error when playing
domclark
Post Sun Mar 10, 2013 8:03 pm
error when playing
Out of 1200 or so videos about 400 won't play get the dreaded error messages.Tried with other machines and different browsers, windows 7 , fire fox, enternet explorer, safari. Some of the mov's play fine. Mostly the ones that won't are mov's. The error have a few different numbers. I tried changing everything about the files themselves, format, name encoding. Also tried many things that I found on this forum, tried everything that was also talked about for suviio console and more than a few setting, of course one at a time. Tried to find something common about the ones that don't play. I converted them sometime ago in quicktime pro /save as self contain file/. Most I believe became mov's. I believe a very small amount from that batch that was converted do play, but that has something to do in what they were in the first place. The only thing that I can find common is quicktime movie , Codecs: XVID,MPEG layer 3, all that don't work have this.
Log file... If this is not the right log file than could you give direct path to the CORRECT ONE or ONES, there are more than a few.
Been reading them and tired now. apple version 10.6.8 Thank, nic. P.S. I have added some of the one that don't play to the playlist/ right side.
I did convert a few now with toast to see what happens and they did play afterwards. But this would be a job in itself, to do all. Hoping to find an easer fix......
Post Mon Mar 11, 2013 5:19 pm
Re: error when playing
can you post results of
ffmpeg -i "/Users/Nic/Music/iTunes/iTunes Music/Movies/Yes Man(2008).mov"
domclark
Post Mon Mar 11, 2013 11:20 pm
yes wait. Here it is. XVID, MPEG Layer 3.... There are some different ones to that are not playing. I did some more looking at a bunch after posting this mornig. I do know for sure that these are ones I converted, quicktime pro save as self contained file. Some from that batch do play. I also have tried many servers and players in the past and really have never run into this on such a vast scale????????LOL... P.S I have to go, But I will find some more different ones later and post them.
domclark
Post Thu Mar 14, 2013 11:19 pm
I have nor herd back from you in a few days on this issue, any updates to this?
Post Thu Mar 14, 2013 11:23 pm
you didn't post the information I asked for
domclark
Post Fri Mar 15, 2013 6:20 am
It was not completely clear in what you needed.
Screen shot 2013-03-15 at 1.17.55 AM.png (17.7 KiB) Viewed 10656 times
domclark
Post Fri Mar 15, 2013 10:36 am
Is that what you needed.
Post Sat Mar 16, 2013 10:41 am
zip wrote:can you post results of
See my signature for further details
domclark
Post Sat Mar 16, 2013 6:34 pm
I have posted the code from the file itself and from the error when playing. I don't know what you are asking for instead. You will have to be really specific in what.
Post Sun Mar 17, 2013 8:51 pm
How can I be more specific? Did you look at the link in my signature? viewtopic.php?f=5&t=1123
Then execute ffmpeg as given above and post the results here.
domclark
Post Wed Mar 27, 2013 9:32 pm
√ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 29 2013 00:10:12 with gcc 4.0.1 (GCC) (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-libfreetype --enable-fontconfig --enable-libass --enable-pthreads --disable-mmx --extra-ldflags=-L/Users/MacAdmin/Desktop/build/target/lib --extra-cflags=-I/Users/MacAdmin/Desktop/build/target/include --extra-libs='-lpolarssl -lfreetype -lexpat -liconv'
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
[mpeg4 @ 0x102b800] Invalid and inefficient vfw-avi packed B frames detected
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/Nic/Music/iTunes/iTunes Music/Movies/Yes Man(2008).mov':
major_brand : qt
minor_version : 537199360
compatible_brands: qt
creation_time : 2010-12-14 13:33:47
Duration: 01:44:28.95, start: 0.000000, bitrate: 923 kb/s
Stream #0:0(eng): Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 608x256 [SAR 1:1 DAR 19:8], 791 kb/s, nan fps, 23.98 tbr, 24k tbn, 23.98 tbc
handler_name : Apple Alias Data Handler
Stream #0:1(eng): Audio: mp3 (.mp3 / 0x33706D2E), 48000 Hz, stereo, s16p, 32 kb/s
Post Thu Mar 28, 2013 5:16 pm
thanks. Some weird things there.
Could you upgrade to 1.2.1, play the file again and post serviio.log again, thanks
domclark
Post Thu Mar 28, 2013 5:39 pm
The program is updating the data base now and I will try in a bit.
domclark
Post Thu Mar 28, 2013 7:00 pm
It is working the same, allot of videos?????? NOT
domclark
Post Sun Apr 07, 2013 3:40 am
Ya no, you have been just stringing along with questions that meant NOTHING. Your answer was useless when you knew I had the latest version. Figures you state your junk plays mov's and m4v's witch it does NOT. You take money and act like you give support, you don't. Your just another arrogant prick and a common thief. Just a punk in my neighborhood. Like your someone ZIP shit. I'll be in your neighborhood soon, so we can talk about it then.
Post Sun Apr 07, 2013 6:15 am
yeah zip, why didn't you drop everything and devote all of your attention to solving this guys problem <sarcasm>. Clearly he is someone of that we should all take notice of... not!
domclark - it's one thing to be frustrated, another to be rude. I don't think anyone will be lining up to help you in the future. Good luck and goodbye!
Post Sun Apr 07, 2013 9:43 am
You didn't do what I asked you to, yet demand answers. Either calm down or send email to sales[at]serviio[dot]org and I will happily refund your money - not really interested in a customer like you. bye
Users browsing this forum: Baidu [Spider] and 53 guests
