Questions about Thecus N5200 / N5550
prmadmax
Post Mon Feb 11, 2013 10:30 am
So I'm thinking of getting either a N5200 or N5550.
I have a couple of questions...
1. Is there a module available for these?
I found this one http://forum.thecus.com/viewtopic.php?f=36&t=3610 - would this work?
How easy is it to setup a Thecus NAS and install modules?
There does not seem to be a guide like the rest so its either straight forward or not :?:
Regards, MadMax
Serviio Beta Tester
Samsung Series 6 UE32H6400 (3D Full HD Smart TV)
Synology DS1512+ / 3GB Ram / 5x 3TB WD Red Edition HDDs with 5.2 firmware running Patters Serviio package for Synology NAS
qoolbox
Post Sat Mar 02, 2013 8:57 am
Re: Questions about Thecus N5200 / N5550
i am the Thecus Third Party dev, for Serviio Module.
The module runs fine on any Intel Thecus Platefrom, with in frontend the mpemberton5 php interface.
it just require some dependency to install as prior on your NAS
OracleJRE6 - http://www.fajo.de/main/en/thecus/modules/oraclejre6
ModBase1 -http://www.fajo.de/main/en/thecus/modules/modbase1
PHP53 - http://www.fajo.de/main/en/thecus/modules/php53
and also my last FFMPEG Module
http://forum.thecus.com/viewtopic.php?f=36&t=3178
the only know issue is on x86 NAS - the files with special caracter encoding (éàè...) are not display due to Thecus limitation, no localdef, i didnt yet resolved the issue.
but on x64 bit NAS there no problem at all...
if you have any questions do not hesitate to contact me
Third Party Thecus NAS Develloper
http://www.tsuga.fr
prmadmax
Post Sat Mar 02, 2013 9:53 am
Hi qoobox,
Thanks for the reply :) I decided in the end to go with a synology NAS.
Regards, MadMax
Serviio Beta Tester
Users browsing this forum: Bing [Bot] and 5 guests
