transcoding folder change not sticking
jrtolle
Post Wed Mar 06, 2013 7:30 pm
I thought I was having problems with the mediabrowser interface not observing the transcoding folder setting, but now it appears that Serviio is not picking up the change at all. I can save the change in the Console, but when I Exit Serviio and manually restart the service and console (I am on Windows 2012 with UAC enabled), the transcoding folder is set back to c:\windows\temp. Am I missing something somewhere on getting the change to stick? I have run the Console as an Administrator and made the change, but still the folder resets back to the default after a restart of Serviio.
As a side note, I have seen another post that mentions mediabrowser using a different folder for transcoding purposes (viewtopic.php?f=5&t=8129&hilit=mediabrowser+temp+folder), is that true? If so, can this be a fixed in a future build?
JR
Post Wed Mar 06, 2013 8:51 pm
Re: transcoding folder change not sticking
a bug, will be fixed in 1.2.1. Search the forum for a workaround.
Darkfalz
Post Thu Mar 07, 2013 2:15 am
"Keep original" channels is also not sticking, it is resorting to downmixing to stereo on restart.
Edit: Even when you change it and save, downmix still goes to stereo without a restart.
Sony KDL-55HX750 and BDV-N990W (Home Theatre)
Sony KDL-40D3100 and BDP-S390 (Loungeroom)
Users browsing this forum: Baidu [Spider] and 23 guests
