Re: Proposal to Change Online Sources URLExtract Logic
You keep adding stuff about how you implemented the workaround. Is the solution I suggested do the same for you? viewtopic.php?f=22&t=8757#p61024
If yes, there is no need to describe what you're doing now, it's just confusing.
Petr
Help translate Serviio
