Serviio 1.2 not working
wullie1974
Post Mon Mar 04, 2013 7:12 pm
I upgraded from 1.1 to 1.2 and I now cant see serviio on my LG tv... 1.1 worked perfectly. I have no problems loading it on my PC and configuring it. but my TV does not see it... I have tried logical reboots. I have also noticed that my HTC one X also does not find Serviio to stream my Music...
Any help would be much appreciated.
Post Mon Mar 04, 2013 9:39 pm
Re: Serviio 1.2 not working
Check which IP it binds to in the console.
meghx
Post Tue Mar 05, 2013 6:17 pm
Hi ,
In a first time , sorry for my english it's not my language and i do my best for understand me
Same problems for me , Serviio 1.1 work but 1.2 don't
1.2 Work only after a fresh install
IP is good in console
Thx for this great server
wullie1974
Post Tue Mar 05, 2013 9:25 pm
the network setting say bound to IP which is my network card...
In console settings i only get dropdown box for English and tick box for check new versions..
still can't pick up serviio on my tv or phone...
starting to feel 1.2 is rubbish..
please can you give me a link for 1.1... Please as it worked.... :roll:
Post Tue Mar 05, 2013 11:11 pm
post detailed log and IPs of your devices
meghx
Post Wed Mar 06, 2013 5:18 pm
Look to work finaly for me
i do a uninstall , install 1.1 , install 1.2 and after this manually change TV profile
Thx
wullie1974
Post Fri Mar 08, 2013 11:01 am
going to stick with 1.1, took 1.2 off, put 1.1 on and instantly see's my tv...
koletom
Post Sun Mar 10, 2013 3:12 pm
Hello, could the textbox not get back instead of the dropdownlist? If dhcp hands out the ip address, then not good the ip binding. I cannot upgrade to the 1.2 versions so:(
Post Mon Mar 11, 2013 5:02 pm
I tried to make some fixes regarding this in 1.2.1
flyerblade
Post Fri Jun 07, 2013 5:18 pm
I am having similar issues with my almost-new 47" LG TV. 1.1 worked fine but with 1.2 and 1.2.1 Serviio keeps disappearing from the list of DLNA servers on the TV. The only solution is to kill the Serviio process with Activity Monitor (Mac OS here) and restart it, then it is visible.
I now use fixed IP addresses to try and keep things simple but this hasn't helped.
The trouble is happens so much that it's almost unusable which is a real shame as in all other respects it works really nicely. Really hope this can be fixed soon.
J_C
Post Mon Jun 24, 2013 2:16 pm
47" LG Smart TV, the server appears in the "Input" list > DLNA servers but when I click it, I just get the basic and boring DLNA menu of folders and the one I've shared in the console is not there. Is this correct or am I missing something?
Post Mon Jun 24, 2013 2:52 pm
J_C wrote:47" LG Smart TV, the server appears in the "Input" list > DLNA servers but when I click it, I just get the basic and boring DLNA menu of folders and the one I've shared in the console is not there. Is this correct or am I missing something?
How is this related to this topic?
Start a new one and provide some more details.
writehooks
Post Sat Mar 29, 2014 2:38 am
Same issue here. Everything worked fine in 1.1, updated to 1.2 and none of my devices can find serviio. Downgraded to 1.1 and resolved.
NX3
Post Sun Mar 30, 2014 9:34 am
Given we are on 1.4.x why not try a modern release
Sent from my HTC One mini using Tapatalk
Return to LG
