When I stream 720p/BlueRay movies keeps loading/stopping
DlllonJ
Post Wed Feb 27, 2013 7:33 pm
Hi guys
I've recently downloaded SERVIIO and started streaming. However the movies I want to stream are BlueRay/720p Rips, when I try to watch them through my Xbox 360 they keep stopping. It seems like they're loading.
Does anybody know if there's anything I can do about this?
khurram23
Post Wed Feb 27, 2013 7:51 pm
Re: When I stream 720p/BlueRay movies keeps loading/stopping
When you say they keep stopping/loading, do you mean they stop and play from beginning or is it just a buffering issue?
Describe your setup please.
I would guess either you don't have enough bandwidth to cover the stream from your computer to xbox (i.e. xbox 360 has a wireless G adapter and not a N or wired) or your computer isn't fast enough to transcode the movie.
Suggestions:
Assuming your xbox is connected via Wireless N adapter or Wired network:
- Select and Play the movie from Xbox.
- Pause it
- Wait about 15mins. (don't do anything on xbox). This will allow your computer to trancode few mins worth.
- Play on xbox
- Does it play normally (for few mins)?
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
DlllonJ
Post Wed Feb 27, 2013 8:50 pm
khurram23 wrote:When you say they keep stopping/loading, do you mean they stop and play from beginning or is it just a buffering issue?
Suggestions:
- Pause it
- Play on xbox
No they don't play from the beginning, so it will be a buffering issue.
I'm using a wired xbox connection directly into my router which is a VMDG280.
Connection details - Download is 20.71mbps Upload is 1.13mbps Ping 27ms.
No it doesn't play normally if I let it load for 15 minutes, it plays for one second then pauses for five.
Any Ideas?
khurram23
Post Wed Feb 27, 2013 9:15 pm
Still feels like buffering issue, which means either there isn't enough bandwidth between your xbox and computer or your computer can't transcode fast enough.
Have you tried playing a simple xvid/avi? Does that play normally or behave the same way?
Is your computer connected via wired or wireless?
Post detailed log. http://forum.serviio.org/viewtopic.php?f=5&t=7
DlllonJ
Post Wed Feb 27, 2013 9:34 pm
khurram23 wrote:Still feels like buffering issue, which means either there isn't enough bandwidth between your xbox and computer or your computer can't transcode fast enough.
It's having no trouble playing BlueRay MP4's or regular AVI files, but when I play BlueRay MKV files it does this buffer issue?
Am I missing a plugin or something?
My laptop is connected via wireless, it's in the same room as the router.
khurram23
Post Thu Feb 28, 2013 3:31 pm
Hey -
Can you try to connect your laptop via wired cable instead of wireless and then try to see if it still does the same?
DlllonJ
Post Thu Feb 28, 2013 6:42 pm
Yeah still the same
khurram23
Post Thu Feb 28, 2013 7:27 pm
Not sure then.
This is what i would do...
Make sure the wireless card is turned off on your laptop and you are connected via wired cable. Reboot your system, just in case.
Make sure xbox 360 is connected via wired. Remove wireless adapter if you have it.
Play your MKV, if it still buffers, pause the movie and give your computer about 15mins to transcode then play again. you should be able to get a min or two of straight (non-buffering) play.
If you have QOS enabled on your router, try disabling it. Try disabling any firewall or packet shaping services on your firewall... for testing purposes.
Not sure otherwise...
grolschie
Post Thu Feb 28, 2013 11:32 pm
DlllonJ wrote:
khurram23 wrote:.... or your computer can't transcode fast enough.
...Post detailed log. http://forum.serviio.org/viewtopic.php?f=5&t=7
...It's having no trouble playing BlueRay MP4's or regular AVI files, but when I play BlueRay MKV files it does this buffer issue? ...
Many MP4 files should play natively on the Xbox 360. Any video that the Xbox cannot play will be transcoded to WMV by Serviio. I would presume that this includes files where normally one would expect mere remuxing (i.e. where it supports the codecs, but not the container).
Please post a detailed log so we can see the ffmpeg command being used. Please also list your computers CPU specs. Thanks.
DlllonJ
Post Fri Mar 01, 2013 12:19 am
grolschie wrote:Many MP4 files should play natively on the Xbox 360. Any video that the Xbox cannot play will be transcoded to WMV by Serviio. I would presume that this includes files where normally one would expect mere remuxing (i.e. where it supports the codecs, but not the container).
System Specs
Processor: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz
Installed memory (RAM): 4.00 GB (3.79GB Usable)
Log
2013-03-01 00:11:42,806 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-03-01 00:11:42,806 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-03-01 00:12:42,809 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-03-01 00:12:42,809 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-03-01 00:12:45,186 DEBUG [PlaylistDAOImpl] Reading all Playlists
2013-03-01 00:13:08,306 DEBUG [RepositoryDAOImpl] Reading all Repositories
2013-03-01 00:13:08,308 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\
2013-03-01 00:13:08,328 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Avatar.2009.EXTENDED.720p.BluRay.x264-BestHD
2013-03-01 00:13:08,329 DEBUG [LibraryAdditionsCheckerThread] Found file 'Avatar - 720p.mkv', checking if it's already in the Library
2013-03-01 00:13:08,329 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Avatar - 720p.mkv
2013-03-01 00:13:08,330 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Avatar.2009.EXTENDED.720p.BluRay.x264-BestHD\Avatar - 720p.mkv, ignore case: true
2013-03-01 00:13:08,331 DEBUG [MediaItemDAOImpl] Media item Avatar - 720p.mkv already exists in DB
2013-03-01 00:13:08,333 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Avatar.2009.EXTENDED.720p.BluRay.x264-BestHD\Sample
2013-03-01 00:13:08,334 DEBUG [LibraryAdditionsCheckerThread] Found file 'besthd-avatar.extended-720p-sample.mkv', checking if it's already in the Library
2013-03-01 00:13:08,335 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item besthd-avatar.extended-720p-sample.mkv
2013-03-01 00:13:08,335 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Avatar.2009.EXTENDED.720p.BluRay.x264-BestHD\Sample\besthd-avatar.extended-720p-sample.mkv, ignore case: true
2013-03-01 00:13:08,336 DEBUG [MediaItemDAOImpl] Media item besthd-avatar.extended-720p-sample.mkv already exists in DB
2013-03-01 00:13:08,337 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Batman The Dark Knight (2008) [1080p]
2013-03-01 00:13:08,338 DEBUG [LibraryAdditionsCheckerThread] Found file 'Batman.The.Dark.Knight.2008.1080p.BluRay.x264.YIFY.mp4', checking if it's already in the Library
2013-03-01 00:13:08,338 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Batman.The.Dark.Knight.2008.1080p.BluRay.x264.YIFY.mp4
2013-03-01 00:13:08,338 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Batman The Dark Knight (2008) [1080p]\Batman.The.Dark.Knight.2008.1080p.BluRay.x264.YIFY.mp4, ignore case: true
2013-03-01 00:13:08,340 DEBUG [MediaItemDAOImpl] Media item Batman.The.Dark.Knight.2008.1080p.BluRay.x264.YIFY.mp4 already exists in DB
2013-03-01 00:13:08,341 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Batman The Dark Knight (2008) [1080p]\Other
2013-03-01 00:13:08,342 DEBUG [LibraryAdditionsCheckerThread] Found file 'WWW.YIFY-TORRENTS.COM.jpg', checking if it's already in the Library
2013-03-01 00:13:08,343 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item http://WWW.YIFY-TORRENTS.COM.jpg
2013-03-01 00:13:08,343 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Batman The Dark Knight (2008) [1080p]\WWW.YIFY-TORRENTS.COM.jpg, ignore case: true
2013-03-01 00:13:08,344 DEBUG [MediaItemDAOImpl] Media item http://WWW.YIFY-TORRENTS.COM.jpg already exists in DB
2013-03-01 00:13:08,344 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Dead.Mans Shoes.2004.DVDRip.XviD-KooKoo
2013-03-01 00:13:08,346 DEBUG [LibraryAdditionsCheckerThread] Found file 'Dead.Mans Shoes.2004.DVDRip.XviD-KooKoo.avi', checking if it's already in the Library
2013-03-01 00:13:08,347 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Dead.Mans Shoes.2004.DVDRip.XviD-KooKoo.avi
2013-03-01 00:13:08,347 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Dead.Mans Shoes.2004.DVDRip.XviD-KooKoo\Dead.Mans Shoes.2004.DVDRip.XviD-KooKoo.avi, ignore case: true
2013-03-01 00:13:08,349 DEBUG [MediaItemDAOImpl] Media item Dead.Mans Shoes.2004.DVDRip.XviD-KooKoo.avi already exists in DB
2013-03-01 00:13:08,350 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Django Unchained 2012 DVDSCR X264 AAC-P2P
2013-03-01 00:13:08,352 DEBUG [LibraryAdditionsCheckerThread] Found file 'du.mkv', checking if it's already in the Library
2013-03-01 00:13:08,352 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item du.mkv
2013-03-01 00:13:08,352 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Django Unchained 2012 DVDSCR X264 AAC-P2P\du.mkv, ignore case: true
2013-03-01 00:13:08,354 DEBUG [MediaItemDAOImpl] Media item du.mkv already exists in DB
2013-03-01 00:13:08,355 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Inception.720p.BluRay.x264-CROSSBOW
2013-03-01 00:13:08,356 DEBUG [LibraryAdditionsCheckerThread] Found file 'crossbow.inception.720p.mkv', checking if it's already in the Library
2013-03-01 00:13:08,356 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item crossbow.inception.720p.mkv
2013-03-01 00:13:08,357 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Inception.720p.BluRay.x264-CROSSBOW\crossbow.inception.720p.mkv, ignore case: true
2013-03-01 00:13:08,358 DEBUG [MediaItemDAOImpl] Media item crossbow.inception.720p.mkv already exists in DB
2013-03-01 00:13:08,359 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\MediaConverter 7
2013-03-01 00:13:08,360 DEBUG [LibraryAdditionsCheckerThread] Found file 'crossbow.inception.720p.MP4', checking if it's already in the Library
2013-03-01 00:13:08,361 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item crossbow.inception.720p.MP4
2013-03-01 00:13:08,361 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\MediaConverter 7\crossbow.inception.720p.MP4, ignore case: true
2013-03-01 00:13:08,362 DEBUG [MediaItemDAOImpl] Media item crossbow.inception.720p.MP4 doesn't exist in DB yet
2013-03-01 00:13:08,362 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2013-03-01 00:13:08,363 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: D:\MediaConverter 7\crossbow.inception.720p.MP4
2013-03-01 00:13:08,363 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: D:\MediaConverter 7\crossbow.inception.720p.MP4
2013-03-01 00:13:08,363 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i D:\MediaConverter 7\crossbow.inception.720p.MP4
2013-03-01 00:13:09,195 DEBUG [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
2013-03-01 00:13:09,197 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\MediaConverter 7\iPad
2013-03-01 00:13:09,198 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\MediaConverter 7\MP4
2013-03-01 00:13:09,199 DEBUG [LibraryAdditionsCheckerThread] Found file 'Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.MP4', checking if it's already in the Library
2013-03-01 00:13:09,199 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.MP4
2013-03-01 00:13:09,199 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\MediaConverter 7\Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.MP4, ignore case: true
2013-03-01 00:13:09,201 DEBUG [MediaItemDAOImpl] Media item Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.MP4 already exists in DB
2013-03-01 00:13:09,201 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Music
2013-03-01 00:13:09,234 DEBUG [LibraryAdditionsCheckerThread] Found file 'Alex Carroll - Mud Sweat And Gear.mp3', checking if it's already in the Library
2013-03-01 00:13:09,234 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Alex Carroll - Mud Sweat And Gear.mp3
2013-03-01 00:13:09,234 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Alex Carroll - Mud Sweat And Gear.mp3, ignore case: true
2013-03-01 00:13:09,235 DEBUG [MediaItemDAOImpl] Media item Alex Carroll - Mud Sweat And Gear.mp3 already exists in DB
2013-03-01 00:13:09,236 DEBUG [LibraryAdditionsCheckerThread] Found file 'Aphrodite - Jungle Brother (Urban Takeover Remix).m4a', checking if it's already in the Library
2013-03-01 00:13:09,236 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Aphrodite - Jungle Brother (Urban Takeover Remix).m4a
2013-03-01 00:13:09,236 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Aphrodite - Jungle Brother (Urban Takeover Remix).m4a, ignore case: true
2013-03-01 00:13:09,237 DEBUG [MediaItemDAOImpl] Media item Aphrodite - Jungle Brother (Urban Takeover Remix).m4a already exists in DB
2013-03-01 00:13:09,237 DEBUG [LibraryAdditionsCheckerThread] Found file 'Aries & Murda - Ganja Farmer.mp3', checking if it's already in the Library
2013-03-01 00:13:09,237 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Aries & Murda - Ganja Farmer.mp3
2013-03-01 00:13:09,237 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Aries & Murda - Ganja Farmer.mp3, ignore case: true
2013-03-01 00:13:09,238 DEBUG [MediaItemDAOImpl] Media item Aries & Murda - Ganja Farmer.mp3 already exists in DB
2013-03-01 00:13:09,239 DEBUG [LibraryAdditionsCheckerThread] Found file 'Auratic - Another Galaxy.m4a', checking if it's already in the Library
2013-03-01 00:13:09,239 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Auratic - Another Galaxy.m4a
2013-03-01 00:13:09,239 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Auratic - Another Galaxy.m4a, ignore case: true
2013-03-01 00:13:09,240 DEBUG [MediaItemDAOImpl] Media item Auratic - Another Galaxy.m4a already exists in DB
2013-03-01 00:13:09,241 DEBUG [LibraryAdditionsCheckerThread] Found file 'Blair Grylls - North Tek.mp3', checking if it's already in the Library
2013-03-01 00:13:09,241 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Blair Grylls - North Tek.mp3
2013-03-01 00:13:09,241 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Blair Grylls - North Tek.mp3, ignore case: true
2013-03-01 00:13:09,242 DEBUG [MediaItemDAOImpl] Media item Blair Grylls - North Tek.mp3 already exists in DB
2013-03-01 00:13:09,242 DEBUG [LibraryAdditionsCheckerThread] Found file 'Blair Grylls - November Mix 2012.mp3', checking if it's already in the Library
2013-03-01 00:13:09,242 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Blair Grylls - November Mix 2012.mp3
2013-03-01 00:13:09,243 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Blair Grylls - November Mix 2012.mp3, ignore case: true
2013-03-01 00:13:09,244 DEBUG [MediaItemDAOImpl] Media item Blair Grylls - November Mix 2012.mp3 already exists in DB
2013-03-01 00:13:09,245 DEBUG [LibraryAdditionsCheckerThread] Found file 'Block Dodger - Pegasus.mp3', checking if it's already in the Library
2013-03-01 00:13:09,245 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Block Dodger - Pegasus.mp3
2013-03-01 00:13:09,246 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Block Dodger - Pegasus.mp3, ignore case: true
2013-03-01 00:13:09,247 DEBUG [MediaItemDAOImpl] Media item Block Dodger - Pegasus.mp3 already exists in DB
2013-03-01 00:13:09,249 DEBUG [LibraryAdditionsCheckerThread] Found file 'Brockie & Ed Solo - Dangerous (Undiluted).m4a', checking if it's already in the Library
2013-03-01 00:13:09,249 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Brockie & Ed Solo - Dangerous (Undiluted).m4a
2013-03-01 00:13:09,249 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Brockie & Ed Solo - Dangerous (Undiluted).m4a, ignore case: true
2013-03-01 00:13:09,250 DEBUG [MediaItemDAOImpl] Media item Brockie & Ed Solo - Dangerous (Undiluted).m4a already exists in DB
2013-03-01 00:13:09,251 DEBUG [LibraryAdditionsCheckerThread] Found file 'Brockie & Ed Solo - Lost Bass.m4a', checking if it's already in the Library
2013-03-01 00:13:09,251 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Brockie & Ed Solo - Lost Bass.m4a
2013-03-01 00:13:09,252 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Brockie & Ed Solo - Lost Bass.m4a, ignore case: true
2013-03-01 00:13:09,253 DEBUG [MediaItemDAOImpl] Media item Brockie & Ed Solo - Lost Bass.m4a already exists in DB
2013-03-01 00:13:09,253 DEBUG [LibraryAdditionsCheckerThread] Found file 'Brockie & Ed Solo - Voices.m4a', checking if it's already in the Library
2013-03-01 00:13:09,254 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Brockie & Ed Solo - Voices.m4a
2013-03-01 00:13:09,254 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Brockie & Ed Solo - Voices.m4a, ignore case: true
2013-03-01 00:13:09,255 DEBUG [MediaItemDAOImpl] Media item Brockie & Ed Solo - Voices.m4a already exists in DB
2013-03-01 00:13:09,256 DEBUG [LibraryAdditionsCheckerThread] Found file 'Culture Shock - Troglodyte.mp3', checking if it's already in the Library
2013-03-01 00:13:09,256 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Culture Shock - Troglodyte.mp3
2013-03-01 00:13:09,256 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Culture Shock - Troglodyte.mp3, ignore case: true
2013-03-01 00:13:09,257 DEBUG [MediaItemDAOImpl] Media item Culture Shock - Troglodyte.mp3 already exists in DB
2013-03-01 00:13:09,258 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - Champion Lover.m4a', checking if it's already in the Library
2013-03-01 00:13:09,258 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - Champion Lover.m4a
2013-03-01 00:13:09,258 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - Champion Lover.m4a, ignore case: true
2013-03-01 00:13:09,259 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - Champion Lover.m4a already exists in DB
2013-03-01 00:13:09,259 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - Ghost Town.m4a', checking if it's already in the Library
2013-03-01 00:13:09,259 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - Ghost Town.m4a
2013-03-01 00:13:09,259 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - Ghost Town.m4a, ignore case: true
2013-03-01 00:13:09,260 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - Ghost Town.m4a already exists in DB
2013-03-01 00:13:09,261 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - Hail Up The Lion.m4a', checking if it's already in the Library
2013-03-01 00:13:09,261 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - Hail Up The Lion.m4a
2013-03-01 00:13:09,261 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - Hail Up The Lion.m4a, ignore case: true
2013-03-01 00:13:09,262 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - Hail Up The Lion.m4a already exists in DB
2013-03-01 00:13:09,263 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - I Don't Smoke.m4a', checking if it's already in the Library
2013-03-01 00:13:09,263 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - I Don't Smoke.m4a
2013-03-01 00:13:09,263 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - I Don't Smoke.m4a, ignore case: true
2013-03-01 00:13:09,264 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - I Don't Smoke.m4a already exists in DB
2013-03-01 00:13:09,265 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - King of The Bongo.mp3', checking if it's already in the Library
2013-03-01 00:13:09,265 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - King of The Bongo.mp3
2013-03-01 00:13:09,265 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - King of The Bongo.mp3, ignore case: true
2013-03-01 00:13:09,267 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - King of The Bongo.mp3 already exists in DB
2013-03-01 00:13:09,268 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - RackNRuin Soundclash.mp3', checking if it's already in the Library
2013-03-01 00:13:09,268 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - RackNRuin Soundclash.mp3
2013-03-01 00:13:09,268 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - RackNRuin Soundclash.mp3, ignore case: true
2013-03-01 00:13:09,269 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - RackNRuin Soundclash.mp3 already exists in DB
2013-03-01 00:13:09,270 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - Sensi.m4a', checking if it's already in the Library
2013-03-01 00:13:09,271 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - Sensi.m4a
2013-03-01 00:13:09,271 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - Sensi.m4a, ignore case: true
2013-03-01 00:13:09,272 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - Sensi.m4a already exists in DB
2013-03-01 00:13:09,273 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline - Stickybuds Guaranteed.mp3', checking if it's already in the Library
2013-03-01 00:13:09,274 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline - Stickybuds Guaranteed.mp3
2013-03-01 00:13:09,274 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline - Stickybuds Guaranteed.mp3, ignore case: true
2013-03-01 00:13:09,275 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline - Stickybuds Guaranteed.mp3 already exists in DB
2013-03-01 00:13:09,276 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo & Deekline ft.Million Dan - Paella (Blaze It Up).mp3', checking if it's already in the Library
2013-03-01 00:13:09,276 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo & Deekline ft.Million Dan - Paella (Blaze It Up).mp3
2013-03-01 00:13:09,276 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo & Deekline ft.Million Dan - Paella (Blaze It Up).mp3, ignore case: true
2013-03-01 00:13:09,277 DEBUG [MediaItemDAOImpl] Media item Ed Solo & Deekline ft.Million Dan - Paella (Blaze It Up).mp3 already exists in DB
2013-03-01 00:13:09,278 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ed Solo Deekline - Sugar Me.m4a', checking if it's already in the Library
2013-03-01 00:13:09,278 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ed Solo Deekline - Sugar Me.m4a
2013-03-01 00:13:09,278 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Ed Solo Deekline - Sugar Me.m4a, ignore case: true
2013-03-01 00:13:09,279 DEBUG [MediaItemDAOImpl] Media item Ed Solo Deekline - Sugar Me.m4a already exists in DB
2013-03-01 00:13:09,280 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fourward - Side By Side.m4a', checking if it's already in the Library
2013-03-01 00:13:09,280 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fourward - Side By Side.m4a
2013-03-01 00:13:09,280 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Fourward - Side By Side.m4a, ignore case: true
2013-03-01 00:13:09,281 DEBUG [MediaItemDAOImpl] Media item Fourward - Side By Side.m4a already exists in DB
2013-03-01 00:13:09,281 DEBUG [LibraryAdditionsCheckerThread] Found file 'Fourward - Talk To Me.m4a', checking if it's already in the Library
2013-03-01 00:13:09,281 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Fourward - Talk To Me.m4a
2013-03-01 00:13:09,282 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Fourward - Talk To Me.m4a, ignore case: true
2013-03-01 00:13:09,282 DEBUG [MediaItemDAOImpl] Media item Fourward - Talk To Me.m4a already exists in DB
2013-03-01 00:13:09,284 DEBUG [LibraryAdditionsCheckerThread] Found file 'Jubwise - Toxic Takeover.mp3', checking if it's already in the Library
2013-03-01 00:13:09,284 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Jubwise - Toxic Takeover.mp3
2013-03-01 00:13:09,285 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Jubwise - Toxic Takeover.mp3, ignore case: true
2013-03-01 00:13:09,286 DEBUG [MediaItemDAOImpl] Media item Jubwise - Toxic Takeover.mp3 already exists in DB
2013-03-01 00:13:09,286 DEBUG [LibraryAdditionsCheckerThread] Found file 'Konflict - Messiah (Noisia remix).m4a', checking if it's already in the Library
2013-03-01 00:13:09,286 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Konflict - Messiah (Noisia remix).m4a
2013-03-01 00:13:09,286 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Konflict - Messiah (Noisia remix).m4a, ignore case: true
2013-03-01 00:13:09,287 DEBUG [MediaItemDAOImpl] Media item Konflict - Messiah (Noisia remix).m4a already exists in DB
2013-03-01 00:13:09,288 DEBUG [LibraryAdditionsCheckerThread] Found file 'Lenzman - Wordsworth.m4a', checking if it's already in the Library
2013-03-01 00:13:09,288 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Lenzman - Wordsworth.m4a
2013-03-01 00:13:09,288 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Lenzman - Wordsworth.m4a, ignore case: true
2013-03-01 00:13:09,289 DEBUG [MediaItemDAOImpl] Media item Lenzman - Wordsworth.m4a already exists in DB
2013-03-01 00:13:09,290 DEBUG [LibraryAdditionsCheckerThread] Found file 'Levela - Brapple Pie.m4a', checking if it's already in the Library
2013-03-01 00:13:09,290 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Levela - Brapple Pie.m4a
2013-03-01 00:13:09,290 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Levela - Brapple Pie.m4a, ignore case: true
2013-03-01 00:13:09,291 DEBUG [MediaItemDAOImpl] Media item Levela - Brapple Pie.m4a already exists in DB
2013-03-01 00:13:09,292 DEBUG [LibraryAdditionsCheckerThread] Found file 'Neelix - Coloured Light - YouTube.M4A', checking if it's already in the Library
2013-03-01 00:13:09,292 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Neelix - Coloured Light - YouTube.M4A
2013-03-01 00:13:09,293 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Neelix - Coloured Light - YouTube.M4A, ignore case: true
2013-03-01 00:13:09,294 DEBUG [MediaItemDAOImpl] Media item Neelix - Coloured Light - YouTube.M4A already exists in DB
2013-03-01 00:13:09,295 DEBUG [LibraryAdditionsCheckerThread] Found file 'Neelix - Live Set 2012.M4A', checking if it's already in the Library
2013-03-01 00:13:09,295 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Neelix - Live Set 2012.M4A
2013-03-01 00:13:09,295 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Neelix - Live Set 2012.M4A, ignore case: true
2013-03-01 00:13:09,297 DEBUG [MediaItemDAOImpl] Media item Neelix - Live Set 2012.M4A already exists in DB
2013-03-01 00:13:09,298 DEBUG [LibraryAdditionsCheckerThread] Found file 'Noisia -Diplodocus (Kill The Noise Remix).m4a', checking if it's already in the Library
2013-03-01 00:13:09,298 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Noisia -Diplodocus (Kill The Noise Remix).m4a
2013-03-01 00:13:09,298 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Noisia -Diplodocus (Kill The Noise Remix).m4a, ignore case: true
2013-03-01 00:13:09,299 DEBUG [MediaItemDAOImpl] Media item Noisia -Diplodocus (Kill The Noise Remix).m4a already exists in DB
2013-03-01 00:13:09,300 DEBUG [LibraryAdditionsCheckerThread] Found file 'Official - Neelix - Expect What - YouTube.mp3', checking if it's already in the Library
2013-03-01 00:13:09,300 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Official - Neelix - Expect What - YouTube.mp3
2013-03-01 00:13:09,300 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Official - Neelix - Expect What - YouTube.mp3, ignore case: true
2013-03-01 00:13:09,302 DEBUG [MediaItemDAOImpl] Media item Official - Neelix - Expect What - YouTube.mp3 already exists in DB
2013-03-01 00:13:09,303 DEBUG [LibraryAdditionsCheckerThread] Found file 'Optiv - Krakpot (Jade remix).m4a', checking if it's already in the Library
2013-03-01 00:13:09,303 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Optiv - Krakpot (Jade remix).m4a
2013-03-01 00:13:09,303 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Optiv - Krakpot (Jade remix).m4a, ignore case: true
2013-03-01 00:13:09,304 DEBUG [MediaItemDAOImpl] Media item Optiv - Krakpot (Jade remix).m4a already exists in DB
2013-03-01 00:13:09,307 DEBUG [LibraryAdditionsCheckerThread] Found file 'Parallel Forces - Grounded Theory (Teebee Remix).m4a', checking if it's already in the Library
2013-03-01 00:13:09,307 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Parallel Forces - Grounded Theory (Teebee Remix).m4a
2013-03-01 00:13:09,308 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Parallel Forces - Grounded Theory (Teebee Remix).m4a, ignore case: true
2013-03-01 00:13:09,309 DEBUG [MediaItemDAOImpl] Media item Parallel Forces - Grounded Theory (Teebee Remix).m4a already exists in DB
2013-03-01 00:13:09,310 DEBUG [LibraryAdditionsCheckerThread] Found file 'Prolix - Feed the habit.m4a', checking if it's already in the Library
2013-03-01 00:13:09,310 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Prolix - Feed the habit.m4a
2013-03-01 00:13:09,310 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Prolix - Feed the habit.m4a, ignore case: true
2013-03-01 00:13:09,312 DEBUG [MediaItemDAOImpl] Media item Prolix - Feed the habit.m4a already exists in DB
2013-03-01 00:13:09,313 DEBUG [LibraryAdditionsCheckerThread] Found file 'Prolix - Noisy Neighbour.m4a', checking if it's already in the Library
2013-03-01 00:13:09,314 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Prolix - Noisy Neighbour.m4a
2013-03-01 00:13:09,314 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Prolix - Noisy Neighbour.m4a, ignore case: true
2013-03-01 00:13:09,316 DEBUG [MediaItemDAOImpl] Media item Prolix - Noisy Neighbour.m4a already exists in DB
2013-03-01 00:13:09,318 DEBUG [LibraryAdditionsCheckerThread] Found file 'Prozack - February Mix.m4a', checking if it's already in the Library
2013-03-01 00:13:09,318 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Prozack - February Mix.m4a
2013-03-01 00:13:09,318 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Prozack - February Mix.m4a, ignore case: true
2013-03-01 00:13:09,320 DEBUG [MediaItemDAOImpl] Media item Prozack - February Mix.m4a already exists in DB
2013-03-01 00:13:09,320 DEBUG [LibraryAdditionsCheckerThread] Found file 'Serial Killaz - Good Enough.m4a', checking if it's already in the Library
2013-03-01 00:13:09,321 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Serial Killaz - Good Enough.m4a
2013-03-01 00:13:09,321 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Serial Killaz - Good Enough.m4a, ignore case: true
2013-03-01 00:13:09,323 DEBUG [MediaItemDAOImpl] Media item Serial Killaz - Good Enough.m4a already exists in DB
2013-03-01 00:13:09,324 DEBUG [LibraryAdditionsCheckerThread] Found file 'Shy FX - Raver (Feat. Kano, Donae'o and Roses Gabor).m4a', checking if it's already in the Library
2013-03-01 00:13:09,324 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Shy FX - Raver (Feat. Kano, Donae'o and Roses Gabor).m4a
2013-03-01 00:13:09,324 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Shy FX - Raver (Feat. Kano, Donae'o and Roses Gabor).m4a, ignore case: true
2013-03-01 00:13:09,325 DEBUG [MediaItemDAOImpl] Media item Shy FX - Raver (Feat. Kano, Donae'o and Roses Gabor).m4a already exists in DB
2013-03-01 00:13:09,326 DEBUG [LibraryAdditionsCheckerThread] Found file 'Stevie 1DA - New Set.mp3', checking if it's already in the Library
2013-03-01 00:13:09,326 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Stevie 1DA - New Set.mp3
2013-03-01 00:13:09,326 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Stevie 1DA - New Set.mp3, ignore case: true
2013-03-01 00:13:09,328 DEBUG [MediaItemDAOImpl] Media item Stevie 1DA - New Set.mp3 already exists in DB
2013-03-01 00:13:09,329 DEBUG [LibraryAdditionsCheckerThread] Found file 'Swankie - Free Party Respect.m4a', checking if it's already in the Library
2013-03-01 00:13:09,329 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Swankie - Free Party Respect.m4a
2013-03-01 00:13:09,329 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Swankie - Free Party Respect.m4a, ignore case: true
2013-03-01 00:13:09,330 DEBUG [MediaItemDAOImpl] Media item Swankie - Free Party Respect.m4a already exists in DB
2013-03-01 00:13:09,331 DEBUG [LibraryAdditionsCheckerThread] Found file 'Tantrum Desire - Reach.mp3', checking if it's already in the Library
2013-03-01 00:13:09,331 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Tantrum Desire - Reach.mp3
2013-03-01 00:13:09,331 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Tantrum Desire - Reach.mp3, ignore case: true
2013-03-01 00:13:09,333 DEBUG [MediaItemDAOImpl] Media item Tantrum Desire - Reach.mp3 already exists in DB
2013-03-01 00:13:09,334 DEBUG [LibraryAdditionsCheckerThread] Found file 'Trauma Sounds - Void, Coresyntax & P739.mp3', checking if it's already in the Library
2013-03-01 00:13:09,335 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Trauma Sounds - Void, Coresyntax & P739.mp3
2013-03-01 00:13:09,335 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Trauma Sounds - Void, Coresyntax & P739.mp3, ignore case: true
2013-03-01 00:13:09,336 DEBUG [MediaItemDAOImpl] Media item Trauma Sounds - Void, Coresyntax & P739.mp3 already exists in DB
2013-03-01 00:13:09,337 DEBUG [LibraryAdditionsCheckerThread] Found file 'Vocoda - Any Jungle Guy.mp3', checking if it's already in the Library
2013-03-01 00:13:09,337 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Vocoda - Any Jungle Guy.mp3
2013-03-01 00:13:09,337 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Vocoda - Any Jungle Guy.mp3, ignore case: true
2013-03-01 00:13:09,339 DEBUG [MediaItemDAOImpl] Media item Vocoda - Any Jungle Guy.mp3 already exists in DB
2013-03-01 00:13:09,340 DEBUG [LibraryAdditionsCheckerThread] Found file 'Yog - Kovert Mix.mp3', checking if it's already in the Library
2013-03-01 00:13:09,340 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Yog - Kovert Mix.mp3
2013-03-01 00:13:09,340 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Yog - Kovert Mix.mp3, ignore case: true
2013-03-01 00:13:09,342 DEBUG [MediaItemDAOImpl] Media item Yog - Kovert Mix.mp3 already exists in DB
2013-03-01 00:13:09,343 DEBUG [LibraryAdditionsCheckerThread] Found file 'Zeds Dead Ft Mavado - Undah Yuh Skirt.m4a', checking if it's already in the Library
2013-03-01 00:13:09,343 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Zeds Dead Ft Mavado - Undah Yuh Skirt.m4a
2013-03-01 00:13:09,343 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\Zeds Dead Ft Mavado - Undah Yuh Skirt.m4a, ignore case: true
2013-03-01 00:13:09,344 DEBUG [MediaItemDAOImpl] Media item Zeds Dead Ft Mavado - Undah Yuh Skirt.m4a already exists in DB
2013-03-01 00:13:09,346 DEBUG [LibraryAdditionsCheckerThread] Found file '[HD] December 10 minute Drum & Bass Mix_youtube_original.mp4', checking if it's already in the Library
2013-03-01 00:13:09,346 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item [HD] December 10 minute Drum & Bass Mix_youtube_original.mp4
2013-03-01 00:13:09,346 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Music\[HD] December 10 minute Drum & Bass Mix_youtube_original.mp4, ignore case: true
2013-03-01 00:13:09,347 DEBUG [MediaItemDAOImpl] Media item [HD] December 10 minute Drum & Bass Mix_youtube_original.mp4 already exists in DB
2013-03-01 00:13:09,349 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Recorded Videos
2013-03-01 00:13:09,350 DEBUG [LibraryAdditionsCheckerThread] Found file 'An Watt & Odyssey - New Years Eve 2013.MOV', checking if it's already in the Library
2013-03-01 00:13:09,350 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item An Watt & Odyssey - New Years Eve 2013.MOV
2013-03-01 00:13:09,350 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Recorded Videos\An Watt & Odyssey - New Years Eve 2013.MOV, ignore case: true
2013-03-01 00:13:09,351 DEBUG [MediaItemDAOImpl] Media item An Watt & Odyssey - New Years Eve 2013.MOV already exists in DB
2013-03-01 00:13:09,353 DEBUG [LibraryAdditionsCheckerThread] Found file 'Bedfordshire Collective - Halloween 2012.MOV', checking if it's already in the Library
2013-03-01 00:13:09,353 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Bedfordshire Collective - Halloween 2012.MOV
2013-03-01 00:13:09,353 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Recorded Videos\Bedfordshire Collective - Halloween 2012.MOV, ignore case: true
2013-03-01 00:13:09,354 DEBUG [MediaItemDAOImpl] Media item Bedfordshire Collective - Halloween 2012.MOV already exists in DB
2013-03-01 00:13:09,356 DEBUG [LibraryAdditionsCheckerThread] Found file 'Sensi-Tize 2012.MOV', checking if it's already in the Library
2013-03-01 00:13:09,356 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Sensi-Tize 2012.MOV
2013-03-01 00:13:09,356 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Recorded Videos\Sensi-Tize 2012.MOV, ignore case: true
2013-03-01 00:13:09,357 DEBUG [MediaItemDAOImpl] Media item Sensi-Tize 2012.MOV already exists in DB
2013-03-01 00:13:09,359 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi
2013-03-01 00:13:09,360 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi\Sample
2013-03-01 00:13:09,375 DEBUG [LibraryAdditionsCheckerThread] Found file 'Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.Sample.mkv', checking if it's already in the Library
2013-03-01 00:13:09,376 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.Sample.mkv
2013-03-01 00:13:09,376 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi\Sample\Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.Sample.mkv, ignore case: true
2013-03-01 00:13:09,377 DEBUG [MediaItemDAOImpl] Media item Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.Sample.mkv already exists in DB
2013-03-01 00:13:09,379 DEBUG [LibraryAdditionsCheckerThread] Found file 'Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.mkv', checking if it's already in the Library
2013-03-01 00:13:09,379 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.mkv
2013-03-01 00:13:09,379 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi\Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.mkv, ignore case: true
2013-03-01 00:13:09,381 DEBUG [MediaItemDAOImpl] Media item Shutter.Island.2010.720p.BluRay.x264.DTS-WiKi.mkv already exists in DB
2013-03-01 00:13:09,382 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Taken 2 2012 DVDRIP XVID AC3 5.1 HS (SilverTorrent)
2013-03-01 00:13:09,384 DEBUG [LibraryAdditionsCheckerThread] Found file 'Taken.2.2012.DVDRIP.XVID.AC3.5.1.HS.avi', checking if it's already in the Library
2013-03-01 00:13:09,384 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Taken.2.2012.DVDRIP.XVID.AC3.5.1.HS.avi
2013-03-01 00:13:09,384 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Taken 2 2012 DVDRIP XVID AC3 5.1 HS (SilverTorrent)\Taken.2.2012.DVDRIP.XVID.AC3.5.1.HS.avi, ignore case: true
2013-03-01 00:13:09,385 DEBUG [MediaItemDAOImpl] Media item Taken.2.2012.DVDRIP.XVID.AC3.5.1.HS.avi already exists in DB
2013-03-01 00:13:09,386 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Ted (2012)
2013-03-01 00:13:09,387 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ted.2012.BluRay.720p.x264.YIFY.mp4', checking if it's already in the Library
2013-03-01 00:13:09,388 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ted.2012.BluRay.720p.x264.YIFY.mp4
2013-03-01 00:13:09,388 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Ted (2012)\Ted.2012.BluRay.720p.x264.YIFY.mp4, ignore case: true
2013-03-01 00:13:09,389 DEBUG [MediaItemDAOImpl] Media item Ted.2012.BluRay.720p.x264.YIFY.mp4 already exists in DB
2013-03-01 00:13:09,389 DEBUG [LibraryAdditionsCheckerThread] Found file 'WWW.YIFY-TORRENTS.COM.jpg', checking if it's already in the Library
2013-03-01 00:13:09,389 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item http://WWW.YIFY-TORRENTS.COM.jpg
2013-03-01 00:13:09,389 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Ted (2012)\WWW.YIFY-TORRENTS.COM.jpg, ignore case: true
2013-03-01 00:13:09,390 DEBUG [MediaItemDAOImpl] Media item http://WWW.YIFY-TORRENTS.COM.jpg already exists in DB
2013-03-01 00:13:09,391 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Legacy (2012)
2013-03-01 00:13:09,392 DEBUG [LibraryAdditionsCheckerThread] Found file 'The.Bourne.Legacy.2012.720p.BluRay.x264.mp4', checking if it's already in the Library
2013-03-01 00:13:09,392 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The.Bourne.Legacy.2012.720p.BluRay.x264.mp4
2013-03-01 00:13:09,393 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Legacy (2012)\The.Bourne.Legacy.2012.720p.BluRay.x264.mp4, ignore case: true
2013-03-01 00:13:09,394 DEBUG [MediaItemDAOImpl] Media item The.Bourne.Legacy.2012.720p.BluRay.x264.mp4 already exists in DB
2013-03-01 00:13:09,395 DEBUG [LibraryAdditionsCheckerThread] Found file 'WWW.YIFY-TORRENTS.COM.jpg', checking if it's already in the Library
2013-03-01 00:13:09,395 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item http://WWW.YIFY-TORRENTS.COM.jpg
2013-03-01 00:13:09,395 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Legacy (2012)\WWW.YIFY-TORRENTS.COM.jpg, ignore case: true
2013-03-01 00:13:09,397 DEBUG [MediaItemDAOImpl] Media item http://WWW.YIFY-TORRENTS.COM.jpg already exists in DB
2013-03-01 00:13:09,398 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE
2013-03-01 00:13:09,400 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE
2013-03-01 00:13:09,403 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE\Sample
2013-03-01 00:13:09,404 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Identity - Sample.mp4', checking if it's already in the Library
2013-03-01 00:13:09,404 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Identity - Sample.mp4
2013-03-01 00:13:09,405 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE\Sample\The Bourne Identity - Sample.mp4, ignore case: true
2013-03-01 00:13:09,406 DEBUG [MediaItemDAOImpl] Media item The Bourne Identity - Sample.mp4 already exists in DB
2013-03-01 00:13:09,408 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Identity[14-26-38].PNG', checking if it's already in the Library
2013-03-01 00:13:09,408 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Identity[14-26-38].PNG
2013-03-01 00:13:09,408 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE\Sample\The Bourne Identity[14-26-38].PNG, ignore case: true
2013-03-01 00:13:09,409 DEBUG [MediaItemDAOImpl] Media item The Bourne Identity[14-26-38].PNG already exists in DB
2013-03-01 00:13:09,410 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Identity[14-27-38].PNG', checking if it's already in the Library
2013-03-01 00:13:09,410 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Identity[14-27-38].PNG
2013-03-01 00:13:09,410 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE\Sample\The Bourne Identity[14-27-38].PNG, ignore case: true
2013-03-01 00:13:09,411 DEBUG [MediaItemDAOImpl] Media item The Bourne Identity[14-27-38].PNG already exists in DB
2013-03-01 00:13:09,412 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Identity[14-30-21].PNG', checking if it's already in the Library
2013-03-01 00:13:09,412 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Identity[14-30-21].PNG
2013-03-01 00:13:09,412 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE\Sample\The Bourne Identity[14-30-21].PNG, ignore case: true
2013-03-01 00:13:09,414 DEBUG [MediaItemDAOImpl] Media item The Bourne Identity[14-30-21].PNG already exists in DB
2013-03-01 00:13:09,415 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Identity[14-31-45].PNG', checking if it's already in the Library
2013-03-01 00:13:09,415 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Identity[14-31-45].PNG
2013-03-01 00:13:09,415 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE\Sample\The Bourne Identity[14-31-45].PNG, ignore case: true
2013-03-01 00:13:09,417 DEBUG [MediaItemDAOImpl] Media item The Bourne Identity[14-31-45].PNG already exists in DB
2013-03-01 00:13:09,418 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Identity.mp4', checking if it's already in the Library
2013-03-01 00:13:09,418 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Identity.mp4
2013-03-01 00:13:09,418 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Identity 2002 720p BRRip x264-HDLiTE\The Bourne Identity.mp4, ignore case: true
2013-03-01 00:13:09,420 DEBUG [MediaItemDAOImpl] Media item The Bourne Identity.mp4 already exists in DB
2013-03-01 00:13:09,420 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE
2013-03-01 00:13:09,423 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE\Sample
2013-03-01 00:13:09,424 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Supremacy - Sample.mp4', checking if it's already in the Library
2013-03-01 00:13:09,424 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Supremacy - Sample.mp4
2013-03-01 00:13:09,425 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE\Sample\The Bourne Supremacy - Sample.mp4, ignore case: true
2013-03-01 00:13:09,426 DEBUG [MediaItemDAOImpl] Media item The Bourne Supremacy - Sample.mp4 already exists in DB
2013-03-01 00:13:09,427 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Supremacy[14-49-53].PNG', checking if it's already in the Library
2013-03-01 00:13:09,427 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Supremacy[14-49-53].PNG
2013-03-01 00:13:09,427 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE\Sample\The Bourne Supremacy[14-49-53].PNG, ignore case: true
2013-03-01 00:13:09,428 DEBUG [MediaItemDAOImpl] Media item The Bourne Supremacy[14-49-53].PNG already exists in DB
2013-03-01 00:13:09,429 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Supremacy[14-50-16].PNG', checking if it's already in the Library
2013-03-01 00:13:09,429 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Supremacy[14-50-16].PNG
2013-03-01 00:13:09,429 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE\Sample\The Bourne Supremacy[14-50-16].PNG, ignore case: true
2013-03-01 00:13:09,430 DEBUG [MediaItemDAOImpl] Media item The Bourne Supremacy[14-50-16].PNG already exists in DB
2013-03-01 00:13:09,431 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Supremacy[14-51-04].PNG', checking if it's already in the Library
2013-03-01 00:13:09,431 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Supremacy[14-51-04].PNG
2013-03-01 00:13:09,431 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE\Sample\The Bourne Supremacy[14-51-04].PNG, ignore case: true
2013-03-01 00:13:09,432 DEBUG [MediaItemDAOImpl] Media item The Bourne Supremacy[14-51-04].PNG already exists in DB
2013-03-01 00:13:09,433 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Supremacy[14-56-27].PNG', checking if it's already in the Library
2013-03-01 00:13:09,433 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Supremacy[14-56-27].PNG
2013-03-01 00:13:09,433 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE\Sample\The Bourne Supremacy[14-56-27].PNG, ignore case: true
2013-03-01 00:13:09,434 DEBUG [MediaItemDAOImpl] Media item The Bourne Supremacy[14-56-27].PNG already exists in DB
2013-03-01 00:13:09,435 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Supremacy.mp4', checking if it's already in the Library
2013-03-01 00:13:09,435 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Supremacy.mp4
2013-03-01 00:13:09,435 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Supremacy 2004 720p BRRip x264-HDLiTE\The Bourne Supremacy.mp4, ignore case: true
2013-03-01 00:13:09,436 DEBUG [MediaItemDAOImpl] Media item The Bourne Supremacy.mp4 already exists in DB
2013-03-01 00:13:09,437 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Trilogy 720p HDLiTE.png', checking if it's already in the Library
2013-03-01 00:13:09,437 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Trilogy 720p HDLiTE.png
2013-03-01 00:13:09,437 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Trilogy 720p HDLiTE.png, ignore case: true
2013-03-01 00:13:09,438 DEBUG [MediaItemDAOImpl] Media item The Bourne Trilogy 720p HDLiTE.png already exists in DB
2013-03-01 00:13:09,438 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE
2013-03-01 00:13:09,440 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE\Sample
2013-03-01 00:13:09,442 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Ultimatum - Sample.mp4', checking if it's already in the Library
2013-03-01 00:13:09,442 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Ultimatum - Sample.mp4
2013-03-01 00:13:09,442 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE\Sample\The Bourne Ultimatum - Sample.mp4, ignore case: true
2013-03-01 00:13:09,443 DEBUG [MediaItemDAOImpl] Media item The Bourne Ultimatum - Sample.mp4 already exists in DB
2013-03-01 00:13:09,444 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Ultimatum[15-02-42].PNG', checking if it's already in the Library
2013-03-01 00:13:09,444 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Ultimatum[15-02-42].PNG
2013-03-01 00:13:09,444 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE\Sample\The Bourne Ultimatum[15-02-42].PNG, ignore case: true
2013-03-01 00:13:09,445 DEBUG [MediaItemDAOImpl] Media item The Bourne Ultimatum[15-02-42].PNG already exists in DB
2013-03-01 00:13:09,445 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Ultimatum[15-03-04].PNG', checking if it's already in the Library
2013-03-01 00:13:09,445 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Ultimatum[15-03-04].PNG
2013-03-01 00:13:09,446 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE\Sample\The Bourne Ultimatum[15-03-04].PNG, ignore case: true
2013-03-01 00:13:09,446 DEBUG [MediaItemDAOImpl] Media item The Bourne Ultimatum[15-03-04].PNG already exists in DB
2013-03-01 00:13:09,447 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Ultimatum[15-03-57].PNG', checking if it's already in the Library
2013-03-01 00:13:09,447 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Ultimatum[15-03-57].PNG
2013-03-01 00:13:09,447 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE\Sample\The Bourne Ultimatum[15-03-57].PNG, ignore case: true
2013-03-01 00:13:09,448 DEBUG [MediaItemDAOImpl] Media item The Bourne Ultimatum[15-03-57].PNG already exists in DB
2013-03-01 00:13:09,448 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Ultimatum[15-06-46].PNG', checking if it's already in the Library
2013-03-01 00:13:09,448 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Ultimatum[15-06-46].PNG
2013-03-01 00:13:09,448 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE\Sample\The Bourne Ultimatum[15-06-46].PNG, ignore case: true
2013-03-01 00:13:09,449 DEBUG [MediaItemDAOImpl] Media item The Bourne Ultimatum[15-06-46].PNG already exists in DB
2013-03-01 00:13:09,450 DEBUG [LibraryAdditionsCheckerThread] Found file 'The Bourne Ultimatum.mp4', checking if it's already in the Library
2013-03-01 00:13:09,450 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item The Bourne Ultimatum.mp4
2013-03-01 00:13:09,450 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\The Bourne Trilogy 720p BRRip x264-HDLiTE\The Bourne Ultimatum 2007 720p BRRip x264-HDLiTE\The Bourne Ultimatum.mp4, ignore case: true
2013-03-01 00:13:09,451 DEBUG [MediaItemDAOImpl] Media item The Bourne Ultimatum.mp4 already exists in DB
2013-03-01 00:13:09,451 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Zero.Dark.Thirty.2012.DVDSCR.H264.AC3-ThyJesus
2013-03-01 00:13:09,453 DEBUG [LibraryAdditionsCheckerThread] Found file 'Zero.Dark.Thirty.2012.DVDSCR.H264.AC3-ThyJesus.mkv', checking if it's already in the Library
2013-03-01 00:13:09,453 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Zero.Dark.Thirty.2012.DVDSCR.H264.AC3-ThyJesus.mkv
2013-03-01 00:13:09,453 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Zero.Dark.Thirty.2012.DVDSCR.H264.AC3-ThyJesus\Zero.Dark.Thirty.2012.DVDSCR.H264.AC3-ThyJesus.mkv, ignore case: true
2013-03-01 00:13:09,454 DEBUG [MediaItemDAOImpl] Media item Zero.Dark.Thirty.2012.DVDSCR.H264.AC3-ThyJesus.mkv already exists in DB
2013-03-01 00:13:09,455 DEBUG [RepositoryDAOImpl] Marking Repository 1 as scanned with current timestamp
2013-03-01 00:13:09,458 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: D:\Ted (2012)
2013-03-01 00:13:09,459 DEBUG [LibraryAdditionsCheckerThread] Found file 'Ted.2012.BluRay.720p.x264.YIFY.mp4', checking if it's already in the Library
2013-03-01 00:13:09,459 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Ted.2012.BluRay.720p.x264.YIFY.mp4
2013-03-01 00:13:09,459 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Ted (2012)\Ted.2012.BluRay.720p.x264.YIFY.mp4, ignore case: true
2013-03-01 00:13:09,461 DEBUG [MediaItemDAOImpl] Media item Ted.2012.BluRay.720p.x264.YIFY.mp4 already exists in DB
2013-03-01 00:13:09,462 DEBUG [LibraryAdditionsCheckerThread] Found file 'WWW.YIFY-TORRENTS.COM.jpg', checking if it's already in the Library
2013-03-01 00:13:09,462 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item http://WWW.YIFY-TORRENTS.COM.jpg
2013-03-01 00:13:09,462 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: D:\Ted (2012)\WWW.YIFY-TORRENTS.COM.jpg, ignore case: true
2013-03-01 00:13:09,463 DEBUG [MediaItemDAOImpl] Media item http://WWW.YIFY-TORRENTS.COM.jpg already exists in DB
2013-03-01 00:13:09,463 DEBUG [RepositoryDAOImpl] Marking Repository 3 as scanned with current timestamp
grolschie
Post Fri Mar 01, 2013 3:04 am
Thanks. But we would need just the section of the log when you are trying to stream the file and it's stuttering.
Hmmm....Django Unchained DVD release is not until April..... :roll: Not cool.
khurram23
Post Fri Mar 01, 2013 7:37 pm
Go ahead and remove that log (edit your post).
Only post the part where transaction is happening as stated by grolschie.
Your computer specs are good. Transcoding time shouldn't be an issue.
Check your router and try disabling QOS if you have it enabled.
Users browsing this forum: No registered users and 52 guests
