Xperia Tablet S - Native media app play-back
S222NEY
Post Wed Feb 06, 2013 1:34 pm
My Xperia Tablet S works fine with Skifta and MX Player, but this is a little 'clunky' and I'd love to be able to play everything in the native Sony media player.
The device name is SGPT121 and the DLNA certification can be found here: http://certification.dlna.org/certs/REG23138846.pdf
According to the certification, the formats supported are:
Image: JPEG_LRG / JPEG_MED / JPEG_SM / PNG_LRG
Audio: AAC_ADTS_320 / AAC_ISO_320 / MP3
Video: AVC_MP4_BL_CIF15_AAC_520
I'd really like to try and develop a profile for the Tablet S but I'm completely new to this and it's years since I've done any kind of coding. I couldn't find "AVC_MP4_BL_CIF15_AAC_520" defined in the MediaFormatProfiles at the top of the profiles.xml - does it need to be defined? Where should I start?
Any help or pointers would be very much appreciated.
Servio 1.2.1 [Windows XP MCE SP3]
SONY | KDL-46HX803 | BDP-S470 | PS3 [CECH-2503B] | Xperia Tablet S [SGPT121GB] | Xperia GO [ST27i]
Post Wed Feb 06, 2013 3:11 pm
Re: Xperia Tablet S - Native media app play-back
Could you provide information about format supported by your device ?
http://wiki.serviio.org/doku.php?id=device_sf
Post Wed Feb 06, 2013 3:17 pm
S222NEY wrote:Video: AVC_MP4_BL_CIF15_AAC_520
Serviio does not support transcoding video to h264, only to mpeg2video. So we have to know the proper format supported by both Serviio and Xperia.
S222NEY
Post Wed Feb 06, 2013 4:41 pm
Illico wrote:Could you provide information about format supported by your device ?
The tablet doesnt appear on Intel UNPnP (neither does my Xperia phone - not sure why?), I had to pull the format details from the DLNA certificationn.
Could you clarify what you mean by the 'proper format' '?
Post Wed Feb 06, 2013 4:53 pm
S222NEY wrote:Could you clarify what you mean by the 'proper format' '?
For example : MPEG_TS_SD_EU
If both Serviio/Xperia support this format, we can create a profile that transcode all media to mpegts/mpeg2video/ac3 stream.
Because AVC_MP4_BL_CIF15_AAC_520 is not a target format supported by serviio/ffmpeg transcoding.
S222NEY
Post Wed Feb 06, 2013 5:03 pm
Would it be worth downloading the sample videos and loading them on to the tablet to see if any will play?
<EDIT>
I have masses of videos in loads of different formats, some over 10 years old. I've got some WMV, MKV and MP4 files to play locally and a random MPEG that plays with out sound. Other MKVs play but with no sound.
Not sure if this helps, but the following file will play locally and will stream via Serviio (with the Generic DLNA profile) using the Sony video player (it also works on my Xperia mobile):
Complete name                            : E:\TEST\<removed>.S01E01.mp4
Format profile                           : Base Media
Codec ID                                 : isom
File size                                : 365 MiB
Duration                                 : 42mn 4s
Overall bit rate                         : 1 212 Kbps
Encoded date                             : UTC 2012-10-10 18:04:31
Tagged date                              : UTC 2012-10-10 18:04:31
Format profile                           : High@L3.1
Format settings, ReFrames                : 5 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 42mn 4s
Bit rate                                 : 1 083 Kbps
Maximum bit rate                         : 7 166 Kbps
Width                                    : 720 pixels
Height                                   : 404 pixels
Bits/(Pixel*Frame)                       : 0.155
Stream size                              : 326 MiB (89%)
Writing library                          : x264 core 128 r2216 198a7ea
Encoding settings                        : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Encoded date                             : UTC 2012-10-10 17:46:15
Tagged date                              : UTC 2012-10-10 18:04:39
Codec ID                                 : 40
Duration                                 : 42mn 4s
Bit rate                                 : 125 Kbps
Maximum bit rate                         : 151 Kbps
Delay relative to video                  : 83ms
Stream size                              : 37.7 MiB (10%)
Encoded date                             : UTC 2012-10-10 18:04:38
The caption that the video conveniently displays when you pause playback indicates that the stream is using: AVC_MP4_MP_SD_AAC_MULT5
S222NEY
Post Wed Feb 06, 2013 6:34 pm
This file will play over the network using a file browser to access the file directly but will not stream, presumably because Serviio transcodes it to a format that can't play:
Unique ID                                : 192019182230345378818812018346839871199 (0x90758C9E9FDC898CA44ED3D7D9458EDF)
Complete name                            : E:\TEST\<removed>.mkv
File size                                : 55.1 MiB
Duration                                 : 22mn 32s
Overall bit rate                         : 342 Kbps
Movie name                               : Encoded with MiniCoder
Encoded date                             : UTC 2011-06-10 08:40:37
Writing application                      : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format settings, ReFrames                : 8 frames
Duration                                 : 22mn 32s
Nominal bit rate                         : 300 Kbps
Width                                    : 640 pixels
Height                                   : 480 pixels
Display aspect ratio                     : 4:3
Bits/(Pixel*Frame)                       : 0.041
Writing library                          : x264 core 104 r1683 62997d6
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-4 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=300 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
Format profile                           : HE-AAC / LC
Codec ID                                 : A_AAC
Duration                                 : 22mn 32s
Sampling rate                            : 48.0 KHz / 24.0 KHz
Menu
00:00:00.097                             : en:00:00:00.097
Users browsing this forum: Google [Bot] and 12 guests
