Cannot connect to Serviio server, it does not seem to be run
Maxxxika
Post Wed Mar 06, 2013 4:20 pm
Hello, I get this message whn I want to start serviio console. Everything was fine till I updated from 1.1 to 1.2
Post Wed Mar 06, 2013 5:01 pm
Re: Cannot connect to Serviio server, it does not seem to be
Maxxxika
Post Thu Mar 07, 2013 10:25 am
Here is the log content:
2013-03-07 11:23:21,369 DEBUG [ServiioConsole] Initializing Serviio Console
2013-03-07 11:23:21,383 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-03-07 11:23:21,384 INFO [ServiioConsole] Starting Serviio Console
2013-03-07 11:23:21,425 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-03-07 11:23:21,485 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-03-07 11:23:31,704 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-03-07 11:23:31,704 DEBUG [ServiioConsole] Retrieving console settings
2013-03-07 11:23:41,717 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-03-07 11:23:41,723 INFO [Messages] Loaded console message bundle for locale: en
2013-03-07 11:23:46,879 INFO [ServiioConsole] Leaving Serviio Console
I've uninstalled and reinstalled serviio several times but it is still not working.
slyguy42o
Post Thu Mar 07, 2013 3:15 pm
what operating system are you using? mac? win? linux?
Maxxxika
Post Thu Mar 07, 2013 5:43 pm
Win7 64bit
Post Thu Mar 07, 2013 5:53 pm
the service doesn't start for some reason. You could try to uninstall all Java versions, and install the latest Java again.
Maxxxika
Post Thu Mar 07, 2013 6:13 pm
zip wrote:the service doesn't start for some reason. You could try to uninstall all Java versions, and install the latest Java again.
Thank you, it solved the problem!
Destian
Post Fri Jul 12, 2013 4:53 pm
Hello. New User, first post.
I am having the same problem, but reinstalling Java did not fix the issue.
There seems to be a problem starting the service. If I go into services.msc and start the service manually I can then start the console, but otherwise I get the error in the original post and the following log:
2013-07-12 12:40:25,266 DEBUG [ServiioConsole] Initializing Serviio Console
2013-07-12 12:40:25,281 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2013-07-12 12:40:25,281 INFO [ServiioConsole] Starting Serviio Console
2013-07-12 12:40:25,328 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2013-07-12 12:40:25,360 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-07-12 12:40:35,594 WARN [ServiioConsole] Cannot connect to the server to get DB initialization info
2013-07-12 12:40:35,594 DEBUG [ServiioConsole] Retrieving console settings
2013-07-12 12:40:45,626 WARN [ServiioConsole] Cannot connect to server: Connection Error (1000) - Connection refused: connect
2013-07-12 12:40:45,626 INFO [Messages] Loaded console message bundle for locale: en
Running Windows 8.1 - Java 7 Update 25
Any help is greatly appreciated. Thank you.
crackedtooth
Post Sat Aug 24, 2013 1:54 pm
Hmm... recently same issue here
Did DSM upgrade... had to reinstall all.
Now on WIn 7 64bit.... console cant connect either.
ALso a problem starting the console 1.3.1
I suspect is a JAVA issue..
I have both 32 and 64 bit latest java installed... no issues I the past...
and to make matters worse... serviidroid works fine
Reinstalling java from full install as done in the past will not sort this issue on the two times I tried
crackedtooth
Post Sat Aug 24, 2013 4:23 pm
Confirmed issues with Windows 7 64 bit and Java 7 update 25
Tested both desktop and laptop , all with full removal and reinstall from offline etc etc
Can only normally access with 1.3.1 console (desktop) to 1.2.1 Server (on Synology NAS) with android ServiiDroid now.
COnsoile in windows just stops working immediately and gives cant connect error
Post Sat Aug 24, 2013 4:24 pm
crackedtooth wrote:Can only normally access with 1.3.1 console (desktop) to 1.2.1 Server (on Synology NAS) with android ServiiDroid now.
The console and server version must be the same (in your case 1.2.1 because 1.3 is not available for the Synology NAS yet). ServiiDroid works because I designed it to work with any version as I didn't want to have to publish a seperate version of Google Play for every version of Serviio.
Scoobydoo
Post Mon Aug 26, 2013 12:15 pm
Hello.
I just updated to 1.3.1 and for some reason it doesn't load up. It bounces for some time and then i get program not responding message. Serviio console is running fine. And I had no issues with the previous version, not sure which one it was but I guess one before 1.3
I'm using MacOs 10.7.5
I attached the log I got. I hope its the right one.
Thanks for the help in advance.
(19.91 KiB) Downloaded 944 times
Post Mon Aug 26, 2013 12:22 pm
It looks like the server is running, so never mind the icon is actually not in the dock.
Scoobydoo
Post Mon Aug 26, 2013 12:33 pm
zip wrote:It looks like the server is running, so never mind the icon is actually not in the dock.
well then something is wrong. because serviio console is not showing PS3 in it and it used to always, also I usually get this message that "serviio is now running" were I had to press ok, and the serviio icon always appeared in task bar i guess. Its wierd that I can see serviio in PS3 but I cant browse my files, it just tells e that there are no files. So I don't know what to do ;]
I'm sorry console is showing PS3 in it. Had to wait longer, but other problems still remain.
Scoobydoo
Post Sun Sep 01, 2013 4:32 pm
So is there anyway of fixing it? because SERViiO is not running at all. I would really appreciate your help.
Post Wed Sep 04, 2013 9:41 pm
From the log it shows the server is running. so:
1) start Serviio (it might or might not appear in the dock)
2) start Serviio-Console - it should appear in the dock
3) setup your files in the console
runarlan
Post Mon Oct 07, 2013 12:53 pm
I had the same problem, and fixed it by going to the task manager, and then the tab "services" where i found Serviio, right clicked it and pressed "start". Then when starting the Serviio console, it opened normally.
fotgold
Post Fri Oct 18, 2013 9:46 pm
I just format my pc and i'm installing all my stuff again, but i have the same issue with java... Any help? I tried to unistall and install java offline but nothing happened. A couple of days ago (before format), had no problem with serviio.
Angelikfear
Post Thu Oct 31, 2013 9:18 pm
I have the same issue. The only change I made when it started to act up was purchasing the pro license. Im not very happy about this because I never purchase paid products but I liked the way the software worked and wanted to donate to the devs. Please any help would be nice. I know that this conversation has been stale for some time.
Post Fri Nov 01, 2013 9:17 am
Angelikfear wrote:I have the same issue. The only change I made when it started to act up was purchasing the pro license. Im not very happy about this because I never purchase paid products but I liked the way the software worked and wanted to donate to the devs. Please any help would be nice. I know that this conversation has been stale for some time.
The server doesn't start for some reason. Post your serviio.log
Users browsing this forum: No registered users and 79 guests
