Java 7 update 15 broke serviio
slimf
Post Tue Feb 19, 2013 11:39 pm
I just updated to the latest Java, and now Serviio wont work (7 update 15)
Anyone else having the same problem?
Windows 8.
pizzaguy541
Post Wed Feb 20, 2013 12:43 am
Re: Java 7 update 15 broke serviio
Have you tried to re-install serviio?
Torturer
Post Thu Feb 21, 2013 5:50 pm
I have exactly the same problem occur today.
Windows 8 and after the auto update jre7 update 15, serviio complains about not being able to find the EXE4J_JAVA_HOME.
I tried to set the environment variable manually, but that did not work.
Then I tried to re-install serviio and still getting the same error.
pizzaguy541
Post Fri Feb 22, 2013 12:34 am
I've re-installed serviio and then rebooted the computer. Everything is working perfectly.
Running serviio on Windows 8 32-bit with java 7 update 15.
grolschie
Post Fri Feb 22, 2013 2:01 am
slimf and Torturer, do you have a 32bit or 64bit Java install?
Torturer
Post Fri Feb 22, 2013 4:51 am
Windows 8 32-bit.
I have tried simply reinstalling serviio over the existing install, and then uninstalling completely and reinstalling. Still no effect. Serviio still complains about the exe4j_java_home not being found.
grolschie
Post Fri Feb 22, 2013 10:25 am
Thanks. I was wondering if there might be an issue with the 64bit version (only) of Java and Serviio, but you would have the 32bit version... so anyways, maybe Zip or someone else will see this thread and be able to help.
Post Fri Feb 22, 2013 12:37 pm
if your OS is 64 bit, you need 64 bit Java, for 32 bit OS you need 32 bit Java
I'd recommend you to have only 1 version of Java on your system, if possible - so try removing all other Java versions apart for the newest one, if it still doesn't work, remove all java altogehter and then install the newest one again
crackedtooth
Post Fri Feb 22, 2013 12:40 pm
@zip
it was never an issue in the past untill the most recent java
and most people with 64bit windows need both java installed
worked fine up to java 14
Setting variable in environment tables does not fixit.
Other java programs run fine for me, just serviio console does not
crackedtooth
Post Fri Feb 22, 2013 12:47 pm
THE FIX
UNINSTALL JAVA (both versions)
Do NOT use the online installer.
Use the offline full install .exe from here:
http://www.java.com/en/download/manual.jsp
Install 64 bit.. than install 32 bit..
sorted it for me.
Torturer
Post Fri Feb 22, 2013 3:28 pm
I have 32bit OS and 32bit java.
If I have to now reinstall java, why is it that only Serviio is affected in such a manner that it requires this action to be taken?
Just curious.
Post Fri Feb 22, 2013 4:10 pm
It uses exe4j tool to generate the service executable Java wrapper. It looks at registry and/or the env variable to figure out where your Java is. If the registry is corrupted by different Java installations, you'll get this error.
macleod
Post Sat Feb 23, 2013 10:43 pm
morning, i have an issue with Java 15 as well. Serviio was detected fine with my LG LW6500 tv until the install. Serviio executes and runs fine on my laptop (has always worked pretty much flawlessly, thanks guys!) however TV can no longer detect it as the DLNA option.
Restarts, reinstalls etc no luck so far, was going to test with another media server but noticed others with same issue with the latest Java release.
I am roll back to the Java se 7 13 release as i can't locate their 14 version on their archive or other sites.
It seemed to mess with AirVideo too until i did a fresh install of that as well.
Oddly enough, Serviio still identifies the TV's IP address as OK from the console, however the TV will not bring up being able to access a DLNA server at all anymore, hence i didn't know if TV issue or serviio?
a pile more reinstalls i would guess?
macleod
Post Sun Feb 24, 2013 2:32 am
reinstalled ye olde Nero Mediahome default that comes with LG tv's and the TV picks it up to access fine.
Serviio still picks up the TV on it's IP address, however the TV (LW6500 australia w latest firmware) still won't recognise it running as an accessible DLNA input.
i dropped back to Java se 7 v13, no change, reupdated after full install back to java 15, no change.
seems odd Serviio is sensing the renderer on the TV fine but not vice versa. Perhaps a full reset of the TV back to factory?
will strip out serviio, java back to v7 or v6 perhaps and work way up from their using manual installs of java each time. frickin' java..... :roll:
santaregina
Post Sun Mar 03, 2013 5:57 pm
thanks to crackedtooth: :D
UNINSTALLed JAVA (both versions)
Install 64 bit.
worked for me too.
TestFactor
Post Wed Mar 06, 2013 3:39 pm
I reinstalled java as above, which did fix the problem, but then Oracle put out another update and it happened again. Uninstalling the 64 bit version and reinstalling it fixed the issue. It actually looked as if the 64 bit version was corrupt after the update as I couldn't get it to run at all. Go Oracle!
Post Wed Mar 06, 2013 5:03 pm
If it happens again, try this: viewtopic.php?f=5&t=95&start=20
crackedtooth
Post Fri Mar 08, 2013 10:40 am
zip wrote:If it happens again, try this: viewtopic.php?f=5&t=95&start=20
The NUISANCE is , that althought he uninstall and reinstall of new java version works...
its a pain and not nice to have to do , especially since most java build updates come sooner now.
both java update 16 AND 17 i could not use the update function.... serviio console wont work....
Also.. serviio is the ONLY java solution unable to find the new java version when using normal java update
TWS by interactive brokers for example has no issues at all...
Maybe idea to try and get fixed path maybe for java? or way for user to modify it?
Cause i LOVE serviio... but getting annoyed i have to close a lot of long running items just to do a java update and get it to work with serviio
Post Fri Mar 08, 2013 11:03 am
Did you attempt the linked suggestion? I can do nothing without you guys giving me some details which, in this case, I can pass onto the developers of the Java wrapper.
crackedtooth
Post Fri Mar 08, 2013 6:59 pm
zip wrote:Did you attempt the linked suggestion? I can do nothing without you guys giving me some details which, in this case, I can pass onto the developers of the Java wrapper.
for me its fixed for update 17 now with the uninstall, offline reinstall for java
"please ask a customer to start the executable from the command line with the argument
/create-i4j-log
and send me the log file."
that one you want someone to try though, correct?
Needs to be done when the error is there though.
I can try it with the next java update , hopefully someone can try it before that time... do not intend to roll back java to try, have too much stuff running 24/7, takes me a long time to reboot and restart all
Users browsing this forum: No registered users and 74 guests
