[SOLVED] FFMPEG not found - transcoding not work
vsn
Post Mon Mar 04, 2013 7:31 pm
Good evening everyone,
Transcoding doesn't work for me. Scanning serviio logs I have found this message
ERROR [MediaServer] FFMPEG not found. Serviio will not work properly.
ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000010001210-7-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000010001210-7-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
I'm using Ubuntu 12.04, Serviio 1.2, FFMPEG package installed from the repo. I have also installed additional packages as described in the wiki for the case of Ubuntu 12.04. But no success.
xxx@britta-TravelMate-5740:~$ ffmpeg
ffmpeg version 0.8.5-4:0.8.5-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
built on Jan 24 2013 18:03:14 with gcc 4.6.3
Use -h to get full help or, even better, run 'man ffmpeg'
Have anyone a idea how can I fix it?
Thanks!
BR,
VSN
vsn
Post Mon Mar 04, 2013 7:32 pm
Re: ERROR [MediaServer] FFMPEG not found - transcoding not w
log attached
pc5dczc_20120304.log
log attached
(13.98 KiB) Downloaded 781 times
koan00
Post Mon Mar 04, 2013 8:18 pm
The wiki doesn't tell you to use the repo for ffmpeg, you are not using the correct ffmpeg version.
You need version 1.1.x for Serviio 1.2
Additionally you will need libass installed and the extra switch to enable libass when you compile ffmpeg (if you want subtitles to work)
Install libass:
cd ~/src
git clone https://code.google.com/p/libass/
cd libass
./autogen.sh
make
make install
Modify the configure step for building ffmpeg:
./configure --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb \
    --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 \
    --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx \
    --enable-librtmp --enable-libxvid --enable-libass
vsn
Post Tue Mar 05, 2013 8:14 pm
Hi koan00,
yes, after installing the last version of ffmpeg I am now able to use transcoding. Thanks a lot!
BR
VSN
koan00
Post Wed Mar 06, 2013 12:33 am
great :D
Users browsing this forum: Baidu [Spider] and 18 guests
