Fail to add video (mkv)
LucianMLI
Post Sun Mar 03, 2013 12:59 am
Serviio fails to add a video containing multiple subtitles. I tried truncating the title but no effect. Plays fine in VLC with subs and all.
<video> is not the actual file name
The number of subs is 28.
A sub contains hebrew characters, I don't know the encoding, could this be an issue? The subs are embedded in the video file. Default encoding Windows 1252
Here is the log error:
2013-03-03 02:43:01,933 WARN  [LibraryAdditionsCheckerThread] Cannot add file <video>.mkv because of an unexpected error. Message: Cannot create Video with title <video>
org.serviio.db.dao.PersistenceException: Cannot create Video with title <video>
   at org.serviio.library.dao.VideoDAOImpl.create(VideoDAOImpl.java:121)
   at org.serviio.library.dao.VideoDAOImpl.create(VideoDAOImpl.java:50)
   at org.serviio.library.local.service.VideoService.addVideoToLibrary(VideoService.java:107)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:188)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
Caused by: java.sql.SQLDataException: A truncation error was encountered trying to shrink VARCHAR '2/SRT/eng/true,4/SRT/hrv/false,5/SRT/cze/false,6/SRT/dan/fal&' to length 256.
   at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
   at org.serviio.library.dao.VideoDAOImpl.create(VideoDAOImpl.java:118)
   ... 6 more
Caused by: java.sql.SQLException: A truncation error was encountered trying to shrink VARCHAR '2/SRT/eng/true,4/SRT/hrv/false,5/SRT/cze/false,6/SRT/dan/fal&' to length 256.
   ... 16 more
Caused by: ERROR 22001: A truncation error was encountered trying to shrink VARCHAR '2/SRT/eng/true,4/SRT/hrv/false,5/SRT/cze/false,6/SRT/dan/fal&' to length 256.
   at org.apache.derby.iapi.types.SQLChar.hasNonBlankChars(Unknown Source)
   at org.apache.derby.iapi.types.SQLVarchar.normalize(Unknown Source)
   at org.apache.derby.iapi.types.DataTypeDescriptor.normalize(Unknown Source)
   at org.apache.derby.impl.sql.execute.NormalizeResultSet.normalizeColumn(Unknown Source)
   at org.apache.derby.impl.sql.execute.NormalizeResultSet.normalizeRow(Unknown Source)
   at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.InsertResultSet.open(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
   ... 10 more
From the exception the obvious problem is multiple sub handling. Maybe truncation, if necessary, should occur before the query, maybe it is, I dunno the code.
Post Sun Mar 03, 2013 11:43 am
Re: Fail to add video (mkv)
Can you post ffmpeg -i for the file?
EDIT: never mind, I fixed it for 1.2.1
Hinge
Post Wed Mar 06, 2013 4:12 pm
Is there a way to recode the .mkv to overcome this or is 1.2.1 available soonish?
I have about 20 files that all have this exact error when i imported them in last night.
Post Wed Mar 06, 2013 5:03 pm
Want to release within a week or so
Hinge
Post Wed Mar 06, 2013 8:24 pm
Ok cool, thanks for the response.
Darkfalz
Post Thu Mar 07, 2013 1:19 am
Got this too for multiple files.
I'm also bewildered why it fails to find a couple of movies which are exactly named as per themoviedb.org (with no special characters or anything). Like "Cocktail (1988)" for example. Or "Se7en (1995)".
Sony KDL-55HX750 and BDV-N990W (Home Theatre)
Sony KDL-40D3100 and BDP-S390 (Loungeroom)
Users browsing this forum: Baidu [Spider], Google [Bot] and 23 guests
