MOV Files on a Samsung UNES6100
pistoladas
Post Sat Mar 16, 2013 8:52 pm
Good afternoon/night.
I'm fairly new to this software and to all the transcoding stuff.
I installed Serviio and was really easy to set up and I can play most stuff on my TV.
Except, MOV files.
Most of these were taken with an Olympus Camera.
I was wondering then if there is any way to play these on my tv?
Perhaps there is a newer/optimum profile for this TV Series? Currently using Samsumg TV player C/D/E Series.
Anyhow, some info and thanks for the help:
C:\Program Files\Serviio\lib>ffmpeg -i "D:\My Videos\P7080366.MOV"
ffmpeg version 1.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Feb 5 2013 21:59:54 with gcc 4.7.2 (GCC)
p --enable-fontconfig --enable-libfreetype --enable-zlib --extra-libs='-lrtmp -l
polarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-
runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-
mingw32- --pkg-config=pkg-config
libavutil 52. 13.100 / 52. 13.100
libavcodec 54. 86.100 / 54. 86.100
libavformat 54. 59.106 / 54. 59.106
libavdevice 54. 3.102 / 54. 3.102
libavfilter 3. 32.100 / 3. 32.100
libswscale 2. 1.103 / 2. 1.103
Guessed Channel Layout for Input Stream #0.1 : mono
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'D:\My Videos\P7080366.MOV':
creation_time : 2002-07-08 18:24:16
comment : OLYMPUS DIGITAL CAMERA
comment-eng : OLYMPUS DIGITAL CAMERA
Duration: 00:00:42.93, start: 0.000000, bitrate: 2582 kb/s
Stream #0:0(eng): Video: mjpeg (jpeg / 0x6765706A), yuvj422p, 320x240, 2498
kb/s, 15 fps, 15 tbr, 600 tbn, 600 tbc
Stream #0:1(eng): Audio: pcm_u8 (raw / 0x20776172), 7867 Hz, mono, u8, 62 k
b/s
MEDIAINFO:
Complete name : D:\My Videos\P7080366.MOV
Format : QuickTime
Format/Info : Original Apple specifications
File size : 13.2 MiB
Duration : 42s 933ms
Overall bit rate : 2 583 Kbps
Movie name/More : OLYMPUS DIGITAL CAMERA
Encoded date : UTC 2002-07-08 18:24:16
Tagged date : UTC 2002-07-08 18:24:16
Writing library : Olympus
Origin : Digital Camera
Format : JPEG
Codec ID : jpeg
Bit rate mode : Variable
Bit rate : 2 499 Kbps
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 15.000 fps
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.169
Stream size : 12.8 MiB (97%)
Language : English
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : raw
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 1 channel
Sampling rate : 7 867 Hz
Bit depth : 8 bits
Stream size : 330 KiB (2%)
Language : English
Post Sun Mar 17, 2013 11:46 am
Re: MOV Files on a Samsung UNES6100
It seems there is a problem in the latest FFmpeg with transcoding mjpeg video codec. You can try to get the latest FFmpeg from Zeranoe, hopefully at some point it'll be fixed.
pistoladas
Post Sat Mar 23, 2013 10:04 pm
Thanks for your prompt answer.
