Serviio does not detect my devices
narend
Post Mon Feb 11, 2013 12:50 am
I had setup Serviio successfully last year and was working fine. I had not used it in about 2 weeks. When I tried today from one of my devices, it did not see the Serviio server. I tried from a couple of other devices, and they had the same issue. I turned debugging on and saw the warning: "Error while retrieving renderer description: Cannot retrieve device description from http:...."
I opened up the TCP and UDP ports recommended and set the bound IP address to my PC, but that did not help.
I then uninstalled Serviio, restarted router and PC, installed Serviio. Now, Serviio does not even see my devices. I don't have the ability to manually add renderers.
Please help.
jazzopie
Post Tue Feb 12, 2013 6:48 am
Re: Serviio does not detect my devices
This is exactly the sameproblem I am having, which I posted earlier about. Not only has the add button dissapeared, but serviio no longer sees 2 out of 3 of my Blu-ray players. One is Samsung BD-5100 and the other 2 are BD-5300. They were all working fine, when the 2 on wireless stopped seeing serviio and servioo stopped seeing them, even though the wireless devices are still connecting the Blu-ray players to the Internet. Now check this out, I swapped my BD -5300 which was working with the BD-5100 which wasn't working ( a direct ethernet connection.) And the BD-5100 is working and the 2 BD-5300 (now both on wireless aren't working-so it's not the players themselves. I tried eveything including shutting down firewalls re-installing serviio - everything I can think of, plus every possible solution off these forums. I can't see any reason why the working wireless connections are suddenly not being seen by serviio and what happened to the ADD button on the renderer profiles. I even tried using the coaxle to Ethernet device I just bought and same thing, connected to the Internet, yet no serviio. I'm thinking of trying to connect it directly, I'm pretty sure that will work but I am still worried why the software no longer let's me add profiles and why connected wireless device can no longer be found.
Post Sun Feb 17, 2013 3:45 pm
Are your wired and wireless devices on the same subnet? The Add button is gone because it was just confusing - devices should appear in the list if everything is correctly set up.
narend
Post Sun Feb 17, 2013 10:10 pm
Yes, wired and wireless devices are all on the same subnet.
jazzopie
Post Mon Feb 18, 2013 8:23 am
Yes- same subnet
Post Mon Feb 18, 2013 12:21 pm
post detailed log of tarting the server up.
narend
Post Mon Feb 18, 2013 2:59 pm
Here's the debug log at restart:
2013-02-18 09:58:51,185 DEBUG [ServiioConsole] Initializing Serviio Console
2013-02-18 09:58:51,216 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-02-18 09:58:51,218 INFO [ServiioConsole] Starting Serviio Console
2013-02-18 09:58:51,302 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-02-18 09:58:51,381 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-02-18 09:59:01,594 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-02-18 09:59:01,595 DEBUG [ServiioConsole] Retrieving console settings
2013-02-18 09:59:11,621 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-02-18 09:59:11,641 INFO [Messages] Loaded console message bundle for locale: en
2013-02-18 09:59:13,749 DEBUG [ServiioConsole] Initializing Serviio Console
2013-02-18 09:59:13,767 DEBUG [ApplicationInstanceManager] Port is already taken. Notifying first instance.
2013-02-18 09:59:13,768 DEBUG [ApplicationInstanceManager] Successfully notified first instance.
2013-02-18 09:59:13,768 DEBUG [ApplicationInstanceManager] Shared key matched - new application instance found
narend
Post Mon Feb 18, 2013 3:14 pm
Please ignore the previous post. Here's the debug log. I filtered out some of the media discovery message to fit in this post.
2013-02-18 10:02:13,224 INFO [ServiioConsole] Leaving Serviio Console
2013-02-18 10:03:28,301 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2013-02-18 10:03:28,332 INFO [MediaServer] ------------------------------------------------------------------------
2013-02-18 10:03:28,332 INFO [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-02-18 10:03:28,332 INFO [MediaServer] Petr Nejedly 2009-2012
2013-02-18 10:03:28,332 INFO [MediaServer] http://www.serviio.org
2013-02-18 10:03:28,332 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-02-18 10:03:28,332 INFO [MediaServer] OS Windows NT (unknown) amd64 6.2
2013-02-18 10:03:28,332 INFO [MediaServer] File encoding: windows-1252
2013-02-18 10:03:28,332 INFO [MediaServer] Headless mode enabled: true
2013-02-18 10:03:28,332 INFO [MediaServer] User: DESKTOP$
2013-02-18 10:03:28,332 INFO [MediaServer] User home dir: C:\
2013-02-18 10:03:28,332 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-02-18 10:03:28,537 INFO [WebServer] Socket buffer set to 65535 bytes
2013-02-18 10:03:28,537 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-02-18 10:03:28,600 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-02-18 10:03:28,600 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-02-18 10:03:28,631 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-02-18 10:03:28,678 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2013-02-18 10:03:29,866 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2013-02-18 10:03:29,898 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2013-02-18 10:03:29,913 DEBUG [LicenseValidator] Validating license file (348 bytes)
2013-02-18 10:03:30,085 INFO [MediaServer] ------------------------------------------------------------------------
2013-02-18 10:03:30,085 INFO [MediaServer] License: FREE
2013-02-18 10:03:30,460 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-02-18 10:03:30,507 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2013-02-18 10:03:31,195 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-02-18 10:03:31,195 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2013-02-18 10:03:31,663 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-02-18 10:03:31,663 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2013-02-18 10:03:31,949 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-02-18 10:03:31,949 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2013-02-18 10:03:32,273 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-02-18 10:03:32,274 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2013-02-18 10:03:32,466 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-02-18 10:03:32,467 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2013-02-18 10:03:32,600 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-02-18 10:03:32,601 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2013-02-18 10:03:33,068 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-02-18 10:03:33,069 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2013-02-18 10:03:33,092 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-02-18 10:03:33,093 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2013-02-18 10:03:33,621 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-02-18 10:03:33,622 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2013-02-18 10:03:34,216 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-02-18 10:03:34,218 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2013-02-18 10:03:34,458 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-02-18 10:03:34,459 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2013-02-18 10:03:34,596 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-02-18 10:03:34,597 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2013-02-18 10:03:34,621 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-02-18 10:03:34,622 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2013-02-18 10:03:34,736 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-02-18 10:03:34,737 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2013-02-18 10:03:34,776 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-02-18 10:03:34,777 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2013-02-18 10:03:35,040 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-02-18 10:03:35,041 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2013-02-18 10:03:35,207 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-02-18 10:03:35,208 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2013-02-18 10:03:35,413 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-02-18 10:03:35,414 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2013-02-18 10:03:35,712 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-02-18 10:03:35,713 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2013-02-18 10:03:35,827 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-02-18 10:03:35,829 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2013-02-18 10:03:35,897 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-02-18 10:03:35,899 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2013-02-18 10:03:36,615 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-02-18 10:03:36,618 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011
2013-02-18 10:03:36,725 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-02-18 10:03:36,728 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2013-02-18 10:03:36,800 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-02-18 10:03:36,802 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2013-02-18 10:03:36,926 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-02-18 10:03:36,927 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2013-02-18 10:03:37,028 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-02-18 10:03:37,029 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2013-02-18 10:03:37,315 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-02-18 10:03:37,318 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2013-02-18 10:03:37,429 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-02-18 10:03:37,475 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-02-18 10:03:37,481 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2013-02-18 10:03:37,782 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-02-18 10:03:37,783 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo
2013-02-18 10:03:38,001 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-02-18 10:03:38,001 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2013-02-18 10:03:38,130 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-02-18 10:03:38,574 INFO [Device] Created UPnP Device with UUID: 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0, bound address: 192.168.1.5
2013-02-18 10:03:38,611 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-02-18 10:03:38,614 INFO [UpdateChecker] Checking if a new version is available
2013-02-18 10:03:38,614 INFO [PluginCompilerThread] Started looking for plugins
2013-02-18 10:03:38,624 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-02-18 10:03:38,630 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe
2013-02-18 10:03:38,888 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-02-18 10:03:38,889 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/dcraw.exe
2013-02-18 10:03:38,931 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-02-18 10:03:38,931 DEBUG [AbstractTranscodingDeliveryEngine] Deleting temporary transcoded files from: C:\Windows\TEMP\Serviio
2013-02-18 10:03:38,960 INFO [WebServer] WebServer starting on port 8895
2013-02-18 10:03:38,966 DEBUG [DiscoveryManager] UPNP device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0 (192.168.1.5) is available
2013-02-18 10:03:38,966 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-02-18 10:03:38,967 INFO [EventDispatcher] Starting EventDispatcher
2013-02-18 10:03:38,967 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-02-18 10:03:38,970 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-02-18 10:03:39,020 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth4 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.5, timeout = 0
2013-02-18 10:03:39,497 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-02-18 10:03:39,500 DEBUG [RendererSearchSender] Multicasting SSDP M-SEARCH using interface eth4 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.5, timeout = 0
2013-02-18 10:03:39,518 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-02-18 10:03:39,526 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.5:57416
2013-02-18 10:03:39,526 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:03:39,553 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.5:57416
2013-02-18 10:03:39,553 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:03:39,554 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.5:57416
2013-02-18 10:03:39,554 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:03:39,569 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-02-18 10:03:39,570 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.5, timeout = 0
2013-02-18 10:03:39,570 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0
2013-02-18 10:03:39,595 DEBUG [WebServer] Incoming connection from /192.168.1.104:34536
2013-02-18 10:03:39,595 DEBUG [WebServer] Incoming connection from /192.168.1.102:41264
2013-02-18 10:03:39,595 DEBUG [WebServer] Incoming connection from /192.168.1.100:45764
2013-02-18 10:03:39,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2013-02-18 10:03:39,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.104
2013-02-18 10:03:39,599 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:39,602 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0 from 192.168.1.102 (headers = [Host: 192.168.1.5:8895,User-Agent: Cisco-IMHTTP/1.8.225 UPNP/1.0 DLNADOC/1.50])
2013-02-18 10:03:39,602 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0 from 192.168.1.104 (headers = [Host: 192.168.1.5:8895,User-Agent: Cisco-IMHTTP/1.8.225 UPNP/1.0 DLNADOC/1.50])
2013-02-18 10:03:39,602 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0 from 192.168.1.100 (headers = [Host: 192.168.1.5:8895,User-Agent: Cisco-IMHTTP/1.8.225 UPNP/1.0 DLNADOC/1.50])
2013-02-18 10:03:39,602 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2013-02-18 10:03:39,603 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.5:8895,User-Agent: Cisco-IMHTTP/1.8.225 UPNP/1.0 DLNADOC/1.50]
2013-02-18 10:03:39,604 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2013-02-18 10:03:39,604 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:39,605 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.5:8895,User-Agent: Cisco-IMHTTP/1.8.225 UPNP/1.0 DLNADOC/1.50]
2013-02-18 10:03:39,605 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:39,605 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.104
2013-02-18 10:03:39,606 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.5:8895,User-Agent: Cisco-IMHTTP/1.8.225 UPNP/1.0 DLNADOC/1.50]
2013-02-18 10:03:39,607 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.104
2013-02-18 10:03:39,725 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.5:61360
2013-02-18 10:03:39,725 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:03:39,847 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-02-18 10:03:39,878 DEBUG [WebServer] Incoming connection from /192.168.1.104:34537
2013-02-18 10:03:39,878 DEBUG [WebServer] Incoming connection from /192.168.1.104:34538
2013-02-18 10:03:39,880 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.104
2013-02-18 10:03:39,881 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.104:
2013-02-18 10:03:39,881 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.104:
2013-02-18 10:03:39,882 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.104
2013-02-18 10:03:39,882 DEBUG [WebServer] Incoming connection from /192.168.1.102:41265
2013-02-18 10:03:39,883 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2013-02-18 10:03:39,883 DEBUG [WebServer] Incoming connection from /192.168.1.102:41266
2013-02-18 10:03:39,884 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2013-02-18 10:03:39,885 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.102:
2013-02-18 10:03:39,885 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2013-02-18 10:03:39,885 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.102:
2013-02-18 10:03:39,890 DEBUG [WebServer] Incoming connection from /192.168.1.100:45765
2013-02-18 10:03:39,892 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:39,893 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2013-02-18 10:03:39,909 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-02-18 10:03:39,943 DEBUG [WebServer] Incoming connection from /192.168.1.100:45766
2013-02-18 10:03:39,944 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:39,946 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSortCapabilities"' from 192.168.1.100:
2013-02-18 10:03:39,946 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:39,950 DEBUG [WebServer] Incoming connection from /192.168.1.100:45767
2013-02-18 10:03:39,951 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:39,952 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSearchCapabilities"' from 192.168.1.100:
2013-02-18 10:03:39,952 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:40,007 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-02-18 10:03:40,008 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2013-02-18 10:03:40,291 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.5:61360
2013-02-18 10:03:40,291 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:03:40,882 DEBUG [WebServer] Incoming connection from /192.168.1.104:34539
2013-02-18 10:03:40,883 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.104
2013-02-18 10:03:40,884 DEBUG [WebServer] Incoming connection from /192.168.1.102:41267
2013-02-18 10:03:40,884 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2013-02-18 10:03:40,884 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=91f92e1d-fe8c-4207-a60a-dee9fc6ca355) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.1.104:9999/event/a4046f4 ... 252eeb4252
2013-02-18 10:03:40,884 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.102
2013-02-18 10:03:40,885 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2013-02-18 10:03:40,885 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=ee6f07d3-8f19-469f-8d0a-c07633834407) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.1.102:9999/event/a382ca0 ... 5fd42d7338
2013-02-18 10:03:40,892 DEBUG [WebServer] Incoming connection from /192.168.1.100:45768
2013-02-18 10:03:40,898 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.100
2013-02-18 10:03:40,898 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2013-02-18 10:03:40,899 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=87723c86-e761-4665-a256-d28e34cb1b10) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.1.100:9999/event/ad78044 ... 5fd42c93b6
2013-02-18 10:03:40,972 DEBUG [EventDispatcher] Sending event notification #0 for subscription 87723c86-e761-4665-a256-d28e34cb1b10 to endpoint http://192.168.1.100:9999/event/ad78044 ... 5fd42c93b6
2013-02-18 10:03:40,981 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.100:9999
2013-02-18 10:03:40,999 DEBUG [EventDispatcher] Event notification sent and received successfully
2013-02-18 10:03:41,000 DEBUG [EventDispatcher] Sending event notification #0 for subscription 91f92e1d-fe8c-4207-a60a-dee9fc6ca355 to endpoint http://192.168.1.104:9999/event/a4046f4 ... 252eeb4252
2013-02-18 10:03:41,000 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.104:9999
2013-02-18 10:03:41,016 DEBUG [EventDispatcher] Event notification sent and received successfully
2013-02-18 10:03:41,016 DEBUG [EventDispatcher] Sending event notification #0 for subscription ee6f07d3-8f19-469f-8d0a-c07633834407 to endpoint http://192.168.1.102:9999/event/a382ca0 ... 5fd42d7338
2013-02-18 10:03:41,016 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.102:9999
2013-02-18 10:03:41,031 DEBUG [EventDispatcher] Event notification sent and received successfully
2013-02-18 10:03:41,438 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-02-18 10:03:42,725 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.5:61360
2013-02-18 10:03:42,725 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:03:43,292 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.5:61360
2013-02-18 10:03:43,292 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:03:45,520 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2013-02-18 10:03:49,408 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-02-18 10:03:49,408 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.5, timeout = 0
2013-02-18 10:03:49,409 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0
2013-02-18 10:03:51,211 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:07 (advertisement duration is 1800 sec.)
2013-02-18 10:03:56,224 DEBUG [ServiioConsole] Initializing Serviio Console
2013-02-18 10:03:56,241 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-02-18 10:03:56,242 INFO [ServiioConsole] Starting Serviio Console
2013-02-18 10:03:56,339 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-02-18 10:03:56,409 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-02-18 10:03:57,108 DEBUG [ServiioConsole] Retrieving console settings
2013-02-18 10:03:57,194 DEBUG [ServiioConsole] Setting console locale to be: en
2013-02-18 10:03:57,201 INFO [Messages] Loaded console message bundle for locale: en
2013-02-18 10:03:57,285 DEBUG [ServiioFrameView] Initializing main frame
2013-02-18 10:03:57,321 DEBUG [ServiioFrameView] System tray is supported
2013-02-18 10:03:57,476 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-02-18 10:03:57,882 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-02-18 10:03:57,913 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2013-02-18 10:03:57,989 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-02-18 10:03:58,618 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2013-02-18 10:03:58,818 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups
2013-02-18 10:03:59,122 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-02-18 10:03:59,148 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-02-18 10:03:59,648 DEBUG [DiscoveryAdvertisementNotifier] Found 1 network interfaces to advertise on
2013-02-18 10:03:59,648 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth4 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.5, timeout = 0
2013-02-18 10:03:59,648 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0
2013-02-18 10:03:59,788 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-02-18 10:03:59,788 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=0, titleKey=pc5dczc_media_library, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = null
2013-02-18 10:03:59,819 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A, titleKey=audio, class=CONTAINER, cacheRegion=no_cache, browsable = null, editable = true
2013-02-18 10:03:59,819 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_A, titleKey=artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-02-18 10:03:59,819 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,835 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,835 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,851 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForArtistAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,851 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=AL_A, titleKey=album_artists, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-02-18 10:03:59,866 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,866 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListAlbumArtistsForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=ART, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,882 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForAlbumArtistCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,898 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,898 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_F, titleKey=folders, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-02-18 10:03:59,913 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioFoldersByNameCommand, containerClass=STORAGE_FOLDER, itemClass=MUSIC_TRACK, idPrefix=FOL, recursive=true, cacheRegion=local_default
2013-02-18 10:03:59,913 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_G, titleKey=genres, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-02-18 10:03:59,913 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAudioGenresByNameCommand, containerClass=MUSIC_GENRE, itemClass=null, idPrefix=GEN, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,929 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForGenreCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,929 DEBUG [ContentDirectoryDefinitionParser] Found Container node with attributes: id=A_C, titleKey=composers, class=CONTAINER, cacheRegion=local_default, browsable = null, editable = true
2013-02-18 10:03:59,944 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposerInitialsCommand, containerClass=CONTAINER, itemClass=null, idPrefix=INI, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,944 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.person.ListComposersForInitialCommand, containerClass=MUSIC_ARTIST, itemClass=null, idPrefix=COM, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,960 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListAlbumsForComposerCommand, containerClass=MUSIC_ALBUM, itemClass=null, idPrefix=A, recursive=false, cacheRegion=local_default
2013-02-18 10:03:59,960 DEBUG [ContentDirectoryDefinitionParser] Found Action node with attributes: command=org.serviio.upnp.service.contentdirectory.command.audio.ListSongsForComposerAndAlbumCommand, containerClass=null, itemClass=MUSIC_TRACK, idPrefix=S, recursive=false, cacheRegion=local_default
2013-02-18 10:04:00,523 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-02-18 10:04:00,585 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.5:3108
2013-02-18 10:04:00,585 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:00,585 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:3108
2013-02-18 10:04:00,601 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:3108
2013-02-18 10:04:00,601 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.5:60927
2013-02-18 10:04:00,601 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:00,601 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:60927
2013-02-18 10:04:00,898 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.5:64223
2013-02-18 10:04:00,898 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:01,156 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-02-18 10:04:01,158 DEBUG [AccessGroupDAOImpl] Reading all AccessGroups for Repository (id = 1)
2013-02-18 10:04:01,159 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-02-18 10:04:01,183 DEBUG [ServiioConsole] Reading application data
2013-02-18 10:04:01,190 DEBUG [RepositoryView$LibraryStatusCheckerThread] Starting library status checking thread
2013-02-18 10:04:01,204 DEBUG [WebServer] Incoming connection from /192.168.1.5:49358
2013-02-18 10:04:01,205 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:01,207 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0 from 192.168.1.5 (headers = [User-Agent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.3.0,Host: 192.168.1.5:8895])
2013-02-18 10:04:01,207 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:01,209 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [User-Agent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.3.0,Host: 192.168.1.5:8895]
2013-02-18 10:04:01,217 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:01,222 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Generic DLNA profile'
2013-02-18 10:04:01,329 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:01,330 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2013-02-18 10:04:01,340 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-02-18 10:04:01,357 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:01,359 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2013-02-18 10:04:01,361 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-02-18 10:04:01,363 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:01,364 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2013-02-18 10:04:01,377 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2013-02-18 10:04:01,525 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:14 (advertisement duration is 1800 sec.)
2013-02-18 10:04:05,525 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-02-18 10:04:05,525 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-02-18 10:04:05,525 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-02-18 10:04:05,532 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-02-18 10:04:05,532 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-02-18 10:04:05,532 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-02-18 10:04:05,532 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-02-18 10:04:05,534 DEBUG [LibraryUpdatesCheckerThread] Looking for removed playlist files in repository: D:\Movies\English Movies
2013-02-18 10:04:05,535 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Movies\English Movies
2013-02-18 10:04:05,537 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-02-18 10:04:05,537 DEBUG [PlaylistDAOImpl] Reading Playlists for Repository (id = 1)
2013-02-18 10:04:05,549 DEBUG [LibraryAdditionsCheckerThread] Found file 'Indiana.Jones.and.the.Raiders.of.the.Lost.Ark.mkv', checking if it's already in the Library
2013-02-18 10:04:05,551 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Indiana.Jones.and.the.Raiders.of.the.Lost.Ark.mkv
2013-02-18 10:04:05,551 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Movies\English Movies\Indiana.Jones.and.the.Raiders.of.the.Lost.Ark.mkv, ignore case: true
2013-02-18 10:04:05,587 DEBUG [LibraryUpdatesCheckerThread] Looking for removed/updated files in repository: D:\Movies\English Movies
2013-02-18 10:04:05,587 DEBUG [MediaItemDAOImpl] Reading MediaItems for Repository (id = 1)
2013-02-18 10:04:05,723 DEBUG [MediaItemDAOImpl] Media item Indiana.Jones.and.the.Raiders.of.the.Lost.Ark.mkv already exists in DB
2013-02-18 10:04:05,728 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2013-02-18 10:04:05,731 DEBUG [LibraryAdditionsCheckerThread] Found file 'Live.Free.Or.Die.Hard.mkv', checking if it's already in the Library
2013-02-18 10:04:05,731 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Live.Free.Or.Die.Hard.mkv
2013-02-18 10:04:05,731 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Movies\English Movies\Live.Free.Or.Die.Hard.mkv, ignore case: true
2013-02-18 10:04:05,733 DEBUG [MediaItemDAOImpl] Media item Live.Free.Or.Die.Hard.mkv already exists in DB
2013-02-18 10:04:05,749 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-02-18 10:04:05,755 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type AUDIO
2013-02-18 10:04:05,761 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type VIDEO
2013-02-18 10:04:05,762 DEBUG [MetadataExtractorConfigDAOImpl] Reading a list of Extractor configuration for type IMAGE
2013-02-18 10:04:05,764 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor EMBEDDED
2013-02-18 10:04:05,798 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 11) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,800 DEBUG [MediaItemDAOImpl] Getting file of media item 2
2013-02-18 10:04:05,800 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor EMBEDDED
2013-02-18 10:04:05,801 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 2) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,802 DEBUG [MediaItemDAOImpl] Getting file of media item 3
2013-02-18 10:04:05,803 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor EMBEDDED
2013-02-18 10:04:05,804 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 3) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,805 DEBUG [MediaItemDAOImpl] Getting file of media item 4
2013-02-18 10:04:05,805 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor EMBEDDED
2013-02-18 10:04:05,806 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 4) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,806 DEBUG [MediaItemDAOImpl] Getting file of media item 5
2013-02-18 10:04:05,807 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor EMBEDDED
2013-02-18 10:04:05,808 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 5) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,809 DEBUG [MediaItemDAOImpl] Getting file of media item 6
2013-02-18 10:04:05,810 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor EMBEDDED
2013-02-18 10:04:05,810 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 6) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,813 DEBUG [MediaItemDAOImpl] Getting file of media item 7
2013-02-18 10:04:05,814 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor EMBEDDED
2013-02-18 10:04:05,815 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 7) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,816 DEBUG [MediaItemDAOImpl] Getting file of media item 8
2013-02-18 10:04:05,817 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 8) and extractor EMBEDDED
2013-02-18 10:04:05,818 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 8) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,820 DEBUG [MediaItemDAOImpl] Getting file of media item 9
2013-02-18 10:04:05,821 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor EMBEDDED
2013-02-18 10:04:05,821 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 9) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,822 DEBUG [MediaItemDAOImpl] Getting file of media item 10
2013-02-18 10:04:05,823 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor EMBEDDED
2013-02-18 10:04:05,824 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 10) and extractor COVER_IMAGE_IN_FOLDER
2013-02-18 10:04:05,825 DEBUG [MediaItemDAOImpl] Reading dirty MediaItems for Repository (id = 1)
2013-02-18 10:04:05,844 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-02-18 10:04:54,865 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.5:3108
2013-02-18 10:04:54,865 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:54,866 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.5:3108
2013-02-18 10:04:54,866 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:04:54,866 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:3108
2013-02-18 10:04:54,867 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:3108
2013-02-18 10:05:01,587 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.5:60927
2013-02-18 10:05:01,587 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:05:01,588 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target upnp:rootdevice from address /192.168.1.5:60927
2013-02-18 10:05:01,589 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.5
2013-02-18 10:05:01,589 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:60927
2013-02-18 10:05:01,590 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.1.5:60927
2013-02-18 10:05:05,529 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-02-18 10:05:05,529 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Post Mon Feb 18, 2013 4:59 pm
what are the IPs of your devices?
narend
Post Mon Feb 18, 2013 9:19 pm
192.168.1.4
192.168.1.8
192.168.1.10
The last device (192.168.1.10) is listed on Serviio, but that device does not see Serviio.
Post Mon Feb 18, 2013 10:50 pm
no mention of these in the log.... it looks like a firewall or antivirus blocking the TCP 8895 port.
narend
Post Mon Feb 18, 2013 11:17 pm
I've previously created inbound rules for TCP 8895 and UDP 1900 in Windows Firewall. Private and Domain profiles are enabled.
Antivirus is Windows Defender and I couldn't find where it could block those ports.
Post Mon Feb 18, 2013 11:29 pm
Can you open this in a browser on the Serviio box?
http://192.168.1.5:8895/deviceDescription/4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0
If yes, you should be able to open it from another PC on your network.
narend
Post Tue Feb 19, 2013 12:20 am
It worked. That URL took me to a page with XML code.
Post Tue Feb 19, 2013 11:38 am
narend wrote:It worked. That URL took me to a page with XML code.
Does it work from another device on the network?
narend
Post Tue Feb 19, 2013 10:43 pm
Also worked from a laptop on the network.
Post Tue Feb 19, 2013 11:30 pm
so it might be something with multicasting not working properly. Might be down to router, network card (drivers)... also search for IGMP on this forum
Users browsing this forum: Baidu [Spider], Google [Bot] and 35 guests
