Computer is booting too fast
Facilis
Post Sun May 20, 2012 3:20 pm
Hey,
First, Sorry for my Bad english.
i got a problem.. i get a new computer with a ssd. I installed Serviio now and my problem is that my computer is booting too fast. I tryed delayed autostart and dependonservice already.
Delayed autostart is working, but the problem is, the console in autostart starts to fast and i get a error that the service is not running. I manually run the console after the delayed autostart is finished.
Dependonservice Tcpip is not working. My TV will not find serviio without restarting the service.
I need a solve for automatically starting serviio.
jabrown0604
Post Sun May 20, 2012 3:46 pm
Re: Computer is booting too fast
you could maybe have a delayed scheduled task. I haven't tried that but I would assume that would work. Will the service stay running after you manually start it?
“Those who have succeeded at anything and don’t mention luck are kidding themselves.”
Server-Mac Mini / OS-WHS 2011 SP1 / TV/HTS-Sharp Aquos/Samsung HT-C6600
Facilis
Post Sun May 20, 2012 3:54 pm
after manually is all fine.. only autostart is not working probably. Is there a way to start automatically console after the service is running with delayed autostart ? Maybe one minute later.
Post Sun May 20, 2012 6:30 pm
no, but you don't really need the console running anyway so you can run it manually when you need it. Otherwise you could write a bat file which would sleep for a bit and then execute the console and put that bat file in the Startup menu instead.
Post Mon May 21, 2012 7:32 pm
Here is my bat to restart serviio and the console.
StartServiio.bat.zip
(564 Bytes) Downloaded 336 times
kaman
Post Thu Mar 14, 2013 5:10 am
I am having a similar issue that I'm hoping someone else has run into and has a solution for. In my case I have had Serviio running for sometime without issue, until I upgraded my system drive to an SSD drive. Now my system boots fine, but every time it goes to sleep, Serviio fails to restore correctly after waking up. Every other application works fine except for Serviio. Now if I open the console and stop and restart the server, then every thing is fine, until the system goes to sleep again. With the conventional hard drive this all worked perfectly, but now my remote devices can't see Serviio until the restart, even though the console says that its running.
I'm guessing that Serviio is coming back online before my nic, or some other service that it depends upon, hence the restart afterwards works perfectly. Can anyone tell me how to slow Serviio down upon restarting, or to at least set a dependency or force a restart after coming back up? Thanks for any help on this frustrating problem.
Post Thu Mar 14, 2013 1:36 pm
Hopefully 1.2.1 will help with this a bit
kaman
Post Fri Mar 15, 2013 3:19 am
Cool! Let me know when its available and I'll take it for a spin and kick the tires!
Thanks!
Users browsing this forum: No registered users and 88 guests
