[SOLVED] Can't play this file, ideas?
CarlosC
Post Sat Mar 09, 2013 10:21 pm
Hi! I have a Sony BDP-S570 (US Model). I have it running with the correct US 2010 profile and it's working fine for 99% of the things I throw at it, but I'm having problems with the following file:
Unique ID                                : 218591631172026694245037217365505586203 (0xA4733780A4428A2DAB642E7FDCE3B41B)
Complete name                            : E:\Películas\Hachiko, A Dog's Tale\Hachiko, A Dog's Tale.mkv
Format version                           : Version 1
File size                                : 4.37 GiB
Duration                                 : 1h 33mn
Overall bit rate                         : 6 704 Kbps
Encoded date                             : UTC 2010-02-28 04:07:23
Writing application                      : mkvmerge v2.5.3 ('Boogie') built on Mar  7 2009 15:00:41
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format settings, ReFrames                : 9 frames
Duration                                 : 1h 33mn
Bit rate                                 : 5 191 Kbps
Height                                   : 690 pixels
Display aspect ratio                     : 1.85:1
Bits/(Pixel*Frame)                       : 0.245
Stream size                              : 3.30 GiB (76%)
Title                                    : Hachiko.A.Dog's.Story.2009.BluRay.720p.DTS.x264-CHD
Writing library                          : x264 core 84 r1416 fcf70c2
Encoding settings                        : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.1 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=5191 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=1:0.60
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 1h 33mn
Bit rate                                 : 1 509 Kbps
Bit depth                                : 24 bits
Stream size                              : 1 006 MiB (23%)
Title                                    : DTS-HDMA core 5.1CH 1509Kbps
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
Input #0, matroska,webm, from 'e:\Películas\Hachiko, A Dog's Tale\Hachiko, A Do
g's Tale.mkv':
    creation_time   : 2010-02-28 04:07:23
  Duration: 01:33:14.63, start: 0.000000, bitrate: 6704 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x690, SAR 1:1 DAR 128:69,
 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           : Hachiko.A.Dog's.Story.2009.BluRay.720p.DTS.x264-CHD
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (de
fault)
      title           : DTS-HDMA core 5.1CH 1509Kbps
Any ideas?
CarlosC
Post Mon Mar 11, 2013 8:08 pm
Re: Can't play this file, ideas?
Anyone?
Post Mon Mar 11, 2013 8:15 pm
Could you enable detailed logging and post the log where you start to play this file ?
CarlosC
Post Mon Mar 11, 2013 8:19 pm
Ok, will do.
CarlosC
Post Tue Mar 12, 2013 2:22 am
Here it is:
2013-03-11 22:28:04,373 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Películas\Hachiko, A Dog's Tale\Hachiko, A Dog's Tale.mkv
2013-03-11 22:28:04,374 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 4 -i E:\Películas\Hachiko, A Dog's Tale\Hachiko, A Dog's Tale.mkv -y -c:v mpeg2video -b:v 17000k -maxrate:v 17000k -bufsize:v 17000k -vf subtitles=filename="E\\:/Películas/Hachiko, A Dog\\\'s Tale/Hachiko, A Dog\\\'s Tale.srt":original_size=1280x690 -r 24000/1001 -g 15 -c:a ac3 -b:a 320k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-9265-bdp2010us-ORIGINAL-646b8ac3bf0f4e973f6fb4fd67f211a6.stf
2013-03-11 22:28:04,716 WARN  [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2013-03-11 22:28:04,716 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2013-03-11 22:28:11,875 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:131)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:100)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:120)
   at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
   at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:80)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
CarlosC
Post Tue Mar 12, 2013 2:40 am
Ok, I solved the problem.
Seems it has to do with the folder/file name. I renamed the folder, file and subtitles to Test (so it's Test\Test.mkv and Test\Test.srt) and it's working just fine.
Looks like there's some problems when using , or ' on the ffmpeg command line and I see serviio is not using filenames between ", it's using escape characters like \ instead. May work under linux, but certainly there are some cases (like this one) where it doesnt :D
Post Tue Mar 12, 2013 6:59 pm
Re: [SOLVED] Can't play this file, ideas?
yes, the , will be encoded in 1.2.1
CarlosC
Post Fri Mar 15, 2013 12:13 am
Great, thanx Zip for your awesome work!
