Sony Bravia KDL-22EX320 No picture but sound is fine
prmadmax
Post Sat Mar 02, 2013 9:35 am
Trying to get this MKV file to play but all I'm getting is sound? (no picture).
TV is Sony Bravia KDL-22EX320 playing directly from serviio on my computer.
File size                                : 599 MiB
Duration                                 : 44mn 12s
Overall bit rate                         : 1 893 Kbps
Encoded date                             : UTC 2010-04-25 11:21:59
Writing application                      : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library                          : libebml v0.8.0 + libmatroska v0.9.0
Format profile                           : High@L3.1
Format settings, ReFrames                : 9 frames
Duration                                 : 44mn 12s
Bit rate                                 : 1 316 Kbps
Width                                    : 720 pixels
Height                                   : 480 pixels
Standard                                 : NTSC
Bits/(Pixel*Frame)                       : 0.159
Stream size                              : 405 MiB (68%)
Writing library                          : x264 core 88
Encoding settings                        : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1316 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Color primaries                          : BT.601 NTSC
Matrix coefficients                      : BT.601
Audio #1
Format profile                           : Dolby Digital
Duration                                 : 44mn 12s
Bit rate                                 : 192 Kbps
Stream size                              : 60.7 MiB (10%)
Title                                    : English
Audio #2
Duration                                 : 44mn 12s
Bit rate                                 : 192 Kbps
Title                                    : Spanish
Language                                 : Spanish
Audio #3
Duration                                 : 44mn 12s
Bit rate                                 : 192 Kbps
Title                                    : French
Language                                 : French
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : English
Menu
00:00:00.000                             : en:Chapter 1
00:09:55.219                             : en:Chapter 2
00:16:40.499                             : en:Chapter 3
00:26:25.375                             : en:Chapter 4
00:32:13.723                             : en:Chapter 5
Regards, MadMax
Serviio Beta Tester
Samsung Series 6 UE32H6400 (3D Full HD Smart TV)
Synology DS1512+ / 3GB Ram / 5x 3TB WD Red Edition HDDs with 5.2 firmware running Patters Serviio package for Synology NAS
prmadmax
Post Sun Mar 03, 2013 1:22 pm
Re: Sony Bravia KDL-22EX320 No picture but sound is fine
Has anyone got any fixes for this? So far the only thing i've found to work is to convert all the media to mp4 format so it will play :|
Regards, MadMax
Serviio Beta Tester
Post Sun Mar 03, 2013 2:15 pm
prmadmax wrote:Has anyone got any fixes for this? So far the only thing i've found to work is to convert all the media to mp4 format so it will play :|
Do you have the same problem for all your mkv/h264/ac3 files ?
prmadmax
Post Sun Mar 03, 2013 2:35 pm
No, It just seems to be these ones. Others play fine.
Regards, MadMax
Serviio Beta Tester
Post Sun Mar 03, 2013 6:21 pm
prmadmax wrote:
Illico wrote:Do you have the same problem for all your mkv/h264/ac3 files ?
OK,
Its probably due to an encoding setting that Sony device does not support :
... I suggest to re-encode this file.
