Looping Playlists
Rock
Post Sun Feb 10, 2013 11:41 pm
Looping Playlists
I am not sure if the problem I have is a problem with Serviio or with the Sony Media Player (SMP N200) I am using with Serviio:
I have created a folder of music videos or mp3s on my PC (a playlist), and Serviio serves that to the Sony Media Player and on to my big TV screen in my lounge. From the Sony software I can select the folder, then the first file in the folder and when the track is finished it will then play the second track, and so on until the last track, then it stops. However, I would like it to then loop, and start again at the beginning.
Can this (looping) be done with Serviio?
Is this a feature that would be normally be implemented within Serviio, or withing the Sony Media Player software?
Rock
Post Mon Feb 11, 2013 1:52 pm
Re: Looping Playlists
It would be in the player. It's usually there, look through their (tools?) menu
mdb139
Post Mon Feb 11, 2013 6:19 pm
Looping Playlists
While playing the media, my Sony TV lets me select repeat, shuffle, etc from the Options menu. My Sony BluRay from the prior year does not have those options.
Users browsing this forum: Google [Bot] and 34 guests
