Changing audio out to mp3
dangles
Post Mon Feb 18, 2013 11:26 pm
I am a simpleton with this type of software and I have what is, hopefully, a fairly simple question:
How can i modify the Panasonic Viera St50 profile in a way that would result in the output audio of transcoded files to be mp3? I have a soundbar connected to my tv through digital audio out, and right now any avi file that is transcoded leaves my soundbar saying it can't play the audio. I believe it will play mp3 audio and whatever the default audio is in an mp4 file as well (my tv does not require the mp4's transcoded to play properly and the audio always works).
Thanks for any help
grolschie
Post Tue Feb 19, 2013 10:15 pm
Re: Changing audio out to mp3
Maybe find the Panasonic profiles in profiles.xml (there are two: "viera2011" and "viera2011a") and change targetACodec="ac3" to targetACodec="mp3" wherever you see it (in those 2 profiles). I'm not sure if this will work, but you could try it. You will need to restart Serviio after making the changes. Any problems, you could reverse the changes and restart Serviio.
dangles
Post Wed Feb 20, 2013 5:12 am
grolschie:
thank you- it worked like a charm. appreciate the response!
