Metadata frustration with movie "If.... (1968)"
garyelmes
Post Sun Mar 10, 2013 4:52 am
HI,
I'm having trouble getting Serviio to properly catalogue the movie "If...."
The filename is "If.... (1968).divx", which is an exact match for the name of the movie as it appears in TheMovieDB.org. If I configure Serviio to use online metadata sources, then it seems to assign the movie file a name almost at random. Right now, it has decided that the movie is "The Pawnbroker". Last time I removed and re-added it, Serviio decided it was "Rachael, Rachael".
The log file entry looks like this:
2013-03-10 17:20:54,601 INFO [LibraryAdditionsCheckerThread] Added file 'If.... (1968).divx' (title: The Pawnbroker) to Library
I've also tried various other permutations of the file name, such as "If (1968).divx" - no good.
If I create a .nfo file with XBMC and switch to that as my metadata source, then the file is catalogued fine. But then, of course, all the other cataloguings disappear. I don't really want to manually catalogue everything using XBMC just for the sake of one ambiguous movie name.
Help!
Post Sun Mar 10, 2013 2:14 pm
Re: Metadata frustration with movie "If.... (1968)"
I've added some code to 1.2.1 to support this scenario
