[SOLVED] Sony Bravia online h264 aac stream no sound
Grokix
Post Thu Feb 21, 2013 5:04 pm
Please, help with transcodding settings...
ffmpeg.exe -i:
c:\Program Files\Serviio\lib>ffmpeg.exe -i "http://1.aaa.aaa.net/~aaa
o/1/"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
[h264 @ 014DFE60] non-existing PPS referenced
[h264 @ 014DFE60] non-existing PPS 0 referenced
[h264 @ 014DFE60] decode_slice_header error
[h264 @ 014DFE60] no frame!
[mpegts @ 014B5AE0] max_analyze_duration 5000000 reached at 5000000
[mpegts @ 014B5AE0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://1.aaa.aaa.net/~aaa/1/':
  Duration: N/A, start: 48787.508167, bitrate: 150 kb/s
  Program 1
      service_name    : ?┐╒р╥ы┘
      service_provider: aaa.TV
    Stream #0:0[0x100]: Video: h264 (Constrained Baseline) ([27][0][0][0] / 0x00
1B), yuv420p, 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x101](rus): Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, ster
eo, fltp, 150 kb/s
device:
Sony KDL-22EX320
profile:
Any sony's profile works without sound
Debug log: too big, but i can post it if needed
Post Thu Feb 21, 2013 6:51 pm
Re: Sony Bravia online h264 aac stream no sound
Is it local or online stream ?
Grokix
Post Sun Feb 24, 2013 1:35 pm
Post Tue Feb 26, 2013 1:53 pm
Grokix wrote:Sony Bravia online h264 aac stream no sound
Ok sorry...
The aac audio track should be delivered in native format. Could you enable detailed logging file, and check the ffmeg command line used when you start to play this file ?
Grokix
Post Tue Feb 26, 2013 5:19 pm
2013-02-26 20:54:24,900 DEBUG [WebServer] Incoming connection from /192.168.1.35:44495
2013-02-26 20:54:24,901 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2013-02-26 20:54:24,903 DEBUG [ResourceTransportRequestHandler] GET /resource/1000000010001161/MEDIA_ITEM/AVC_TS_MP_SD_AAC_MULT5_ISO-0/ORIGINAL HTTP/1.1, headers = [getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming,X-AV-Physical-Unit-Info: pa="BRAVIA KDL-22EX320";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-22EX320"; mv="1.7";,Host: 192.168.1.36:8895]]
2013-02-26 20:54:24,903 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.35
2013-02-26 20:54:24,904 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.35, Profile=Sony Bravia TV (2011)'
2013-02-26 20:54:24,905 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000010001161 and type 'MEDIA_ITEM' received
2013-02-26 20:54:24,906 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001161 (online)
2013-02-26 20:54:24,906 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-02-26 20:54:24,908 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1000000010001161, format AVC_TS_MP_SD_AAC_MULT5_ISO and profile Sony Bravia TV (2011)
2013-02-26 20:54:24,909 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000010001161 (online)
2013-02-26 20:54:24,910 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2013-02-26 20:54:24,911 DEBUG [VideoDeliveryEngine] Delivering item '1000000010001161' for client 'IPAddress=/192.168.1.35, Profile=Sony Bravia TV (2011)'
2013-02-26 20:54:24,913 DEBUG [VideoDeliveryEngine] Delivering file 'http://1.aaa.aaa.net/~aaa/1/' in native format
2013-02-26 20:54:24,913 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2013-02-26 20:54:24,914 DEBUG [ResourceDeliveryProcessor] Sending file back
2013-02-26 20:54:24,914 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Tue, 26 Feb 2013 16:54:24 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=00;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=8D500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-02-26 20:54:24,914 DEBUG [OnlineInputStream] Reading 1512000 bytes starting at 0
2013-02-26 20:54:25,050 DEBUG [OnlineInputStream] Byte range not supported for http://1.aaa.aaa.net/~aaa/1/, returning the whole stream
2013-02-26 20:55:08,083 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2013-02-26 20:55:08,083 DEBUG [OnlineInputStream] Closing stream
Illico wrote:The aac audio track should be delivered in native format.
It seems you are right...
Post Tue Feb 26, 2013 7:28 pm
Could you provide ffmpeg -i of this stream (you only post stream 0.0 and 0.1, but I also need to know the container Input 0) ?
Post Tue Feb 26, 2013 7:29 pm
On Sony Bravia 2011 profile section (profiles.xml) you can edit :
      <OnlineTranscoding>
         <!-- Online AAC video streams miss sound, must transcode to ac3 -->
         <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="mp4" aCodec="aac" />
            <Matches container="flv" vCodec="h264" aCodec="aac" />
            <Matches container="applehttp" vCodec="h264" aCodec="aac" />
            <Matches container="mpegts" vCodec="h264" aCodec="aac" />
      </OnlineTranscoding>
newborn
Post Sat Mar 02, 2013 5:40 pm
Or perhaps make the modification seen in the first post of this thread. http://forum.serviio.org/viewtopic.php?f=11&t=8581
Post Sat Mar 02, 2013 6:59 pm
newborn wrote:Or perhaps make the modification seen in the first post of this thread. http://forum.serviio.org/viewtopic.php?f=11&t=8581
Yes newborn, this should be probably more accurate, Grokix, could you try this ?
newborn
Post Sat Mar 02, 2013 8:21 pm
Interestingly the above mentioned fix did get sound for some streams where there was no sound before, but I got no sound when playing an itvplayer stream. I'm going to append contentType="vod" after all.
So
<OnlineTranscoding>
         <Video targetContainer="mpegts" forceInheritance="true"> <!-- do not transcode to ac3 -->
               <Matches container="mp4" />
               <Matches container="flv" vCodec="h264" aCodec="aac" contentType="vod" />
               <Matches container="applehttp" vCodec="h264" />
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
               <Matches container="asf" /> <!-- to support mms:// streams -->
               <Matches container="flv" />
Update 1: That didn't help.. Now trying:
<OnlineTranscoding>
         <Matches container="flv" vCodec="h264" contentType="vod" />
Update 2: That didn't help either... I guess I'll now add Illco's mime-type renaming stuff..
Grokix
Post Sun Mar 03, 2013 10:57 am
Illico wrote:On Sony Bravia 2011 profile section (profiles.xml) you can edit :
      <OnlineTranscoding>
Thanks a lot!
The sound is now working, but video is slower then sound :( Sound speed is ok.
If I play this stream in VLC all is good.
I've updated ffmpeg info in my first post.
Post Sun Mar 03, 2013 1:03 pm
Grokix wrote:If I play this stream in VLC all is good.
We can not compare VLC with Sony decoder. VLC is very permissive and better than Sony, which is very restrictive.
Grokix wrote:The sound is now working, but video is slower then sound :( Sound speed is ok.
hum...try this:
      <OnlineTranscoding>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
Grokix
Post Wed Mar 06, 2013 8:26 pm
I've deleted "DAR="16:9" " from last config because Sony Bravia's zoom function worked bad.
Illico, now it works perfectly! Thanks a lot!
ps My home's TV fans thank you very much!
Users browsing this forum: Baidu [Spider] and 25 guests
