YOUTUBE TOP 100 MUSIC VIDEOS WEB RESOURCE
• Page 4 of 5 • 1, 2, 3, 4, 5
Version 17 posted to support revised YT format
Re: YOUTUBE TOP 100 MUSIC VIDEOS WEB RESOURCE
Version 18 posted to correct V17 thumbnail error
Hello jhb50,
thank you so much for this plugin. It is absolutely brilliant. This is the first plugin I used and I like it very much.
I had however a small problem. I used default settings and that ended up in the weekly list. And for this it requests a page with different dates. When it returns an error it will take it back one day. The problem I had was that I'm from the Netherlands an the returned error string is in dutch. So I had to add an additional possible error string. I changed this:
Into
If you ever create a new version could you please add this error string, would be much appreciated.
Into
Sure, but shouldn't there be a translation for the other phrase?
Yes there should be, but I have not encountered that error, so I dont kow the exact phrase. To fix this issue I turned on debugging and added log statements to the groovy file, then found the error phrase and used that. Is there perhaps a way to get the other errors? I also put the html request in a browser and examined the result and it resulted in the same error. So if you have an url for me which would result in the other error phrase then I can determine the exact translation. For me it is working fine for the moment, and if I ever encounter other errors then I will report them here.
For an even better solution I've posted V19 which removes the language dependency.
Thanks, just tried it and it works fine.
Ive noticed the videos take a longer time to load up, previously it used to load within 5 seconds, now its between 15 to 30 seconds
Version 20 Posted to honor YouTube Expiry date
jhb50 wrote:474 Alternative, 455 Blues, 471 Comedy/Spoken, 454 Country, 454 Easy Listening, 466 Electronic, 456 Folk, 462 International, 460 Jazz, 476 K-Pop, 465 Latin, 475 Metal, 458 New Age, 472 Pop, 470 R&B, 451 Rap, 461 Reggae, 465 Religious, 473 Rock, 463 Stage & Screen, 459 Vocal
This works great for Pop and Alternative codes, but when I tried the Country code 454 it only brought back 6 entries and non were country, I also noticed 454 is also listed as Easy Listening.
I'm using: http://www.youtubetop100.com?type=454&res=1080
Can you tell me where or how to find the correct code for country?
Great plugin and thanks for the work on it.
The codes were incorrect for country and religous. Corrected to:
// 474 Alternative, 455 Blues, 471 Comedy/Spoken, 453 Country, 454 Easy Listening, 466 Electronic, 456 Folk,
// 462 International, 460 Jazz, 476 K-Pop, 465 Latin, 475 Metal, 458 New Age, 472 Pop, 470 R&B, 451 Rap,
// 461 Reggae, 464 Religious, 473 Rock, 463 Stage & Screen, 459 Vocal
jhb50 wrote:The codes were incorrect for country and religous. Corrected to:
Thanks for the fast reply, that fixed it for me works perfect now!
This is not working anymore, please can you look at this further, i cant get enough of the Thrift Shop track!
I registered to firstly say thanks for a great plugin! However, it all of a sudden has gone kaput. I thought perhaps it was just a caching problem but it seems never to load up the videos. Thanks again, been loving it so far though.
Version 21 posted to support revised YouTube format
Thanks, I've posted common links to http://www.serviidb.com/plugin-api-name/youtubetop100
Either you can copy and paste or add sources automatically from the apps in my signature.
On ServiiDroid just search "top100" in add from ServiiDB to list this plugins contents.
Getting following errors with this plugin - any idea?
Npuser
- Code:
2013-06-17 19:08:43,072 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Starting parsing resource: http://www.youtubetop100.com
2013-06-17 19:08:43,072 DEBUG [FeedItemUrlExtractor] YouTubeTop100: Parsing with Top100 V21
2013-06-17 19:08:45,273 WARN [WebResourceParser] Plugin returned null container
2013-06-17 19:08:45,273 WARN [OnlineContentCacheDecorator] Could not store object to local cache (online_feeds): Value must not be null
2013-06-17 19:08:45,273 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
at org.serviio.library.online.OnlineLibraryManager.getEarliestItemExpiryDate(OnlineLibraryManager.java:313)
Npuser
Seems YouTube have stopped creating their Top 100 playlist.
that sucks. Hope its just a fluke, YT will bring it be back soon. Thanks for looking into though
Kind of odd http://www.youtube.com/playlist?list=MCUS.yyyymmdd does not work but mobile version http://m.youtube.com/playlist?list=MCUS.yyyymmdd does.
NPuser
NPuser
desktop version works with
http://www.youtube.com/playlist?gl=hl=e ... S.yyyymmdd
