Transcoding/FFMpeg to FLV only uses 1 core
I see that FFMpeg only uses 1 CPU core, altough I've set it to 4 in the Serviio Console.
How can I chang the FFMpeg uses all cores?
Thanks!
patters wrote:The example you link to is encoding H.264 in a Flash container. It's not the same thing as the Flash video codec. The Flash video encoder within FFmpeg is not multithreaded. Serviio doesn't currently support encoding to H.264, and the FFmpeg that's bundled is not compiled with libx264 included.
patters wrote:If the original file is H.264 in mkv and you want to play it in the Media Browser try setting the quality to Original. That way the file is only remuxed, not transcoded. However, if you're trying to view content remotely while away from home, it's unlikely that your home internet connection will have enough upstream bandwidth to send the original quality stream. This is why the Flash encoder is used: Flash players like FlowPlayer don't support many formats, so Flash video is the next alternative (and computationally cheaper to encode than H.264).
Users browsing this forum: Google [Bot] and 39 guests
