Bug with JAVA 7 update 15 32+64bit ??
crackedtooth
Post Fri Feb 22, 2013 11:37 am
After installing the java 7 updates 15 32 bit and 64bit i get the error : cant find JVM when windows boots for the serviio console.
Is this a known issue?
Worked fine with earlier versions up to java 7 update 14.
Maybe vmoptions file edit? or no such easy fix ?
Windows 7 , 64 bit.
java 7 versoion 15 , both 32 and 64 bit installed.
Servio console on windows (connecting to external linux NAS).
crackedtooth
Post Fri Feb 22, 2013 11:39 am
Re: Bug with JAVA 7 update 15 32+64bit ??
THE FIX
UNINSTALL JAVA (both versions)
Do NOT use the online installer.
Use the offline full install .exe from here:
http://www.java.com/en/download/manual.jsp
Install 64 bit.. than install 32 bit..
sorted it for me.
