Please check your network connection
kevinm2k
Post Sat Mar 02, 2013 12:42 pm
Hitting a new problem with the new version of Serviio (1.2).
I am attempting to run a Futubox stream through Serviio to my Samsung UE37ES6300.
The time is variable but its normally between 2-5 minutes before I get the message 'Please check your network connection' and it goes off.
Any ideas???
Kevin
Iveky
Post Sat Mar 02, 2013 5:49 pm
Re: Please check your network connection
it is always same error on samsung es serie, like before with 1.0 and 1.1, and has nothing with new 1.2 serviio version, i think...?
Rjay
Post Sun Mar 10, 2013 7:07 pm
kevinm2k wrote:Hi,
Any ideas???
Kevin
It seems as if there is a problem with some Samsung models when streaming online content, there are plenty of posts on here about disconnect issues with Samsung TVs. I have the UE40ES6300 and I have had mixed results when streaming online feeds with Serviio. Can you tell me in what form you entered the url to stream Futubox streams? I have tried but when I selected the file on my TV all I got was the Futubox logo, no video or audio so I must have messed up somewhere with the URL. Maybe if I can get the URL to work we can work on this together, I have in the past manged to get online content that wouldn't play to play correctly with a bit of messing about.
I tried Wild Media Server for Futubox streams because you can use the Futubox m3u file so as you get all the feeds in one folder on the TV, but with Wild Media Server no matter what I did it would only ever play 15 seconds then I got the "Please check your network connection" message and then it would switch off. Of course nStreamPlayer does not work with 2012 Samsung TVs either, typical!!
kevinm2k
Post Sun Mar 10, 2013 7:43 pm
I managed to get nstreamplayer working. It does a decent job actually. Message me IG you want the package as I've packaged it up.
Sent from my Nexus 4 using Tapatalk 2
Conic
Post Mon May 27, 2013 5:14 pm
Users browsing this forum: No registered users and 51 guests
