Where does Serviio store it's settings?
LucianH
Post Tue Jan 15, 2013 9:31 pm
To repeat the title - where does Serviio store it's settings? Are they contained in a specific folder/file or are they registry settings? The reason for asking is that I want to backup/restore the settings if possible.
Post Tue Jan 15, 2013 9:39 pm
Re: Where does Serviio store it's settings?
It's all in the sub folder in the installation directory called 'library'
LucianH
Post Tue Jan 15, 2013 9:41 pm
will wrote:It's all in the sub folder in the installation directory called 'library'
Many thanks
Onur
Post Thu Feb 21, 2013 8:48 pm
I searched the forum for backing up serviio database and i found this thread.
I am using windows-7 and i have installed ubuntu linux (wubi) in the 2nd partiton of my hdd. I have installed serviio to linux and copied the library folder from windows version to linux one but it doesnt see my library. Maybe the problem in local library section is related with drive paths but it doesnt show any online library entry either.
Can anyone help me about this problem?
Post Fri Feb 22, 2013 2:03 pm
I'm not sure if copying Windows library to Linux will work. You should just set it up again.
