxY1"ÒÕzWz%aÞo@p]^m­…ét]Ü” ÉóÝ0ѝêÙ`‘ÕÅg / show/game show / / 01:10:00
UTC 2013-01-01 01:25:00 : en:Û¹1ß_jà / en:¡:ë[CžÈÜʼÀÅ€è6J¼…qnHüM÷‘óÒõ›Ë|õïýì,OóµÈß)ï®§ÌDðÓäýÉŽ=ÝÉBc®Ožé†ŒïVËh«8 / movie/drama / / 01:15:00 /
UTC 2013-01-01 02:40:00 : en:÷ϯÿ€ / en:<òàq›|œNiöp / news/current affairs / / 00:05:00 /
UTC 2013-01-01 02:45:00 : en:HçØ / en:Ç8í|“œEéí­¬ïoÞ“.Û]ñÛmmŸ€µRÌñ / news/current affairs / / 03:15:00 /
UTC 2013-01-01 06:00:00 : en:V÷ÿ)° / en:庭_¶¶Î[8ºÚ­ûVIî3³oãžIÎ"róÝW›ã0…‚GTo›à²€õ<?tg¯ûki_a’y§ËÜ„¶É¼óÖڇ܀ / news/current affairs / / 03:00:00 /
UTC 2013-01-01 09:00:00 : en:yû@×ö˜ / en:o 2ýN¶¥úñ¤Ù<_Uìüù<åjQÚ.{ùþ^{±tÐCzbšã]ø÷þ¥?bšçáå×É—Ï%”:+‘‰¦¤¢Ü[úǁټOXÄ3‹Ž_J‘ºÁ#ª7ŠÀÚ¥g / movie/drama / / 01:35:00 /
UTC 2013-01-01 10:35:00 : en:»LM¶Ý­¯šè¸à / en:›ö\ZËž'CžÈ7êys‹h™R7Êtx1c©ê&{YÉ…eµ¶ù¤‚Ûml­X‡§ÿ_Ozp»—$–¼@ÛVC´”¹ìƒù=!=ßNfÃ/6D•Û×XgZ«8 / movie/drama / / 01:40:00 /
UTC 2013-01-01 12:15:00 : en:%L‚iÚT¿j‡SgêU  / en:q˜KÃ86³¿;Ö‚,n¯ëÑ(vv%ç•êž)¬÷UÇdÎkÆîFª&ñ(þllwªÎüíòi/ª¿Àƨ8ž*ûÓ4ïÇøç’À†–[Í¿a”vG~¶u`‘ÕÅg / news/current affairs / / 00:05:00 /
UTC 2013-01-01 12:20:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2013-01-01 12:35:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2013-01-01 12:45:00 : en:Ãÿ3^¹ˆÖG©r / sl[kÀ / en:ê”ãco|´ëû§1\E·ýzRH”¯›Iêê+õx¸ß{ÒEÚzžî˜7Úò«‹n/-QQ×Ãé¥eÉ)ZHÿ#¾{qÖºÁ#ª7ŠÇ. / news/current affairs / / 01:00:00
UTC 2013-01-01 13:45:00 : en:âLþÀ / en:¼ïëÿ“õmïçÚ¶ç°Mß,ÙÄÜø¸Í¾L¹ÿ0áÚ›òbp·ì³áÛU&¯½ª$®ôçSÿrb—¨SJîg¡æ¿1!°,¿€ÿ}¶KGùyÝ»uE‚GTo†[}YÀ / movie/drama / / 02:15:00 /
UTC 2013-01-01 16:00:00 : en:Ö»€­·Nnÿò / en:_ (Î?À¶ˆâ ¶¥¸Ð.þ*o²´‹Þz.k.ËŽƒgÅ€ÏYŸQ;N'»yviÓ¡î«#Ü<ÕÇŠ'õqy/¦A¢ïâ£ðZ£+±ÐÍÊ•"‘`‘ÕÅ`mR±Ë€ / movie/drama / / 01:35:00 /
UTC 2013-01-01 17:35:00 : en:HçØ / en:庭_µQž¿§»©Tg¯ûkhª“Óøç’sœmFaCð%Ý‚³Ævk¬à / news/current affairs / / 00:15:00 /
UTC 2013-01-01 17:50:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2013-01-01 18:00:00 : en:‹Á<(m=¥ƒ  / en:±µ¾4ÚÔü7}ë¼½¼ñ/*,»¦õ óæ+ñLɬéÊ{¬Öš×笩Xd} ˆOzg„_)ث煿GÌB¿žíJ+ãTûލÞ+8 / show/game show / / 00:30:00 /
UTC 2013-01-01 18:30:00 : en:Up / en:_ (ÎÇÈéÉR±ÚþÜØeâ@NÃo°&ûYñð#¹‰îhàô”;{þªþ]x"z©¨wIï·knÿ¢v¨» / movie/drama / / 01:30:00 /
UTC 2013-01-01 20:00:00 : en:·¦½q±€ / en:äs’Œž7îÑ<Îbü+›áÿâÛ‰ üÙ„À³ËãMZj¥E|OÛÿö-Ö€s1{øÔHÚ‘8[ñ¶&â׌êzÒò{÷ÔEÆç¾¶Šw7sfE‚GToŽ\ / user defined / / 01:00:00 /
UTC 2013-01-01 21:00:00 : en:ç†mC / en::\gÞºÔ÷»ö 2+ïÉ=ÊÙ¼Ny½άàÕ¿þM½®ÿä6Èræà-FÎKM¸PƒáZx;ÐüãÏ[ouù2ãewÉ­vCîÕ«p3á]Á#ª7ŠÇ. / show/game show / / 00:30:00 /
UTC 2013-01-01 21:30:00 : en:áÌK}¼¦\šX / en:°m(xn—V‹ònìCÙvž£A}à ¹œÅøWIUˆ0¤øí‹fî<a´Ì(çíÀYsð®ŸñÓyMqRÎÚáB˜YÐ*}ÝÉBŠw×\ìüž+“çºa£;Õ²Á#ª7ŠÎ / show/game show / / 00:30:00 /
UTC 2013-01-01 22:00:00 : en:HçÕœ˜ž / en:庭_µQž¿§»©Tg¯ûklü°ýœ]¿Žw9Ù%ýlÿ¾vçËF@mêÎ / news/current affairs / / 00:15:00 /
UTC 2013-01-01 22:15:00 : en:°ä¨×ÙgñM / en:ËÇ=¨vv‰¹Îû|šKuZ¿mmçAùy4¨À7”øøu¤Øzç8ìת7•–Ç´•RÌñ€ / news/current affairs / / 00:10:00 /
UTC 2013-01-01 22:25:00 : en:âòS–Ý€ / en:n.æý;Y@mŽàPd‡¶Å^Ç;<Û{;q¤6º¸Ñl:£x¬Ú`K»d)FzþÞ¦/VsÂr¾ / sports / / 01:20:00 /
UTC 2013-01-01 23:45:00 : en:–(༠½VÀ / en:ÞØØ ±Þ=-Â+áëÒ’vd¶Öì3¸ Q3º­s­ÃW¼‡íÕ¯¥jV­r*yÇ8WV§Kú—'R¥ªô®:ôLøy­Í¯­=ç‰{X!úÛs¿¼¬ù°Hêâ³€ / show/game show / / 01:05:00 /
Post Mon Feb 04, 2013 8:16 am
Re: KDL46HX853 and Humax .ts playback
if PVR format is always the same, you can create a custom profile that transcode this file to mpegts/mpeg2video/aac.
Copy/paste in profiles.xml just before the last </Profiles> element:
   <Profile id="sonypvr" name="Sony Bravia TV (2012) - for PVR files" extendsProfileId="sony2012">
         <!-- Transcode PVR files -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" forceVTranscoding="true" maxVBitrate="17000" targetACodec="ac3" aBitrate="192" DAR="16:9">
            <Matches container="mpegts" vCodec="h264" aCodec="aac" />
Then save and restart serviio services and on serviio console select this profile when you want to play a PVR file.
aebailey
Post Mon Feb 04, 2013 10:20 pm
Thanks Illico, as your profile says "DLNA Master". Thank you for the quick and accurate response
