XBOX 360 Not playing sound on MKV Files - MAC User
aaronoafc
Post Mon Feb 25, 2013 7:01 pm
Hi guys,
so I just installed serviio on my macbook pro retina, managed to get it working with my xbox and have played an mp4 file perfectly fine however all of my .mlv files seem to play with no sound, any ideas?
Thanks in advance
grolschie
Post Mon Feb 25, 2013 7:33 pm
Re: XBOX 360 Not playing sound on MKV Files - MAC User
Can you please provde the output of: ffmpeg -i <filename>
aaronoafc
Post Mon Feb 25, 2013 7:47 pm
Sorry how do I do that? I'm on a mac too just incase its diff from pc :)
aaronoafc
Post Mon Feb 25, 2013 8:16 pm
grolschie wrote:Can you please provde the output of: ffmpeg -i <filename>
Nevermind - got it, is this what you're after?
built on Jul 10 2012 22:12:54 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
Input #0, matroska,webm, from '/Users/file.mkv':
creation_time : 1970-01-01 00:00:00
Duration: 00:41:24.28, start: 0.000000, bitrate: 3776 kb/s
Stream #0:0: Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
Stream #0:1(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
grolschie
Post Tue Feb 26, 2013 12:36 am
Hmmm... I'm not sure why there's no sound, since mkv is supposed to transcoded to asf with WMAV2 audio.
aaronoafc
Post Tue Feb 26, 2013 7:33 am
:( It's driving me nuts
aaronoafc
Post Tue Feb 26, 2013 10:49 am
Anyone else have any ideas? I've tried a few MKV files (other series + films) and its still the same! worst comes to worst I can convert to something else (best application to do so????) but I'd rather not it possible
Users browsing this forum: Baidu [Spider] and 16 guests
