Presentation Settings
Post Tue Mar 12, 2013 10:18 pm
I've searched, but perhaps I've missed it. I'm wondering if there is something I need to set in the presentation settings. I have several TV series that I am ripping from DVDs. I place the files in a folder with the series name, then each episode with SxEx. Serviio is gathering the correct metadata, no problem. However, I am seeing the videos in both the Series folder and the Titles folder. I would like to have my movies in one list, and the TV episodes under Series, episode name. Right now, Since every Perry Mason episode is named "The case of..." my C folder under titles is getting extremely long.
So, is there a particular setting that only lists the TV episodes under one folder (Series?) and only movies in another?
Post Tue Mar 12, 2013 10:31 pm
Re: Presentation Settings
Post Tue Mar 12, 2013 10:58 pm
Ah, I found a fix. Instead of using Titles I tried Movies and that did the trick. I could swear I tried that before, but that was older versions. Maybe something was changed. Anywho, now I have three folders when I first connect to Serviio: Movies, Series & Online. Movies is just that, Series is TV episodes and Online is just that as well. All is well with the world again :D
NX3
Post Tue Mar 26, 2013 11:09 am
Or you can setup up folders tv, movies and then use use the folder browse option :)
Post Tue Mar 26, 2013 12:30 pm
NX3 wrote:Or you can setup up folders tv, movies and then use use the folder browse option :)
That's certainly an option. For family members I like keeping it as simple as possible, and right now my TV shows are on three separate hard drives. Spreading out my files, don't ya know. :D What I should do is replace all my media hard drives with new 3TB drives and keep one just for TV episodes. All it takes is money, right? :lol:
Return to User experiences
