support to GoToMeeting
lavvash
Post Sat Mar 16, 2013 11:51 am
Hi ALL
How to play this file from serviio ?
Serviio not see this file from dlna on my Sony Bravia TV
MediaInfo
Complete name : D:\ServerFolders\Torrent\[Специалист] Основы ITIL. IT Service Management по стандартам V.3.1\2012-01-31 18.35 ITIL 30.01-06.02 v R.wmv
Format : Windows Media
File size : 196 MiB
Duration : 3h 5mn
Overall bit rate : 148 Kbps
Maximum Overall bit rate : 277 Kbps
Encoded date : UTC 2012-01-31 15:35:01.531
Writing application : 4.8 Build 723 / GoToMeeting
BitRateFrom the writer : 143552
Audio samples : 110086
Video samples : 7719
recording time : Вт, 31 янв 2012 21:41:47 Московское время (зима)
Format : G2M4
Codec ID : G2M4
Bit rate mode : Variable
Bit rate : 95.5 Kbps
Width : 1 280 pixels
Height : 1 024 pixels
Display aspect ratio : 5:4
Frame rate mode : Variable
Nominal frame rate : 29.970 fps
Bit depth : 8 bits
Language : Russian (RU)
Format : WMA
Format version : Version 2
Codec ID : 161
Codec ID/Info : Windows Media Audio
Description of the codec : Windows Media Audio 9 - 48 kbps, 44 kHz, mono 1-pass CBR
Duration : 3h 5mn
Bit rate mode : Constant
Bit rate : 48.0 Kbps
Channel(s) : 1 channel
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 63.8 MiB (33%)
Language : Russian
Post Sun Mar 17, 2013 12:27 am
Re: support to GoToMeeting
Post ffmpeg -i for the file
lavvash
Post Sun Mar 17, 2013 6:41 am
C:\Users\Администратор>cd C:\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg -i "D:\ServerFolders\Torrent\[Специалист] Ос
-06.02 v R.wmv"
g-config
Guessed Channel Layout for Input Stream #0.0 : mono
Input #0, asf, from 'D:\ServerFolders\Torrent\[╨б╨┐╨╡╤Ж╨╕╨░╨╗╨╕╤Б╤В] ╨Ю╤Б╨╜╨╛╨▓╤
Л ITIL. IT Service Management ╨┐╨╛ ╤Б╤В╨░╨╜╨┤╨░╤А╤В╨░╨╝ V.3.1\2012-01-31 18.35 I
TIL 30.01-06.02 v R.wmv':
WMFSDKVersion : 9.00.00.4509
WMFSDKNeeded : 0.0.0.0000
IsVBR : 1
WM/ToolVersion : 4.8 Build 723
WM/ToolName : GoToMeeting
BitRateFrom the writer: 1435Meeting
Audio samples : 1100Meeting
Video samples : 7719Meeting
recording time : ╨Т╤В, 31 ╤П╨╜╨▓ 2012 21:41:47 ╨Ь╨╛╤Б╨║╨╛╨▓╤Б╨║╨╛╨╡ ╨▓╤А╨╡╨
╝╤П (╨╖╨╕╨╝╨░)
Duration: 03:05:41.72, start: 0.000000, bitrate: 147 kb/s
Stream #0:0(rus): Audio: wmav2 (a[1][0][0] / 0x0161), 44100 Hz, mono, s16, 4
8 kb/s
Stream #0:1(rus): Data: none
Stream #0:2(rus): Video: g2m (G2M4 / 0x344D3247), 1280x1024, 95 kb/s, 1k tbr
, 1k tbn, 1k tbc
Post Sun Mar 17, 2013 11:31 am
g2m (GoToMeeting) video codec is not supported.
lavvash
Post Mon Mar 18, 2013 9:17 am
How to convert this files to supported format ?
Post Mon Mar 18, 2013 11:27 am
