Change Serviio Ports
mmarauder
Post Fri Feb 22, 2013 4:59 pm
A feature I think could be quite helpful would be the ability to change the port that mediabrowser runs on. I have multiple machines running serviio making it difficult since they all use the same port for mediabrowser. Also, as a security issue since it is an open public port it would be nice to change to something unique.
patters
Post Wed Feb 27, 2013 8:06 am
Re: Change Serviio Ports
Can't you achieve both of those things by setting up some port forwards on your router?
Return to Feature requests
