Question about metadata
BrianMarkussen
Post Sat Mar 02, 2013 1:23 pm
Hi
I just got serviio up and running on my thecus nas. I can play my files on my Samsung tv, that is all good :-)
My question is now. When i choose metadata form online providers, what can i expect to see on my Samsung. All i see now is a very small thumbnail of the movie, can i get more than that or is that not possible with dlna?
Thx for answer :-)
Brian
PS: If i include xmbc nfo and tell to use that as meta data, the files dosent show on tv?
Post Sun Mar 03, 2013 12:12 pm
Re: Question about metadata
Yep, TVs usually don't display any additional metadata.
paniko
Post Mon Mar 04, 2013 11:05 am
zip wrote:Yep, TVs usually don't display any additional metadata.
I have the same issue so... I think it's a TV DLNA client side limit that not support the retrieving of metadata thumbnail.. right??
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
Post Mon Mar 04, 2013 1:51 pm
the spec allows for all sorts of metadata, Serviio sends some of it, but most clients ignore it
