[SOLVED] Sony BDP S-790 Problem with '.srt' subtitles
ajmg
Post Wed Mar 13, 2013 3:04 pm
Hi there!
(Sorry my english)
I must starting by congratulate and thank you for the good work.
I was patiently waiting for version 1.2, since it had been announced that subtitles will be supported for any equipment.
Choosing the correct Profile (BDP S-x90) and properly configuring the console to hardsub the '.srt' subtitles, i'm always getting, with any format tested until now, the message "the file is corrupt or not supported" (or something like that) displayed by the BDP...
Am i missing something?
Thanks for your support...
AJMG
Post Wed Mar 13, 2013 3:10 pm
Re: Sony BDP S-790 Problem with '.srt' subtitles
Could you enable detailed logging and post here the result when you play this file ?
ajmg
Post Wed Mar 13, 2013 7:44 pm
Hi!
Detailed Logging returns:
2013-03-13 19:40:13,734 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2013-03-13 19:40:14,750 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:131)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:100)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:120)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:80)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
2013-03-13 19:40:15,000 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2013-03-13 19:40:17,078 WARN [ProcessExecutor] Process cmd has a return code of 1! This is a possible error.
2013-03-13 19:40:24,000 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2013-03-13 19:40:24,015 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
Can you help?
Thanks...
Post Wed Mar 13, 2013 10:40 pm
What is the file name? Are you on Windows?
ajmg
Post Wed Mar 13, 2013 10:46 pm
Hi!
Yes.
Windows XP Professional...
Filename samples:
Name - Of The Movie [01x01].mp4
Name - Of The Movie [01x01].srt
But it seams just don't play nothing (with external subs files) if subtitles are anabled on the console...
The same error...
Thanks...
Post Wed Mar 13, 2013 10:49 pm
There is a bug, file names incl. [ ] or , will fail. It's fixed in 1.2.1. For now you'd have to rename your file not to include [ and ]
ajmg
Post Wed Mar 13, 2013 10:51 pm
Oh!!!!
Ok... :)
I'll try it...
Thanks!
ajmg
Post Thu Mar 14, 2013 1:17 pm
Hi!
Just checked...
Simple filename:
FileName.mp4
FileName.srt
The problem persists...
Same Logg...
Thanks...
ajmg
Post Thu Mar 14, 2013 1:46 pm
By the way...
Checked with PS3 and just changes the error to "network servor error", or something like that...
Also tried reinstall Serviio...
No success...
Thanks...
ajmg
Post Thu Mar 14, 2013 5:52 pm
SOLVED!!!!
I'm sorry for this...
I changed the filenames but in the path there was folders with "[" and "]"...
That's ok now...
Thanks for all...
allon
Post Mon Sep 16, 2013 1:35 pm
Re: [SOLVED] Sony BDP S-790 Problem with '.srt' subtitles
Does the sony support .srt only via streaming from pc
or
Can in recognize this format from Hard disk
Users browsing this forum: Baidu [Spider] and 3 guests
