MP4 files won't always stream on Samsung TV
carmens
Post Sat Feb 23, 2013 12:12 am
I've downloaded the most recent version of Serviio and have installed it onto my Ubuntu machine. I have also installed FFmpeg and OpenJDK through the Synaptic Package Manager. I'm trying to stream a 53 minute mp4 file on my Samsung un55d6000 TV. The audio and video start normally but after 13 minutes, the file stops playing
Below is the output from ffmpeg. Any thoughts what would cause it to fail?
Thank you
FFmpeg version SVN-r0.5.9-4:0.5.9-0ubuntu0.10.04.3, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --extra-version=4:0.5.9-0ubuntu0.10.04.3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libdc1394 --enable-shared --disable-static
libavutil 49.15. 0 / 49.15. 0
libavcodec 52.20. 1 / 52.20. 1
libavformat 52.31. 0 / 52.31. 0
libavdevice 52. 1. 0 / 52. 1. 0
libavfilter 0. 4. 0 / 0. 4. 0
libswscale 0. 7. 1 / 0. 7. 1
built on Jan 24 2013 19:42:21, gcc: 4.4.3
Seems stream 1 codec frame rate differs from container frame rate: 47.95 (48000/1001) -> 23.98 (24000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'two.mp4':
Duration: 00:53:34.33, start: 0.000000, bitrate: 288 kb/s
Stream #0.0(und): Audio: aac, 48000 Hz, stereo, s16
Stream #0.1(und): Video: h264, yuv420p, 720x404, 23.98 tbr, 23.98 tbn, 47.95 tbc
grolschie
Post Sat Feb 23, 2013 5:00 am
Re: MP4 files won't always stream on Samsung TV
For starters, the ffmpeg version looks quite old. I suggest obtaining the latest version.
Users browsing this forum: Baidu [Spider] and 48 guests
