[SOLVED] WMV3 file problems on Sony Bravia KDL 2010
srg84
Post Mon Feb 25, 2013 4:23 pm
Hi, I have Sony Bravia KDL 2010 Model, everything goes perfect except one type of file:
I have this profile to see GoPRo Hero 2 Videos (extending Sony Bravia 2010), and i tried to decode this wmv with no luck...
The sound is ok but the video keeps black, any suggestions?.
Any help will be apreciated
ffmpeg.exe -i "Descenso
 en la sierra.wmv"
g-config
[wmv3 @ 013F6C40] Extra data: 8 bits left, value: 0
[asf @ 003DB9A0] Stream #0: not enough frames to estimate rate; consider increas
ing probesize
Guessed Channel Layout for  Input Stream #0.1 : stereo
Input #0, asf, from 'Descenso en la sierra.wmv':
    WMFSDKVersion   : 12.0.7601.17514
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
  Duration: 00:04:06.82, start: 0.000000, bitrate: 22784 kb/s
    Stream #0:0: Video: mjpeg, yuvj420p, 1920x1080, 90k tbr, 90k tbn, 90k tbc
      comment         : Movie/video screen capture
    Stream #0:1(eng): Audio: wmav2 (a[1][0][0] / 0x0161), 48000 Hz, stereo, s16,
 192 kb/s
    Stream #0:2(eng): Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 1920x1080
, 24000 kb/s, 29.97 tbr, 1k tbn, 1k tbc
2013-02-25 17:13:39,376 DEBUG [VideoDeliveryEngine] Delivering item '530' for client 'IPAddress=/192.168.0.10, Profile=Sergio Sony Bravia'
2013-02-25 17:13:39,376 DEBUG [VideoDeliveryEngine] Delivering file 'Descenso en la sierra.wmv' using transcoding
2013-02-25 17:13:39,376 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.0.10, Profile=Sergio Sony Bravia'
2013-02-25 17:13:39,376 DEBUG [FileBasedTranscodingDeliveryStrategy] Transcoded file 'C:\TEMPOR~1\Serviio\transcoding-temp-530-custom-ORIGINAL.stf' is complete, sending simple stream
2013-02-25 17:13:39,376 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Descenso en la sierra.wmv: MPEG_TS_SD_EU_ISO
2013-02-25 17:13:39,376 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Descenso en la sierra.wmv: MPEG_TS_SD_NA_ISO
2013-02-25 17:13:39,377 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Descenso en la sierra.wmv: MPEG_TS_SD_KO_ISO
   <Profile id="custom" name="Sergio Sony Bravia" extendsProfileId="sony2010">
    <!-- This is a custom profile to force transcoding with lower bitrate of GoPro media files -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="15000" targetACodec="ac3">
            <Matches container="mp4" vCodec="h264" aCodec="aac" />
      <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="15000" targetACodec="ac3" forceVTranscoding="true" >
            <Matches container="asf" vCodec="mjpeg" aCodec="wmav2" />
srg84
Post Tue Feb 26, 2013 7:52 am
Re: WMV3 file problems on Sony Bravia KDL 2010
I think the problem is that the program thinks he is transcoding fine the video.
Maybe the video stream transcoded is not the main video stream?
Stream #0:2(eng): Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 1920x1080, 24000 kb/s, 29.97 tbr, 1k tbn, 1k tbc
This videos are made with Windows Live Movie Maker, in theory there should be only one video stream :? .
Any suggestions?
srg84
Post Tue Feb 26, 2013 4:52 pm
Ok, i have the same problem as:
viewtopic.php?f=4&t=9041
I will try to remove the mjpeg stream with GDSMUX :twisted:
srg84
Post Tue Mar 05, 2013 6:33 pm
SOLVED 8-)
Users browsing this forum: Baidu [Spider] and 28 guests
