is there a way to save the transcoding files?
• Page 1 of 1
is there a way to automaticly save the transcoding output for futur use?
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Re: is there a way to save the transcoding files?
You could convert them yourself using e.g handbrake then Serviio won't need too
I think you want to export the temporary transcoded file to a record folder, isn't it ?
Exactly!
• Page 1 of 1
