Samsung BD-C6900: A couple issues
NuSkooler
Post Sat Dec 25, 2010 12:03 am
First off, thank you everyone that has been involved in the development of this product! I have a Samsung BD-C6900 Blu-Ray player and have tried the software Samsung provides -- it's total garbage. I heard of Serviio on a forum full of gripes about said Samsung software... great stuff!
A couple of issues I'm having -- I'm hoping someone else has the same or similar model of player and can help. First, here is my XML fragment:
<Profile id="11" name="Samsung BD-C6900" extendsProfileId="1">
      <Detection>
         <X-AV-Client-Info>*Samsung*</X-AV-Client-Info>
      </Detection>
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="mp4" />
            <Matches container="asf" />
The issues:
1) Audio is out of sync enough to drive you nuts any time someone is talking on screen.
2) Maybe this is normal, not sure: I have to set my BD player to PCM output to my receiver. Generally I have it on Bitstream for actual BluRays or if I plug in the laptop via HDMI even to play the exact same MKV.
Any help/tips greatly appreciated!
Post Thu Jan 06, 2011 3:56 pm
Re: Samsung BD-C6900: A couple issues
Is it for all your file or for some type?
Could you provide "ffmpeg -i" result of files with issue?
Post Thu Jan 06, 2011 3:57 pm
didn't Samsung C series profile work for you?
NuSkooler
Post Fri Jan 07, 2011 3:44 pm
Sorry for the long delay -- for some reason my post kept showing up with no replies even after refreshing. I got into the post and I see a couple. Odd?!
Here is the ffmpeg info:
FFmpeg version SVN-r23012, Copyright (c) 2000-2010 the FFmpeg developers
  built on May  3 2010 19:05:24 with gcc 3.4.5 (mingw-vista special r3)
erver --enable-memalign-hack --enable-libmp3lame --enable-w32threads --extra-ldf
lags=-L/static/lib --extra-cflags=-I/static/include
  libavutil     50.15. 0 / 50.15. 0
  libavcodec    52.66. 0 / 52.66. 0
  libavformat   52.62. 0 / 52.62. 0
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
[matroska @ 0148bc80]MAX_READ_SIZE:5000000 reached
[matroska @ 0148bc80]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (959/20
) -> 23.98 (959/40)
Input #0, matroska, from 'g:\Movies, Etc. Two\Movies\Inception.2010.1080p.BluRay
.DTS.x264-DiRTY\Inception.2010.1080p.BluRay.DTS.x264-DiRTY.mkv':
  Duration: 02:28:07.94, start: 0.000000, bitrate: N/A
    Chapter #0.0: start 0.000000, end 701.743000
      title           : 00:00:00.000
    Chapter #0.1: start 701.743000, end 1297.338000
      title           : 00:11:41.743
    Chapter #0.2: start 1297.338000, end 1880.337000
      title           : 00:21:37.338
    Chapter #0.3: start 1880.337000, end 2482.230000
      title           : 00:31:20.337
    Chapter #0.4: start 2482.230000, end 3073.737000
      title           : 00:41:22.230
    Chapter #0.5: start 3073.737000, end 3681.553000
      title           : 00:51:13.737
    Chapter #0.6: start 3681.553000, end 4229.684000
      title           : 01:01:21.553
    Chapter #0.7: start 4229.684000, end 4935.597000
      title           : 01:10:29.684
    Chapter #0.8: start 4935.597000, end 5512.590000
      title           : 01:22:15.597
    Chapter #0.9: start 5512.590000, end 6038.532000
      title           : 01:31:52.590
    Chapter #0.10: start 6038.532000, end 6682.175000
      title           : 01:40:38.532
    Chapter #0.11: start 6682.175000, end 7254.414000
      title           : 01:51:22.175
    Chapter #0.12: start 7254.414000, end 7809.051000
      title           : 02:00:54.414
    Chapter #0.13: start 7809.051000, end 8455.447000
      title           : 02:10:09.051
    Chapter #0.14: start 8455.447000, end 8887.947000
      title           : 02:20:55.447
    Stream #0.0(eng): Video: h264, yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 t
br, 1k tbn, 47.95 tbc
      title           : Inception 2010 1080p BluRay DTS x264-DiRTY
    Stream #0.1(eng): Audio: dca, 48000 Hz, 6 channels, s16
      title           : English
    Stream #0.2(eng): Subtitle: 0x0000
      title           : English
    Stream #0.3(fre): Subtitle: 0x0000
      title           : French
    Stream #0.4(spa): Subtitle: 0x0000
      title           : Spanish
The profile XML is (at least I'm attempting to) only for .MKV's as the player doesn't like to stream them natively out of the box (though it can from USB... grr).
