[SOLVED] no videos working with de last 1.2 version
leoleo
Post Sun Mar 03, 2013 8:52 pm
Hello, I have a BD player sony S370 and since the last version of servio 1.2 I can't read videos files (mkv, avi...) Before with serviio 1.1 I could read this files, moreover, I have also reinstalled this version
Could you help me someone please ?
Post Sun Mar 03, 2013 9:09 pm
Re: no videos working with de last version of serviio
Make sure you assign the correct profile under the console, it is no longer automatic for older Sony devices in order to better support features of newer models.
leoleo
Post Sun Mar 03, 2013 9:20 pm
OK I will try with "no automatic assign" that all right ?
And are you sure after this modifition videos files can be read ?
Post Mon Mar 04, 2013 8:09 am
I also have the Sony BDP-S370 model, and I have to manually assign the "Sony BDP-Sx70/SMP-N100 (2010)" profile on serviio console device list, and it works flawlessly. (Default is "Sony BDP-Sx90 (2012)" profile)
leoleo
Post Mon Mar 04, 2013 7:56 pm
thanks for all, I done the modifications that you wrote me and now it's ok
I had no understood some words... because I'am french
Have a good evening !
Post Mon Mar 04, 2013 8:29 pm
leoleo wrote:I had no understood some words... because I'am french
Je suis français aussi, bonne soirée leo !
leoleo
Post Tue Mar 05, 2013 8:07 am
C'est génial alors ! Tu vas surement pouvoir m'aider, jai d'autres questions :
Jai des fichiers mkv avec plusieurs pistes audio, comment faire pour que serviio me lise celle que je veux.. de plus sur ces fichiers la il ya des sous titres, jai vu que la version 1.2 les prenait en charge, , comment faut il faire.?
Post Tue Mar 05, 2013 9:42 am
leoleo wrote:Jai des fichiers mkv avec plusieurs pistes audio, comment faire pour que serviio me lise celle que je veux.. de plus sur ces fichiers la il ya des sous titres, jai vu que la version 1.2 les prenait en charge, , comment faut il faire.?
- Pour les pistes audio, pour le moment serviio ne sait pas extraire une piste particulière, il prend la première: une solution est d'utiliser un outil Mkvtoolnix qui te permet de nettoyer les pistes inutiles.
- Pour les soustitres, lit la FAQ: http://www.serviio.org/index.php?option ... icle&id=33, ce qu'il y a d'important c'est de préciser le champs "Preferred langage" dans la console. Personnellement j'ai mis : fr,fre,french
- For sound tracks, only the first one is used by current serviio's version, you have to use an external tool to clean/remove unnecessary audio tracks.
- For subtitles, read FAQ, you have to set value on "preferred langage" field, for example ; fr,fre,french
