Video - Series Library -> Empty
verwooks
Post Sat Mar 09, 2013 1:15 pm
Hey,
I not sure how this happened. But I most certanly happened after 1.2. But worked a while.
I discovered it after I had added a episode, but the library wouldn't update. I could find the content using "Folders" and navigate to the right folder and start.
So I tried deleting the folder/drive from library and readding it, after trying to use for refresh several times. Now no series at all is visible, but movies work just fine as before.
http://ge.tt/2GFZjYa/v/0?c
I have tried reinstalling serviioo server, readding library, downgrading to 1.1. Changing presentation options. Nothing helps. No content will add in Series. That's the only problem.
How can I Fix this?
EDIT:
im doing a readd library with logging enabled. Will post later.
<!-- use INFO for library stuff -->
<category name="org.serviio.library">
<priority value="INFO"/>
</category>
verwooks
Post Sat Mar 09, 2013 2:47 pm
Re: Video - Series Library -> Empty
I wont post the whole log file, but I see some files won't get any metadata from:
http://www.thetvdb.com/api/235C8CA4529142E9/mirrors.xml
The site is down.
Message: Cannot retrieve list of mirrors for tvdb.com: Server returned HTTP response code: 503 for URL: http://www.thetvdb.com/api/235C8CA4529142E9/mirrors.xml
Could this be the problem?
2013-03-09 14:54:41,558 WARN [LibraryManager] Cannot read metadata of file G:\The Wire\The Wire - Season 5\the.wire.s05e02.avi via extractor ONLINE_VIDEO_SOURCES. Message: Cannot retrieve list of mirrors for tvdb.com: Server returned HTTP response code: 503 for URL: http://www.thetvdb.com/api/235C8CA4529142E9/mirrors.xml
2013-03-09 14:54:41,558 DEBUG [VideoService] Updating video in database: the.wire.s05e02
2013-03-09 14:54:41,558 DEBUG [VideoDAOImpl] Reading a Video (id = 283)
2013-03-09 14:54:41,558 DEBUG [GenreDAOImpl] Reading a Genre (name = Unknown)
2013-03-09 14:54:41,558 DEBUG [GenreService] Genre Unknown found
Post Sat Mar 09, 2013 6:48 pm
Yes, thetvdb.com are having problems. 1.2.1 should fix it.
verwooks
Post Sat Mar 09, 2013 11:25 pm
Excellent :) Waiting for it.
