Sony BD Player with no DivX support
JamieCanada
Post Thu Feb 07, 2013 1:35 am
Hello, I like this product.
I have a Sony BDVN890W from Canada which supports XVid AVI's but not the DivX format. The player matches the "Sony BD Player / SMP" Profile which I modified to get the avi's to work. (I followed a previous post about disabling the avi media format profile). My question is about the transcoding matching - can you setup serviio so that the xvid avi's are served natively but the divx avi's are transcoded. This is the line that I add/remove and seems to affect both avi types:
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="320">
<Matches container="avi" vCodec="mpeg4" /> <!-- can I say divx only? -->
Post Thu Feb 07, 2013 10:49 pm
Re: Sony BD Player with no DivX support
post ffmpeg -i of the divx file
JamieCanada
Post Thu Feb 07, 2013 11:42 pm
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memal
ign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --ar
ch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-ming
w32- --pkg-config=pkg-config
[avi @ 0182CDE0] non-interleaved AVI
Input #0, avi, from '.avi':
encoder : VirtualDubMod 1.5.10.1 (build 2366/release)
Duration: 01:48:28.88, start: 0.000000, bitrate: 903 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (DX50 / 0x30355844), yuv420p, 596x246 [SAR 1:1 DAR 298:123], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb/s
JamieCanada
Post Thu Feb 07, 2013 11:54 pm
Just found the solution (adding vFourCC="dx50").
See the referencing issue: https://bitbucket.org/xnejp03/serviio/i ... vx-5-codec
Thanks, Jamie.
pizzaguy541
Post Sat Feb 09, 2013 12:43 am
I had this similar problem in the past and the advice given to me was to use the AVI FourCC Changer. Simply type in xvid in both text fields and then click apply. It takes less than a second to change and the file will no longer require to be transcoded.
You can get the file here: http://www.inmatrix.com/download/avic100.zip
