RTMP - segmentation fault on linux
forrest79
Post Mon Feb 04, 2013 9:07 pm
I have a problem with reading rtmp streams on linux. If I test "ffmpeg -i URL" on Windows 7, I got this results:
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
  author
  copyright
  description
  keywords
  rating
  title
  presetname            Custom
  creationdate          Sun Jan 27 15:00:25 2013
  videodevice           Decklink Video Capture
  framerate             25.00
  width                 720.00
  height                404.00
  videocodecid          avc1
  videodatarate         904.00
  avclevel              31.00
  avcprofile            66.00
  videokeyframe_frequency4.00
  audiodevice           Decklink Audio Capture
  audiosamplerate       48000.00
  audiochannels         2.00
  audioinputvolume      75.00
  audiocodecid          mp4a
  audiodatarate         96.00
[flv @ 014DBEA0] Estimating duration from bitrate, this may be inaccurate
Input #0, flv, from 'rtmp://wcdn60.nacevi.cz:1935/ELH_VIP?id=5lrPz6fNsyxKbW/ELH_VIP_Vary_404p.stream':
    author          :
    copyright       :
    description     :
    keywords        :
    rating          :
    title           :
    presetname      : Custom
    creationdate    : Sun Jan 27 15:00:25 2013
    videodevice     : Decklink Video Capture
    avclevel        : 31
    avcprofile      : 66
    videokeyframe_frequency: 4
    audiodevice     : Decklink Audio Capture
    audiochannels   : 2
    audioinputvolume: 75
  Duration: N/A, start: 0.000000, bitrate: 1024 kb/s
    Stream #0:0: Video: h264 (Baseline), yuv420p, 720x404 [SAR 1:1 DAR 180:101], 925 kb/s, 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac, 48000 Hz, stereo, s16, 98 kb/s
But when I run the same command on linux (Ubuntu Server 12.04), where is Serviio primary running, I got:
  built on Nov 12 2012 23:57:54 with gcc 4.6.3
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
Segmentation fault
Everything else work good on linux. I googled about "Segmentation fault" on Ubuntu and search this forum, but nothing that I found work for me. Can anybody help me? FFmpeg on linux is compiled from source, from Serviio download page.
khurram23
Post Tue Feb 05, 2013 1:52 am
Re: RTMP - segmentation fault on linux
Have you compiled all necessary apps required on linux?
Follow instructions on wiki and see if this resolves the issue...
http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
forrest79
Post Tue Feb 05, 2013 11:59 am
Yes, I have followed the instructions on the wiki, I just did not use source data from the repositories, but from the archives that are on the serviio download page.
khurram23
Post Tue Feb 05, 2013 4:08 pm
Provide an example URL. I'll try it on my Ubuntu installation.
forrest79
Post Wed Feb 20, 2013 9:21 am
Upgrade to Ubuntu Server 12.10 a recompile ffmpeg help :-)
patters
Post Wed Feb 20, 2013 9:33 am
At a guess I would have thought it could be that librtmp wasn't compiled quite right. You could have checked this by running the rtmpdump binary which that source package builds, before compiling ffmpeg.
Users browsing this forum: Baidu [Spider] and 19 guests
