Library on Synology NAS USB device
jpifer
Post Wed Sep 19, 2012 1:01 pm
I'm running the latest serviio on my synology ds411+. Love how it works.
I have no problem playing videos with the library stored on the internal synology drives, but when I try to store video files on an external usb drive, it doesn't seem to find the files. The folder is shown, but it is empty.
Hopefully I gave enough information. Can anyone tell me if this should work or not?
Thanks,
James
Post Thu Sep 20, 2012 9:20 pm
Re: Library on Synology NAS USB device
read the FAQ
jpifer
Post Fri Sep 21, 2012 12:11 pm
Done that already. If you are referring to "My files (on remote drive) are not scanned" I don't believe that applies. I'm running the Synology Serviio package, not the Windows Serviio package. I heard back from Patters on a blog and he is going to check it out when he has time.
Thanks,
James
trabantero
Post Tue Mar 12, 2013 11:26 pm
hey all,
did anybody find a solution for this problem? I searched in the forum, but couldn't find anything.
I have also written a message to "zip", but i guess he don't want to help at this problem ... @zip: please show me the correlating topic in the faq.
Best regards,
trabantero
Post Wed Mar 13, 2013 1:56 pm
The above FAQ entry applies, the USB is a 'remote' drive t the NAS. You have to setup access rights correctly.
Users browsing this forum: Google [Bot] and 40 guests
