Help for updating ffmpeg with moded librtmp?
Post Mon Mar 04, 2013 10:13 pm
Serviio 1.2 for Windows comes with ffmpeg.exe containing the standard librtmp library. I have a moded librtmp.dll provided by KSV that contains code which allows mips.tv rtmp links to be opened, which the standard library cannot do. I need to access mips.tv as one of the SkySportsPlus.groovy sources.
Is there any way to link this librtmp.dll into the Serviio ffmpeg.exe? I know nothing about how to compile these libraries.
Post Tue Mar 05, 2013 8:11 pm
Re: Help for updating ffmpeg with moded librtmp?
I also have a problem with the latest Serviio 1.2 with M6group plugin, it seems that new librtmp library failed with M6 server.
With previous 1.1 version it's OK.
Post Thu Mar 07, 2013 12:46 pm
Zip,
Could you explain the difference between librtmp on serviio 1.1 (work with M6group.groovy) and serviio 1.2 version (failed) ? ( or point me the librtmp version used on 1.1 an 1.2)
Post Thu Mar 07, 2013 5:24 pm
1.1 has rtmpdump 2.4, 1.2 has the latest git source code
Post Fri Mar 08, 2013 3:38 pm
zip wrote:1.1 has rtmpdump 2.4, 1.2 has the latest git source code
OK,
I don't know how to do that, so is it possible that you compile a ffmpeg.exe (compatible with serviio) with librtmp2.4 version?
Post Fri Mar 08, 2013 4:19 pm
Do you wan me to revert to the older rtmp for future version or what is it you need?
Post Fri Mar 08, 2013 4:52 pm
zip wrote:Do you wan me to revert to the older rtmp for future version or what is it you need?
Revert to the older rtmp for testing on M6group plugin, I will call you after the test. Thanks
dval666
Post Fri Mar 08, 2013 5:00 pm
jhb50 wrote:Serviio 1.2 for Windows comes with ffmpeg.exe containing the standard librtmp library. I have a moded librtmp.dll provided by KSV that contains code which allows mips.tv rtmp links to be opened, which the standard library cannot do. I need to access mips.tv as one of the SkySportsPlus.groovy sources.
I would like to know about this cause I´m interested too. Perhaps someone can compile including that moded library.
Post Fri Mar 08, 2013 7:31 pm
Illico wrote:Revert to the older rtmp for testing on M6group plugin, I will call you after the test. Thanks
Download 1.1 and try it with that FFmpeg. It takes ages to build FFmpeg.
With previous ffmpeg (1.1) M6group plugin works, but not with the latest 1.2 I don't know what librtmp dev are changed ;-(
